Project of the Month built by apointofview
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Reducing Mini-Mill Column Flex (and Column Y-Axis Alignment)
Thread Tools Display Modes
Old 09-12-2009, 07:48 AM   #1
rudydubya
rudydubya's Avatar
Liked 25 Times on 24 Posts
Default Reducing Mini-Mill Column Flex (and Column Y-Axis Alignment)
After I finished the spindle-column alignment on my Harbor Freight mini-mill (http://www.homemodelenginemachinist....p?topic=6007.0), I still didn't get a good tram in the Y-axis. It measured about .004 (all my measurements are in inches) out of alignment, as if the column was tilted to the front just a tad. I also had a significant flex in the column. With a firm push or pull on the motor or top of the column in the Y-direction, I could get almost +/- .010 (2.5 tads) of up and down movement of the spindle relative to the table. I wanted to fix, or at least reduce, the flex, and planned on correcting the column-table alignment while I was at it.
From what I had read about the column flex, the consensus was that the major cause was that big Belleville washer under the big nut at the back of the column (with maybe some compression of the column wall under the washer thrown in), and by replacing the washer with a flat plate you could reduce the flex. Some folks added angle brackets and braces to the plate to make the column even more rigid. I decided on a simple flat steel plate bolted to the back of the column to replace the washer and act as a reinforcement up the column axis.
I made a column reinforcing plate (hereafter called a column plate) out of 3/4" thick, 4" wide steel, and drilled holes for some 3/8" bolts plus one 15/16" hole for the big pivot shaft. I used the center of the plate as a reference to locate the bolt holes. Most of you probably know I shouldn't have. The pivot shaft is not on the centerline of the column. It is centered on the ways, but the ways are shifted over about 1/4" on the gib side of the column. I never noticed it before. Must be a lesson in there somewhere. Anyway, my hole locations were far enough in from the sides of the plate to still work on the column, it's just a little off-center.
I match-drilled holes for the bolts into the back of the column, tapped them for 3/8" threads, and bolted the plate to the column. The flex was reduced to less than half of what it was, now about +/- .004, but still more than I wanted, and I hadn't fixed the Y-axis tram yet either.
I drilled four holes in a piece of 1/2" thick, 1" wide steel, one at each end for 3/8" bolts, and two near the center for 7/16" bolts. The end holes were far enough apart to clear the edges of the column plate. This would be a pressure plate to push on the bottom of the column plate.
I drilled and tapped holes into the base of the mill itself to match the 3/8" outside holes in the pressure plate, and drilled and tapped through the column plate only for the 7/16" holes, not into be base.
I bolted the pressure plate to the base of the mill with the outside bolts and tightened them until the column was pulled in enough to tilt the column back and eliminate the .004 Y-axis tram error. I then inserted 7/16" bolts through the center holes and screwed them through the column plate until they were snug against the mill base. With the end bolts pulling on the column, and the middle bolts pushing on the column, the bottom of the column was locked in place and the flex was reduced to about +/- .0015.
Some final notes:
With the bolts in place, I can no longer rotate the column side-to-side to mill at an angle. I have never used that feature anyway, so it was not a concern to me. Also, my mill was trammed in the X-axis to my satisfaction before I drilled the holes at the bottom of the column plate, but I left plenty of clearance around the 7/16" bolts in the pressure plate to allow some slight angle adjustment for tramming, if necessary.
My mini-mill Y-axis alignment required the bottom of the column to be pulled in toward the base, so the 3/8" outside bolts were tightened first, as evenly as possible to avoid any twist. Then the inside 7/16" bolts were screwed in just tight enough to eliminate any flex. If the required correction was the other way, the center bolts would need to be screwed in first, pushing the bottom of the column away from the base, and then the outside bolts tightened to eliminate any flex.
If I were to do this mod over, I would use a thinner column plate, say 5/8" or 1/2" so the big nut would be sure to grab all of the pivot shaft threads. The 3/4" plate I used just barely allows that. Also, my plate was 12" long. If I were planning to fit my mill with an air spring kit like the one sold by Little Machine Shop, I would shorten to column plate to maybe 10" long so it wouldn't be in the way of the hole in the column required by the kit.
The remaining minor flex in the column assembly is probably due to bending of the pivot shaft and/or the pivot plate. I couldn't think of any practical way to eliminate it entirely.
Drilling into your mill might void any existing warranties. I never had an extended warranty on my mill, so it wasn't a concern.
I think that's about it, thanks for reading.
