Home Model Engine Machinist > Building Them > Questions and Answers > Truing square stock in a 4 jaw independent chuck?
Thread Tools Display Modes
Old 12-07-2009, 01:16 AM   #1
Twmaster
Liked 20 Times on 20 Posts
Default Truing square stock in a 4 jaw independent chuck?
I'm scratching my head here. I have some 1" square I need to work on. Cannot quite wrap my head around how to indicate this so it is trued in the chuck. Each time I try to rotate the part the indicator ends up physically moving making measurements pointless.
A search of google was useless.
Mike N
Folded, bended, spindled and mutilated. But happy.
Twmaster is offline
Old 12-07-2009, 01:39 AM   #2
Tin Falcon
Tin Falcon's Avatar
Liked 744 Times on 597 Posts
Likes Given: 18
Default Re: Truing square stock in a 4 jaw independent chuck?
This has been discussed before but poblaby the easiest way is to locate the center and center punch then indicat in on the punch mark with a pump center. the other way is to retract the plunger of the indicator as you turn the piece and you may want to set a little level on top to keep things square.
You can often get close just by eyeballing it in turn the chuck by hand and bring a bit close to the part then turn it 180 degrees you will se a gap adjust out 1/2 the gap then turn 90 degrees repeat until close then finish with above methods.
tin
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 12-07-2009, 02:04 AM   #3
Twmaster
D'oh! Pump Center.....
I was just looking at those on Tallgrass Tools web site a day or two ago...
Mike N
Twmaster is offline
Old 12-07-2009, 03:46 AM   #4
shred
Liked 33 Times on 33 Posts
Lacking a pump center, you can make do with a regular dead center trapped between the tailstock and the pop mark and indicate off that. The Bogster and others posted that one here a long while back.
Here's a few of the old threads:
http://www.homemodelenginemachinist....p?topic=6407.0
http://www.homemodelenginemachinist....p?topic=5034.0
http://www.homemodelenginemachinist....hp?topic=596.0 (the center-in-center trick is at the end of this one)
shred is offline
Old 12-07-2009, 05:40 AM   #5
mardtrp
Why not just stick it in the 4 jaw and tighten down the jaws a bit, now bring the tip of whatever tool you have in the toolpost, up towards the square bit. Start to rotate the chuck by hand and watch the square corners in relation to the tooltip.
Adust the 4 jaws as nessesary, until ALL the 4 corners are just touching the tooltip, when that happens, it's dead centre.
Try it, you wont believe how simple it is to do, until you give it a go.
Oh, dont bother with any dial indicator, not unless you dont like the thing, it's a good way to ruin them, by trying to true up a bit of square with them.
Mark
mardtrp is offline
Old 12-07-2009, 06:36 AM   #6
rake60
rake60's Avatar
Liked 211 Times on 189 Posts
There is the simple old method.
The indicator tip needs to be as close to on center as possible.
With the tip against one flat rock the chuck back and forth to find
the low spot and zero out the indicator. Pull the needle back to clear
the piece and rotate it 180° Lower the tip to that flat and again
rock the chuck back and forth to find the low spot.
If you indicate to the 4 sides low spots the stock will be centered.
If the stock is too big to clear the indicator needle by puling it back,
mount the indicator on the cross slide and move it back out of the way
to rotate to the opposite side.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 12-07-2009, 06:52 AM   #7
Deanofid
Liked 151 Times on 148 Posts
Likes Given: 5
Mark
Howzat?
Been truing square in a four jaw with the DI for years. Haven't hurt one yet.
Deanofid is offline
Old 12-07-2009, 01:53 PM   #8
jonesie
Liked 11 Times on 11 Posts
i agree with rake 60 use the indicator as he says i always set my indicator that is on my surface gage on the carriage then move it back out of the way.there will be times that just getting close will not be good enough and doing it this was you will be right on center every time. i have never damaged an indicator in30yrs +doing it this way
. good luck
jonesie is offline
Old 12-07-2009, 04:34 PM   #9
mklotz
mklotz's Avatar
Liked 138 Times on 258 Posts
Make a "flapper" for your DI as shown here...
http://www.homemodelenginemachinist....39062#msg39062
and you won't need to worry about damaging the instrument.
I made mine so it was one-screw-detachable from my regular 4J centering fixture.
Don't be tempted to center using the edges of square stock. Work off the flat surfaces. The edges are often dented and damaged.
Regards, Marv
Home Shop Freeware
http://www.myvirtualnetwork.com/mklotz
mklotz is offline
Old 12-07-2009, 09:55 PM   #10
Twmaster
Thanks again gang. Lots of reading. Great ideas! I just happen to have a coule of centers I can use temporarily until I can make a pump center.
Mike N
Twmaster is offline
6" Union 4 jaw independent chuck with integral 1 3/4-8 thread steamer Buy / Sell / Trade / eBay 7 02-05-2012 04:31 PM
Truing stock on a lathe milotrain Questions and Answers 5 08-31-2011 12:56 AM
Independent 4 jaw chuck trouble Tin Falcon Tools 12 08-10-2009 01:01 AM
WANTED: 4-Jaw Independent Chuck sparky961 Buy / Sell / Trade / eBay 0 08-03-2008 06:45 PM
How do I ensure stock is square in the chuck ? JohnS Tools 18 09-28-2007 07:38 AM
