Home Model Engine Machinist > The Tools and Tips > Tools > Dividing head for Taig lathe/mill
Old 08-15-2009, 04:40 PM   #1
joe d
Liked 53 Times on 51 Posts
Default Dividing head for Taig lathe/mill
Hi all
Having choked after looking at the prices of factory-made gears, I've decided that I really need to learn to cut my own. So, I need a dividing head suitable for my Taig mill and lathe. Enter Tony Jeffrees... who has designed just the beastie required (see here: http://www.jeffree.co.uk/pages/divheadmk1.html )
I've started with the spindle:
Engineering Change No 1: decided that the spindle nose should be threaded 3/4-16 so all my Taig tooling will fit, this necessitated a filing guide to make the hex...(you all know how this goes... need a tool to make a tool to make a tool.....)
And here we are: spindle finished.
Don't touch that dial, more to come!
Cheers, Joe
joe d is offline
Old 08-15-2009, 04:43 PM   #2
CrewCab
Liked 32 Times on 32 Posts
Default Re: Dividing head for Taig lathe/mill
Looking forward to this Joe, thanks for sharing ............ good start on the spindle
CC
CrewCab is offline
Old 08-15-2009, 04:44 PM   #3
RobWilson
Guest
Posts: n/a
VERY NICE Joe
how long did it take to file the hex ?
Regards Rob
Old 08-15-2009, 04:52 PM   #4
joe d
Thanks CC, Rob: the hex is 1" across the flats, started at 1.20" dia, so it wasn't bad.. half an hour including a smoke and a cuppa. The material is leaded steel, so it cuts (and files) a treat. I will have to keep after it to keep the rust down, well, who said this was low maintenance
Joe
joe d is offline
Old 08-15-2009, 05:08 PM   #5
Kermit
Guest
Posts: n/a
Is that 12L14 really that much easier to work with than the 1018 I'm using? I've got tons(It seems ) of the stuff that are cast offs from work. It appears we don't use any leaded steel in anything we are making. We do use lots of 304, 316, 321, 347, and 4140. The 1018 is always rusted completely over its surfaces, but the 4140 appears to take longer than one to two weeks before it is completely covered with rust. This is Houston weather with 95 degree days at 80% humidity and almost daily rainstorms, 98-100% humidity nights are common after rain in the late afternoon.
and I'm blabbing without much point.......(maybe I'm getting rusty at small talk :P )
my question being how much easier is it to work leaded steel than low carbon steel?
Kermit
Old 08-15-2009, 05:19 PM   #6
mklotz
mklotz's Avatar
Liked 140 Times on 260 Posts
1212 is the standard (100%) for steel machinability. 12L14 comes in at an astounding 170%, making it winner of the machiniability stakes.
http://www.engineersedge.com/materia...l-aluminum.htm
Regards, Marv
Home Shop Freeware
http://www.myvirtualnetwork.com/mklotz
mklotz is offline
Old 08-15-2009, 05:37 PM   #7
zeeprogrammer
Liked 172 Times on 172 Posts
I made a crankshaft for the Open Launch engine out of 1018.
Then I tried the same thing for the Horizontal Mill out of 1018.
I failed at that (not because of the metal) and tried again using 12L14.
For me, the difference was astounding.
I don't have much experience but I'm wondering why I would ever use 1018 again.
I have the same question in the Horizontal Mill thread but no answers yet.
Carl (aka Zee. will sometimes respond to 'hey' but never 'hey you'.)
To work. To work.
zeeprogrammer is offline
Old 08-15-2009, 07:27 PM   #8
vlmarshall
vlmarshall's Avatar
Liked 55 Times on 55 Posts
Well, I tried to find something online that'd tell you 12L14 wasn't as strong as 1018. I found the opposite. We hardly ever use it at work, and I don't know why.
http://www.onlinemetals.com/alloycat.cfm?alloy=12L14
http://www.onlinemetals.com/alloycat.cfm?alloy=1018
...sorry for dragging the thread off topic.
Chesapeake, Virginia, USA, Northern Hemisphere, Earth, Sol system, Orion Spur, Milky Way.
Sherline 5400 mill, Xylotex drivers and EMC controller
Sherline 4400 lathe, Gecko drivers and EMC controller
vlmarshall is offline
Old 08-15-2009, 09:02 PM   #9
Maryak
Maryak's Avatar
Liked 141 Times on 126 Posts
Maybe lead and weldability has something to do with it
Best Regards
Its hard to remember your objective was to drain the swamp when your up to your neck in alligators.Если вы у Тетушки были яйца, она была бы Дядюшкой
Maryak is offline
Old 08-16-2009, 03:49 AM   #10
Deanofid
Liked 154 Times on 150 Posts
Likes Given: 5
Joe, I made one similar to Tony's, and it works great for gear cutting with the Taig. You'll get you're moneys worth out of it!
So, how did you cut the thread on the spindle?
Dean
Deanofid is offline
How many on here use a Taig / Peatol Lathe or Mill? alan2525 Tools 15 10-27-2013 10:32 PM
CNC Dividing Head Dinkum CNC Machines and Conversions 11 05-30-2012 05:00 PM
Rotary Head/Dividing Head Question chucketn General Engine Discussion 6 02-13-2012 03:18 PM
Dividing head m_kilde Tools 25 04-11-2011 09:17 AM
Sherline, Microlux or the Taig lathe/mill? shlomo Tools 30 07-13-2010 11:27 PM
