Home Model Engine Machinist > Building Them > General Engine Discussion > taig tips/setup Speedy's ultimate help wanted thread.
Old 07-04-2009, 10:25 PM   #1
Speedy
Senior Member
Liked 22 Times on 21 Posts
Default taig tips/setup Speedy's ultimate help wanted thread.
I am looking forward to using my lathe, but I have to wait untill I go out and purchase some material and some bits.
so I thought I should take the time to set up the lathe and have some questions.
I am not sure if the previous owner lapped the carriage to the bed.
and I am trying to make sure everything is ready for its first cuts.
what is the proper way of adjusting the gibs on the carriage?
should you be able to push the carriage across the the bed by hand? (what makes a perfect gib adjustment)
also the backlash in the handles of the carriage and cross slide is this normal to have?
I did read taigs manual but it didn't talk much about this
also if anyone has any general lathe advice for maintenance that would be great!
(any other substitute to the 10w oil taig says to oil everything with, maybe something better?)
thanks
Michael
-Michael www.shnitzlhaus.com
Taig lathe
Myford ML7
sieg x2 mill
Speedy is offline
Old 07-04-2009, 11:42 PM   #2
pete
Liked 44 Times on 33 Posts
Likes Given: 43
Default Re: taig tips/setup
Speedy, Get the book that pertains to this lathe written by I believe Tony Jeffree, You can search on Tee Publishing's web sit for the correct title. It will answer probably all of your questions plus has some good accesories to build for that lathe. The book is well worth the money and you won't be disapointed.
Pete
pete is offline
Old 07-04-2009, 11:54 PM   #3
kuhncw
Liked 62 Times on 60 Posts
Likes Given: 9
Hi Michael,
Congratulations on the new Taig. I suspect you know this, but there is a huge amount of good Taig information out on Nick Carter's site. http://www.cartertools.com/
Another good site is the Taig Owner's Club site: http://taigownersclub.forumotion.net/ and there is also a Taig group on Yahoo.
Backlash in the carriage and cross slide is normal on a lathe. I would also say you should be able to push the carriage along the bed with a gentle push. There should be no side to side motion. The Jeffree book mentioned in the previous post should be a great help as well.
Chuck
kuhncw is offline
Old 07-05-2009, 12:07 AM   #4
zeeprogrammer
Liked 172 Times on 172 Posts
I don't know the Taig (I barely know my own machine).
Select the 'home' tab and then do a search on 'gibs'. Lots of info.
I had (and still do since I'm still very new to this) trouble figuring out how to adjust the gibs. I ended up taking the thing apart, polishing the gibs, and then re-assembling. Very glad I did. World of difference. I expect to do it again soon...partly because I'm sure I can do it better...partly for the experience and learning. (But I have a very small machine and it's pretty easy to do.)
I don't know what others will say...but it sure seems like every machine has its personality and isn't the same as the next even if it's the same type. That's part of the fun.
I can push the carriage back and forth (assuming the screw is not engaged.)
Carl (aka Zee. will sometimes respond to 'hey' but never 'hey you'.)
To work. To work.
zeeprogrammer is offline
Old 07-05-2009, 12:15 AM   #5
raggle
Liked 6 Times on 6 Posts
The best information on this is on Nick Carter's site
where you'll find an enormous lot of links to Taig users' mods worldwide.
The Yahoo group is also useful - http://groups.yahoo.com/group/taigtools/
If you have the milling slide it will reveal all the shake you may have in the carriage and cross slide when you take a flycut or mill.
An early check on tailstock alignment is advised. you'll need to turn a centre on a piece of stock in the chuck as Taig does not supply a headstock centre. Bringing the tailstock up to it and gently trapping a thin piece like a razor blade will reveal any side to side or vertical error. If the tailstock is low, shim it up. Headstock high, shim that. Side to side is obvious
10W/30 is recommended lubricant.
Please post results here. I for one will be keen.
Ray
If you want to see further, stand on the shoulders of giants. Choose them carefully, be sure they are not monsters or midgets on stilts.
raggle is offline
Old 07-05-2009, 12:59 AM   #6
gmac
Liked 28 Times on 27 Posts
Michael;
There's a setup procedure described with photo's on Carter Tools website;
http://www.cartertools.com/setup.html
I've seen more specifics on gib setup - if I can locate them I'll post.
Here's one site with a number of "you-build" accessories for the Taig that may appeal to you;
http://www.deansphotographica.com/ma.../projects.html
Here's Tony Jeffree's website
http://www.jeffree.co.uk/modelengineering.html
I spiraled into the Carter Tools website and wasn't seen for two weeks . Be careful.... The Yahoo Group is quite active and the people very helpful. I still haven't really setup mine; I've been to distracted with re-learning machining and model IC engine designs!
Hope you enjoy the Taig as much as I do.
Garry
British Columbia, Canada
gmac is offline
Old 07-05-2009, 02:50 AM   #7
Tin Falcon
Tin Falcon's Avatar
Liked 815 Times on 647 Posts
Likes Given: 18
Micheal:
ways should be agusted for free easy movement without any side play. Sometimes this is a tough balance.
A little backlash is normal and not a real problem on a manual lathe.
Way oil for ways. IIRC I usese mobile vacra No 2
For spindle Mobile velocolite 10
There are many brands some probly better than What I am using these are old stand buys I bought a gallon of each and will use them untilll i run out then may look for something better.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 07-05-2009, 03:58 AM   #8
Speedy
Senior Member
WOW I cant thank you all enough for all your help so far.
I just emailed the fellow I got the lathe off of, since he didn't use the metal setup he didnt lap it.
sooooooo I will be lapping it soon, bit nervous (might be the excitement!)
so I have to take it all apart (well just take the carriage,headstock,tailstock off)
Tin Falcon, on the taig you can oil the spindle?
Oboy I sense lots more questions when I begin! better to do it now and get it right
Taig lathe
Myford ML7
sieg x2 mill
Speedy is offline
Old 07-05-2009, 11:13 AM   #9
steamer
Liked 105 Times on 101 Posts
Zee,
Yes machines do have their own "personality's" and over time you learn how to "listen" to what they have to say....sometimes with your ears and sometimes with your hands and eyes.
....Ok no cracks about "Lathewispering"......
steamer is offline
Old 07-05-2009, 01:19 PM   #10
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
That was a general statement to lathes may not apply to taig sorry for any confusion . You may only need way oil for small light machines.
From what I see you just purchased a lightly used made in USA machine. Why do you want to lap the ways? does it really need it? you may be causing more problems than you are correcting by doing this.
The Ultimate boys Mechano Project Springbok General Engine Discussion 1 06-02-2012 01:25 AM
Wanted Taig pulleys crab Buy / Sell / Trade / eBay 0 03-20-2012 11:34 PM
Speedy's first part. rc airplanes. Speedy The Break Room 24 04-09-2010 09:25 PM
X2 table dissassembly tips wanted tmuir General Engine Discussion 3 05-14-2009 11:43 PM
The ultimate shop calculator mklotz Tools 2 10-11-2007 10:13 AM
