Home Model Engine Machinist > Building Them > Engines From Castings > Stuart 10H
Old 06-09-2009, 07:12 PM   #11
kellswaterri
Senior Member
Liked 10 Times on 9 Posts
Likes Given: 3
Default Re: Stuart 10H
Hi Jeff, nicely done with the engine build...did you encounter any problems fitting the nuts to hold the Cylinder to the body of the engine... two things, one size Smaller nuts are available in most BA sizes...also I personally think the drawing pitch circle for the studs holding Cyl/ to engine body is a tad too small...I found this out the hard way on the Score build
All the best for now,
John.
kellswaterri is offline
Old 06-09-2009, 11:06 PM   #12
Jeff02
Liked 5 Times on 5 Posts
Likes Given: 5
Bob and John, Thanks for the kind words.
Yes I to think Diameter is too small, this is my third and on my other two I said the same thing, I think on my forth I will increase by about an 1/8 of an inch on the total diameter this will give me 1/16 a side.
Jeff02 is offline
Old 06-09-2009, 11:51 PM   #13
tel
tel's Avatar
Liked 111 Times on 106 Posts
Originally Posted by Jeff02
I have been using 600 grit wet and dry sand paper with a lot of elbow grease and water.
I guess I should say I start with a file, then go to sand paper starting with 300 grit and working up to 600.
BTW I have just used the 300, I save the 600 until the very last.
Try some light oil with the w&d - makes a difference!
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 06-11-2009, 11:51 PM   #14
Jeff02
Likes Given: 5
Last night!
Jeff02 is offline
Old 06-12-2009, 10:53 AM   #15
deverett
deverett
Liked 184 Times on 140 Posts
That's a neat little oil cup. Did you use a form tool to shape it?
If you did, would you mind giving us all a blow-by-blow account of how you made the tool.
Thanks,
The Emerald Isle
deverett is offline
Old 06-12-2009, 09:57 PM   #16
Jeff02
Likes Given: 5
Sorry, but the oil cups are from PM Research. There is how ever an article in Issue 18 of Model Engine Builder on how to make them.
http://www.pmresearchinc.com/store/home.php?cat=23
Jeff02 is offline
Old 07-27-2010, 01:29 AM   #17
Jeff02
Likes Given: 5
Finishing up on some old projects.
Jeff02 is offline
Old 07-27-2010, 01:57 AM   #18
steamer
Liked 105 Times on 101 Posts
Oh I do like the red....much better than the green...
steamer is offline
Old 07-28-2010, 02:52 AM   #19
dparker
Liked 14 Times on 13 Posts
Jeff02:
That looks so nice it makes me want to build that model also, except being on disability and married now the kit prices tend to scare me towards bar stock type plans . Many years ago I built the 10V and it is a real good runner and catches everybody's attention when they see it running in my basement shop. I thought when I built it I wanted to run it on steam but the thought of building a safe boiler back in the 1970's scared me enough that I just run it with my air compressor.
Good work-------don
Hammer to shape, shim to fit and weld all over.* A little paint covers a multitude of sins.
dparker is offline
Old 07-28-2010, 03:01 AM   #20
Troutsqueezer
Troutsqueezer's Avatar
Liked 32 Times on 51 Posts
Very nice, Jeff.
I've been trying to think of a way to make engines look like they were cast but without actually casting them. Haven't gotten there yet.
I plan on doing some rounded edges, which will help a little.
-Trout
-Dennis-
Once you see the bandwagon, it's too late.
Troutsqueezer is offline
Plans for Stuart 10h drileyeng General Engine Discussion 1 08-23-2010 05:55 PM
Stuart 10V First Timer kartwood A Work In Progress 14 06-11-2009 10:31 PM
Need Stuart No. 4 Help Please! chiliviking General Engine Discussion 16 08-29-2008 12:10 PM
Stuart No.4 chiliviking Engines From Castings 3 06-24-2008 05:45 PM
PMR 1-BI vs Stuart 10H Tin Falcon Engines From Castings 1 09-02-2007 02:14 AM
