Project of the Month built by Johno1958
Home Model Engine Machinist > The Tools and Tips > Tools > Building a precision mini drill press - any motor and spindle suggestions ?
Old 11-08-2009, 04:39 PM   #11
Liked 6 Times on 5 Posts
Default Re: Building a precision mini drill press - any motor and spindle suggestions ?
The standard, I believe, for using very small drills was an Albrecht (uncertain if this is the correct spelling) chuck.
Edit: Delta ( and probably others) offered a high-speed bench-top drill press many years ago (thinking the 60's or 70's). Back then, this was part of their industrial tool catalog - not the home stuff. Expensive then but second hand today... who knows.
There is an article in Pop Mech, Dec 1941 with plans to build a small modelmaker's drill press powered by a sewing machine or vacuum power brush head motor.
Elektor magazine had a construction article - early 2001, I think - but I cant locate any more info.
Dunc is offline
X2 spindle/motor heat? zeeprogrammer General Engine Discussion 2 01-11-2010 04:40 PM
Cutting keyway in motor spindle JimM Machine Modifications 2 06-29-2009 09:43 PM
Turning down a motor spindle JimM Machine Modifications 12 06-27-2009 08:17 PM
Drill press purchase suggestions ? David Morrow Tools 3 03-27-2009 12:18 AM
Buffalo Forge Drill press motor mod Bernd Machine Modifications 3 01-15-2008 01:31 PM
