Project of the Month built by dnalot
Home Model Engine Machinist > Building Them > General Engine Discussion > Vapor Carburetor
Old 09-13-2009, 09:40 PM   #1
Rustkolector
Liked 57 Times on 34 Posts
Default Vapor Carburetor
Has anyone built and used a vapor (bubble) carburetor based on Jan Ridders designs? If so, can you briefly relate your experience and any operating issues you observed?
Jeff
Rustkolector is offline
Old 09-14-2009, 07:57 AM   #2
nemt
Liked 6 Times on 6 Posts
Likes Given: 7
Default Re: Vapor Carburetor
Hy Jeff,
I myself have not build that vapouriser yet, but several of my Dutch modell builder colleges have. Very satisfying. Only after a some time, when the petrol goes out, the lighter parts of the petrol seem to be gone, so the mixtyre becomes unusable. You have to refresh the tankfilling.
Nemt.
nemt is offline
Old 09-14-2009, 12:11 PM   #3
Debian
Hi Jeff,
I could be wrong, but I'd take a look here:
http://www.homemodelenginemachinist....topic=4922.105
Looks like Cedge used a vapour carburetor for His marvellous "Victorian" IC engine.
Hope this helps.
Paolo
Debian is offline
Old 09-14-2009, 01:43 PM   #4
putputman
Senior Member
putputman's Avatar
Liked 94 Times on 89 Posts
Likes Given: 18
Jeff, I built Jan's carb some time ago. I mounted it on my Red Wing engine and it functioned well. The only negative I found was as the fuel level changed it had some effect on the carb adjustment.
Jan's first design was extremely simple and worked fine. I then built his new version that was supposed to have better speed control. I didn't have much luck with the new version. I must have done something wrong and after awhile, just gave up on it.
I would be interested in hearing how it works out for you if you build it.
Here is a video of it on the Red Wing.
Arv
Brainerd, Minn. USA
Think twice -- cut once ---- www.putputman.com
putputman is offline
Old 09-14-2009, 10:58 PM   #5
Rustkolector
Putputman,
I have built the latest version of Jan's vapor carb using the two disks. It works, but not well on my "particular" engine. I have a slow speed throttle governed engine. It starts exceptionally easy on a lean mixture setting, and runs nicely, but at about twice its design RPM. I cannot slow it down with the vapor carb throttle without the engine running roughly. It just won't run smoothly at the richer setting like Jan's engines do. I contacted Jan and he says he has experienced the same results, but since his engines are higher speed, they work fine. His pressure controlled 2 stroke, however, seems to be the exception and runs down to 300 RPM. I have had two different thoughts on correcting the problem. First, add a second rotary barrel throttle in-line to throttle the mixture volume after adjusting it to the best running mixture using the vapor carb throttle. Second thought is to add a throttling screw on the excess air intake on the vapor carb throttle. That way I can use Jan's 3 way rotary valve to set the vapor flow, and the air valve to adjust for a better air/fuel ratio. I will probably do the latter first. But to do that, I have to remake the throttle valve into the earlier one like you used. The disk version doesn't lend itself to neatly adding an air throttle valve. Any thoughts would be greatly appreciated.
Old 09-14-2009, 11:46 PM   #6
Cedge
Cedge's Avatar
Liked 60 Times on 59 Posts
I've seen 3 of the engines owned by local builders running on the Vapor system, one of which was a 9 cylinder radial engine. They seem to just work fine and all 3 users say they are quite simple and pretty dependable to use. The only downside I've heard from them was cold weather negatively effecting the vaporization.
I briefly experimented with the Vapor Tank but my little engine is so darned fickle and my deadline so closing so rapidly that I went back to the aspiration set up. I intend to revisit the Vapor Tank and in fact adapted the fuel tank on the Victorian so that I can make the switch over with little additional work.
Steve
Cedge is offline
Old 09-14-2009, 11:52 PM   #7
putputman
Senior Member
putputman's Avatar
Likes Given: 18
Jeff, how about building Jan's first version of the carb. It is very simple and fast to build. See if your engine run better with that one.
I had very similar problems with his second version. He may be right when he says they work better on higher speed engines. Mine are all low speed.
Arv
Brainerd, Minn. USA
Old 09-15-2009, 01:11 AM   #8
Rustkolector
Thanks, I will look around for info on Jan's first version. I am not familiar with it.
Jeff
Old 09-11-2012, 05:31 PM   #9
EMARCH55
Default
built one with copper pipe worked well on both my model rngnes
EMARCH55 is offline
Old 09-11-2012, 10:07 PM   #10
Brian Rupnow
Liked 3555 Times on 2941 Posts
Likes Given: 36
Default
I just built one three weeks ago for my Atkinson engine to Jans new design, but I haven't got the engine running yet.
Brian Rupnow
Brian Rupnow is offline
grapegro Likes This
Pacific Vapor Engine from Morrison & Marvin Castings idahoan Engines From Castings 220 01-20-2015 12:41 AM
Simplified Vapor Fuel Tank cfellows Plans 39 01-05-2013 10:31 AM
Carburetor cfellows A Work In Progress 13 05-20-2012 07:57 PM
Carburetor nfk General Engine Discussion 8 10-25-2010 10:33 PM
fuel vapor tank by cfellows jonesie General Engine Discussion 4 08-13-2010 04:49 AM
