Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > best mods for 7x10 mini lathe & mill what's yours?
Old 01-17-2010, 01:22 PM   #1
sourdoughsmitty
Liked 2 Times on 2 Posts
Default best mods for 7x10 mini lathe & mill what's yours?
Well after playing for a week and making a few smalltools I made a list of mods to help this model that I found online
1changing to ball bearings on both cross and compound ,now as the original holes are somewhat sloppy would a properly sized bushing do as well
2 ball bearing on the carriage drive crank , there again as in #1 above would I be better served with a properly fitting bushing?
3 buying the 14" bed for it , anyone done this ?is it wothwhile? I do mostly fishing tackle repair with this lathe
anyone have the specs on making my own belt drive for my mini mill ?
4 plans for the groz type qctp or similliar ?
thanx smitty
sourdoughsmitty is offline
Old 01-17-2010, 01:53 PM   #2
compressor man
Liked 6 Times on 6 Posts
Default Re: best mods for 7x10 mini lathe & mill what's yours?
I have performed quite a few (some rather amateurish ) but I feel that the best thing that I have ever done to my 7x12 lathe is modifying the compound and cross slide handles. I made new handles that let the actual part that you grasp with your fingers spin as you crank it. Did that make sense Wow, this made a BIG difference to me and I recommend anyone taking the time to do this. I guarantee that it will be time well spent.
Chris
Chris
compressor man is offline
Old 01-17-2010, 04:20 PM   #3
BillH
Best mod I did was to sell my 7x14 and buy a 8xXX or larger lathe.
BillH is offline
Old 01-17-2010, 04:43 PM   #4
cfellows
cfellows's Avatar
Liked 759 Times on 487 Posts
Likes Given: 3
Originally Posted by BillH
Best mod I did was to sell my 7x14 and buy a 8trash or larger lathe.
Great if you can afford it, but there has been a lot of very nice work done on the 7 x 10, 7 x 12, etc. It's a lot of lathe for the money and puts metalworking within the reach of many folks who couldn't otherwise afford it.
Chuck
cfellows is offline
Old 01-17-2010, 06:04 PM   #5
zeeprogrammer
Liked 172 Times on 172 Posts
Best mod I've made for the my 7x12 mini-lathe (thus far) was covering the carriage apron. Otherwise swarf gets in there very easily and messes things up.
I'm currently working on a DRO system using digital calipers.
Carl (aka Zee. will sometimes respond to 'hey' but never 'hey you'.)
To work. To work.
zeeprogrammer is offline
Old 01-17-2010, 08:22 PM   #6
ozzie46
Liked 41 Times on 54 Posts
Quick Change tool Post and Camlock on tailstock.
Loosening bolt to move tailstock gets tiresome real quick.
Ron
ozzie46 is online now
Old 01-17-2010, 08:56 PM   #7
Cedge
Cedge's Avatar
Liked 60 Times on 59 Posts
Smitty
By the time I upgraded to the C4 Lathe, my 7 x14 Micromark was modified to the max.
--Extended Cross slide travel for cutting up to 7 inch diameter materials
--Extended cross slide lead screw for full rearward travel
--fitted it with a 5 inch chuck
--Cross slide nut center drilled to remove backlash
--DRO's both axis and tail stock
--Independent variable speed power feed on longitudinal lead screw
--Spindle mounted Indexer
--All custom hand wheels and locks
--Tool rack mounted behind splash guard....(perhaps the handiest mod of all)
--adjustment points on rear of saddle to remove any lateral movement
The little fellow now sits there gathering dust and taking up valuable counter space, but I enjoyed every time I ever used it. I somehow can't seem to decide to sell it.
Mods to the little X2 mill were not quite as extensive.
-- Belt drive added
--Extended Z rack
--Adjustable Sieg Power Feed
--DRO, on XY&Z
--Spring loaded spindle stop
--Upgraded all locks with LMS kit
--LED table lighting
Again.... after upgrading, it gathers dust most of the time, but does do some second function drilling and a bit of milling.
Both machines delivered everything the were designed for and more. No regrets for having begun my long learning curve using them. The day eventually came when I wanted to upgrade to better stuff.... even if I didn't need to. By then I knew these machines and their quirks and easily worked with them or around them without thinking much about it.
Steve
Cedge is offline
Old 01-17-2010, 09:37 PM   #8
compressor man
Chuck
Thanks Chuck! I will be the first to admit that bigger lathes are better in almost every way than smaller ones. But just for hobby use a 7x12 may be all the lathe some people can afford. So why not spend some time making it the best tool that it can be.
Chris
Chris
Old 01-18-2010, 03:01 AM   #9
sourdoughsmitty
Great info all ,
Chuck's reply is also right on the money ,it is a lot of lathe for the money , I was looking for a larger one preferrably a 9" south bend but most that I looked at were pretty clapped out. I answered aqn add for both a 7x10mini lathe and mini mill for 500 . These were 2 years old with only 4 hours on them ,the guy got bored and put them away!! they still had the usual packing grease in all the places these also came with a fair amount of both lathe and mill tooling as well as a milling vise I added it all up at todays prices and figured more than 1200$$ here.I have beeen looking on the web and finding a lot of users of this level of machine tools. So far it has become somewhat of a hobby in itself improving these and making tooling for them it will be easier now to wait and find my s/b thanx all smitty
Old 01-18-2010, 03:37 AM   #10
slick95
slick95's Avatar
smitty ,
With nothing more than the quick change tool post mod (A2Z Little Machine Shop) for my Micro Mark mini-lathe and the mini mill without mod I built my first IC engine, the Odds and Ends Hit Miss:
http://www.homemodelenginemachinist....p?topic=7773.0
Great machines that fit my budget at the time and I'll never regret the purchase...
Jeff
A job worth doing is a job worth doing well...
slick95 is offline
Starting Mini-Lathe Mods cfellows Machine Modifications 81 12-03-2016 01:06 PM
7x10 Mini Lathe Tail Stock Cam Lock Mod dwentz Machine Modifications 6 02-10-2012 03:58 AM
7x10 mini lathe 1hand Buy / Sell / Trade / eBay 7 01-12-2011 04:56 AM
Mini Mill and 9x20 Lathe For Sale Jack Buy / Sell / Trade / eBay 2 02-15-2009 02:58 PM
Lathe and Mini Mill - Spare Belts - Getting an order together for UK Users CrewCab The Break Room 17 07-10-2008 10:06 PM
