Home Model Engine Machinist > Showing Them > A Work In Progress > Building an engine from scrap parts and no plans
Thread Tools Display Modes
Old 01-07-2010, 04:29 AM   #1
black85vette
Liked 59 Times on 56 Posts
Default Building an engine from scrap parts and no plans
See what you think about this. You guys know how I love to re-use stuff and make things with materials I have on hand. Well here is some stuff my friend gave me. Parts his company used to make but no longer produce. The box is cast and plated. The wheels were from some sort of surgical equipment and are aluminum. I have the 2" aluminum pipe stock from my mill power feed project. I have some left over .5" x 4" aluminum for a vertical piece to hold the cylinder. HOLY COW! the scale on this is bigger than anything I have ever thought about doing. The bore would be just under 2 inches. How much air will that take??
This may not be a good idea. Anyone want to talk me out of it? (or tell me how to make it work?)
black85vette is offline
Old 01-07-2010, 04:44 AM   #2
Deanofid
Liked 151 Times on 148 Posts
Likes Given: 5
Default Re: A possible pre-work in progress
I'm guessing you're figuring on a horizontal with a hit 'n miss appearance, 'Vette. If so, you can sleeve the cylinder so it won't displace so much in the way of cubic inches. Don't make the stroke too long and that will help too.
If you sleeve it, you can make it a good snug press fit, then cut some fins on the OD of the cylinder to spiff it up.
About 15 years ago, I made a wobbler with a bore of about 1 1/4" and a stroke of 1 1/2". It took a lot of air. I don't mean a lot of pressure, but a lot of volume.
I have one of those larger Sears compressors on wheels. Can't remember the storage tank size, but will pump up a couple of tires before it comes on. That wobbler would have it coming on every couple of minutes. I think you're looking at a lot of air consumption if you make it with a 2" bore and any reasonable stroke to match it's size.
Dean
Deanofid is offline
Old 01-10-2010, 02:17 AM   #3
Powder keg
Powder keg's Avatar
Liked 32 Times on 32 Posts
So, Have you started making chips yet? We're waiting
Wesley P
Idaho:o)
A Gismo ??? If it has a flywheel or spins and is made with small parts. I'll take one! If it makes noise, moves, or requires frequent oiling and dusting it's a better deal yet. It's especially right if its shiny and bright.
Powder keg is offline
Old 01-10-2010, 03:54 AM   #4
black85vette
No, not yet. I liked Dean's idea of fins on the cylinder. That would give it the width for a good proportion with the rest of the engine and allow a smaller bore. So I am going to have to find some appropriate material. I think I can get started cutting out a section for the crank to rotate in and also work out the bearing blocks.
Old 01-14-2010, 11:46 PM   #5
Bill Mc
Liked 2 Times on 2 Posts
Hi black85vette - I appreciate what you are planning to build but, won't the teeth on those two 'flywheels' be more like a buzz saw when the engine is running? I sure wouldn't want to accidently touch them with my wrist. Just thought I would put in my two cents worth. - Billmc
Bill Mc is offline
Old 01-15-2010, 12:23 AM   #6
bearcar1
Senior Member
Liked 42 Times on 42 Posts
Say BS' why not make it into a full-blown IC engine and then you would not have to worry about air volume and what not. I can see the basics in my mind. Take your time to do some actual working sketches and I'm sure you can decide whether or not you really wish to proceed. Best of luck.
BC1
Jim
bearcar1 is offline
Old 01-15-2010, 12:31 AM   #7
black85vette
Bill; This is just the raw materials. I plan on turning the outside of the flywheels smooth. Don't think it would look very good with the teeth either.
Jim; Good idea. That would make it much more of a project since I have not done an IC engine yet. May have to consider that. It would certainly be a one of a kind. Any special issues with an IC of that scale? How about cylinder material?
Old 01-15-2010, 12:59 AM   #8
Deanofid
Likes Given: 5
For IC, you will need some kind of cast iron, or at least steel liner for the cylinder.
Also, those wheels you have there look to be aluminum. They probably wouldn't be heavy enough for an IC engine. They have to provide enough momentum to provide a compression stroke. You could shrink on a steel rim.
Dean
Deanofid is offline
Old 01-16-2010, 02:01 AM   #9
cfellows
cfellows's Avatar
Liked 698 Times on 459 Posts
Likes Given: 3
I've never built an air engine that has a bore larger than .75" although I have a couple of 2 cylinder engines which are .75" bore. If you get much larger than that, you are going to use a lot of air unless you have a pretty short stroke and/or run it slow.
You can make those aluminum wheels, which look like browning timing belt pulleys, into more efficient flywheels by turning off the teeth and press fitting a short section of steel pipe over the perimeter.
Looks like a fun project.
Chuck
So many projects, so little time, not enough energy...
cfellows is offline
Old 02-18-2010, 02:18 AM   #10
black85vette
This project is a bit backwards. The parts are coming to me but not from a set of plans. The parts show up and then I try to figure out what to make with them.
Here is where I am right now. I have cut an opening in the rear of the base to make room for the crank to turn. Then I cut smooth flat spots for the front vertical piece and the crank supports. I turned the outside of the wheels to make them smooth and then made a close fit brass hub to reduce the opening in the center of the flywheels. I also had a new part show up. My friend gave me a cylinder from a glycol pump. The liner is already perfectly smooth and chrome plated. Next step is to figure out a vertical mount for the cylinder which will then dictate the position of the crank shaft.
No plans overhead valve steam engine and HMEM plans engine rcmadness Finished Projects 3 11-24-2010 11:57 AM
Another scrap engine Julian Photos and Videos 25 06-15-2010 03:04 AM
Scrap engine Julian Photos and Videos 11 04-25-2010 10:51 AM
Bassett Lowke 3/4 inch traction engine plans and parts tmuir Questions and Answers 7 08-25-2008 01:42 PM
Parts From Scrap rake60 Tips and Tricks 4 09-05-2007 03:02 AM
