Project of the Month built by gbritnell
Home Model Engine Machinist > Showing Them > A Work In Progress > Building Elmer's Fancy
Old 07-25-2009, 06:37 PM   #1
arnoldb
arnoldb's Avatar
Liked 93 Times on 178 Posts
Default Building Elmer's Fancy
Well, Rocker fever has passed, but Engine Building fever definitely not...
I started on Elmer's Fancy, and will build as close to original plans as possible, but to the highest finish I can
Deviation from the original build plans will be to make shafts, holes and screws to the closest metric equivalents, I'll be using aluminium for the column and might "personalise" the flywheel.
Started with the column - turned the bottom dowel, turned space for the decorative foot, and turned the rest down to 5/8" up to the chuck as suggested by Elmer. Then laid out for the rest of the detail:
Part-way through turning the detail:
Nearly made a boo-boo on the taper bit; calculated the angle at which to set the topslide from Elmer's dimensions (nice doing trigonometry for a change), but forgot to halve it! Fortunately I realised this in time, as the initial cut angle just looked wrong.
This is where I stopped tonight:
To turn the round part at the foot, I just took a piece of 6mm silver steel, drilled a 4mm hole through it at a slight angle; then used the bench grinder to grind it to shape to make a form tool. Then heat treated it and a final couple of pushes over the oilstone & it worked a treat - forgot to take a picture though.
Wanted to carry on today, but had to stop due to severe chatter & cold feet - not on the project, but on my body - It's terribly cold here in Windhoek today and my workshop's not very warm
Regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Old 07-25-2009, 06:41 PM   #2
BMyers
Liked 9 Times on 9 Posts
Default Re: Building Elmer's Fancy
WOW ! If one piece looks that nice, I cant wait to see the rest
BMyers is offline
Old 07-25-2009, 06:59 PM   #3
Foozer
Liked 73 Times on 65 Posts
NO NO NO No No No no no no
Going to the Docs, see if there is a shot to be had to avoid the new strain of mental illness, if not
A thou or 2ml of Tequila should be sufficient self medication till the new strain passes.
Looking good though
Robert
"Nothing is more irritating than that which exposes the pedigree of ideas"----Lord Acton----
Foozer is offline
Old 07-25-2009, 07:33 PM   #4
vlmarshall
vlmarshall's Avatar
Liked 55 Times on 55 Posts
You're not SUPPOSED to fight it, Foozer!
Chesapeake, Virginia, USA, Northern Hemisphere, Earth, Sol system, Orion Spur, Milky Way.
Sherline 5400 mill, Xylotex drivers and EMC controller
Sherline 4400 lathe, Gecko drivers and EMC controller
vlmarshall is offline
Old 07-25-2009, 07:54 PM   #5
rleete
Liked 36 Times on 36 Posts
Likes Given: 39
You can't fight it. Might as well just get started.
Easily distracted by shiny things
rleete is offline
Old 07-25-2009, 08:24 PM   #6
arnoldb
arnoldb's Avatar
Thanks very much BMyers - I'll try to keep it that way
Regards, Arnold
arnoldb is offline
Old 07-25-2009, 08:33 PM   #7
arnoldb
arnoldb's Avatar
Robert, Vernon & rleete
This seems to be new strain - must have originated with Robert though.
Some other members also caught it - the "build it & bling it" strain !
My previous symptoms were to "just get the dang thing built" - now I want to make it & make it purty
Ah well, if you can't beat it, join it !
arnoldb is offline
Old 07-26-2009, 08:16 AM   #8
RobWilson
Guest
Posts: n/a
Hi Arnold,
great looking column,brings back memory's of the fun i had building my Fancy
Regards Rob
Old 07-26-2009, 08:59 AM   #9
arnoldb
arnoldb's Avatar
Thanks very much Rob
Regards, Arnold
arnoldb is offline
Old 07-26-2009, 05:28 PM   #10
arnoldb
arnoldb's Avatar
Did some more work on the column today.
I don't want to spoil the finish on the column, so clamped it with paper as protection in the vice, and set about milling the flats using the vertical slide on the Myford:
Flats finished, drilled & reamed holes for the main bearing and pivot shaft. I don't have a 3mm reamer yet, so made a d-bit reamer from some 3mm piano wire for the pivot hole:
Next up I made the drill-jig and spacer bush, then drilled the ports; just clamped the myford's machine vice in the cross-vice in the drill press & went for it:
Then, with the machine vice still in the drill press cross vice, I rotated the column 90 deg in the machine vice and cross-drilled the hole for the steam connection.
After that, the machine vice went back to the vertical slide on the Myford, column turned another 90 deg, and milled the flywheel clearance on the foot of the column, as well as drilled out the spring clearance for the pivot shaft. I found a spring that I hope will work.
Ended here tonight: column complete (except for base), and special bits & bobs needed to get to this stage.
Don't know if I will find shop time during the week to carry on; if not I'll have to wait for next weekend.
Regards, Arnold
arnoldb is offline
Elmer's Fancy II smfr Finished Projects 14 01-25-2012 03:21 AM
Elmer's Fancy II smfr A Work In Progress 20 01-21-2012 11:47 PM
Elmer's Fancy II miner49r General Engine Discussion 3 12-20-2011 09:24 AM
First Build - Elmer's Fancy thefishhunter Photos and Videos 14 06-25-2009 05:21 AM
Elmer's Fancy RobWilson Photos and Videos 6 04-21-2009 01:10 PM