Rudy
rudydubya is offline
pollaccia Likes This
Old 09-12-2009, 11:05 AM   #2
tmuir
Liked 32 Times on 32 Posts
Default Re: Reducing Mini-Mill Column Flex (and Column Y-Axis Alignment)
'With the bolts in place, I can no longer rotate the column side-to-side to mill at an angle. '
Does anyone use this feature?
Personally I would prefer it wasn't there as it just allows the mill to slip out of adjustment easier.
I always like reading peoples mods as I'm very much a follower rather than a leader in machine mods.
tmuir is offline
Old 09-12-2009, 12:59 PM   #3
Tin Falcon
Tin Falcon's Avatar
Liked 808 Times on 645 Posts
Likes Given: 18
interesting mod
Tmuir .
I have actually used the angle tilting function IIRC had to put holes in some 6 foot long pieces at a 37 degree angle . but for model work it seldom if ever gets used. IMHO it is usually easier to tilt the work piece than the mill head. although tilting the head to the correct angle then tramming it back to square was a required exercise in trade school.
IMHO tilting the mill head rather than the column would be more useful.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 09-12-2009, 01:49 PM   #4
zeeprogrammer
Liked 171 Times on 171 Posts
Great thread Rudy. Really good.
While I suspect (hope) that someday I can move up to a better lathe, I think my mill will be around much longer. I have the exact same mini-mill so your mods have been very interesting too.
How did you drill/tap into the base of the mill? Drill press? Take the table off?
Thanks.
Carl (aka Zee. will sometimes respond to 'hey' but never 'hey you'.)
To work. To work.
zeeprogrammer is offline
Old 09-12-2009, 06:31 PM   #5
rudydubya
rudydubya's Avatar
Originally Posted by zeeprogrammer
... How did you drill/tap into the base of the mill? Drill press? Take the table off? ...
zee, actually I left everything in place and used my trusty old electric drill. I used a scrap piece of steel that I milled down so it would fit between the plate and the base (from an earlier abandoned attempt to put a wedge between the plate and the base; it's a long story...) for a drill and tap guide. Two sizes of guide holes, first were sized to fit the tap drill (size "Q" as I recall) and I drilled the holes in the base. (Slow going in the cast iron, but not too bad.) Then I removed the scrap, enlarged the guide holes for a close fit on the 3/8" tap, replaced the scrap, and tapped the holes in the base. I clamped the scrap in place so it wouldn't slip. Used the same method to do the holes in the plate.
I'm not too good at drilling straight holes or tapping freehand, so I use guide holes drilled in the drill press whenever I can. Also, the holes in the base were located so they were just inside the side walls of the base. I didn't want to have to tap into blind holes.
Rudy
Old 09-12-2009, 06:50 PM   #6
zeeprogrammer
Thanks Rudy. And while you didn't know it at the time...you gave me a clue as to what to expect when I work on my Spindex. Drilling cast iron will take some time.
Thanks.
To work. To work.
Old 09-12-2009, 07:08 PM   #7
rudydubya
rudydubya's Avatar
You are quite welcome zee. I should have said "with MY drill bit it was slow going." YMMV. Always glad when a post is helpful to someone, and always hope it's not as a bad example.
Rudy
Old 09-13-2009, 09:35 PM   #8
Bill S
Liked 3 Times on 3 Posts
Very nice work! and great photos. I have one question though, how do you keep your shop sooo clean? Seriously, my shop is a mess and I clean it regularly.
Bill
Bill Stupak
Bill S is offline
Old 09-14-2009, 05:34 AM   #9
rudydubya
rudydubya's Avatar
Thank you Bill. The shop isn't normally that neat, just happened to be between projects and cleaned up that area to work on the mill and lathe. Usually tools and paper towels and chips and scrap and other assorted odds and ends scattered about.
Rudy
Old 09-14-2009, 11:20 PM   #10
Krown Kustoms
Liked 20 Times on 20 Posts
Send a message via AIM to Krown Kustoms Send a message via Yahoo to Krown Kustoms
Thats a great I dea, thanks for the post.
-B-
A big fan of Murphy
Krown Kustoms is offline
Mini-Mill Spindle-Column Alignment rudydubya Machine Modifications 42 02-19-2014 06:08 AM
Mill Column Protection rebush Tools 3 07-02-2012 02:42 PM
Column stiffeners and question about column to table perpendicular tramming Espeefan Machine Modifications 4 02-26-2012 02:16 PM
Is this an antique, benchtop, micro, column mill? Larry Questions and Answers 7 07-10-2011 01:04 AM
Sherline Mill - Extend the column height David Morrow Machine Modifications 1 09-14-2008 06:40 AM
