Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > General Engine Discussion > How do you unstick a stuck morse taper in an X2 mill?
Old 05-20-2009, 02:58 PM   #1
tmuir
Liked 32 Times on 32 Posts
Default How do you unstick a stuck morse taper in an X2 mill?
I tried to remove my er32 chuck tonight but I couldn't, the Morse taper is stuck in well and truly.
I tried undoing the retaining bolt a couple of mm and tapping it with a rubber mallet but had no joy.
Tried locking the spindle and fitted a large spanner to the chuck and attempted to turn it and pull down with no luck.
I actually don't really need to remove it at the moment but I may some day so any tips to get it out would be great.
thanks
tmuir is offline
Old 05-20-2009, 04:14 PM   #2
dwentz
Liked 6 Times on 6 Posts
Default Re: How do you unstick a stuck morse taper in an X2 mill?
Do not try to twist it, you could damage the mating surface. Support the bottom of the mill with something, I have just set it down on 123 blocks or something like that, and use a metal hammer on the drawbar. It should come out with that. The rubber mallet does not transfer enough force. A few small blows are better than one large one. Once you get it out check the surfaces, and see of you had a chip get in. I wipe the surfaces down with a little spindle oil from time to time to keep them from sticking.
Dale
Dale in Belleville, IL
dwentz is offline
Old 05-20-2009, 06:00 PM   #3
PhillyVa
Liked 8 Times on 8 Posts
A brass punch or hammer is what I would use first to insure that you don't any damage.
Philly
Half a brain cell is better than none! Almost chemoed to death
PhillyVa is offline
Old 05-20-2009, 07:26 PM   #4
Jasonb
Jasonb's Avatar
Liked 423 Times on 265 Posts
Likes Given: 18
I use the copper end of a copper/hide mallet on the draw bar of my X3.
Try removing it after the machine has been running a while, it may just warm up teh spindle a touch to make it expand slightly.
Jason
Jasonb is offline
Old 05-21-2009, 12:00 AM   #5
bentprop
Liked 17 Times on 17 Posts
This may seem elementary,but I don't know how much experience you have with your mill.
Unscrew the drawbar a couple of turns,then tap it with a hammer.This should loosen the taper enough to unscrew the drawbar by hand,and remove your tooling.
Maybe teaching you to suck eggs,but I had this vision of a fellow knocking the bejasus out of the drawbar,and getting nowhere.
Hans.
bentprop is offline
Old 05-21-2009, 01:07 AM   #6
rake60
rake60's Avatar
Liked 220 Times on 195 Posts
The only X2 with a Morse taper that I am aware of is the Grizzly
machine with a MT#3 taper. The draw bar thread in that machine
has a M12-1.75 thread. If my assumptions are correct, I would
recommend going to your local hardware store to purchase a long
M12-1.75 bolt. Screw it into the back side if the ER32 chuck until it
bottoms out then back it off two full turns.
After doing that, give the head of that bolt progressively sharper
raps with a steel hammer. I think you'll be surprised by how easily
it will let go by that method.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 05-21-2009, 08:00 AM   #7
tmuir
Thats exactly what I was doing but was getting nowhere with the method.
I remember someone showing their lead hammer they made.
I've got several kg of lead I might make myself one of those at some point but will need to buy an appropriate face mask first.
Here we go again, buy a tool to make a tool to fix a tool so I can finish making another tool.
tmuir is offline
Old 05-21-2009, 11:12 AM   #8
gilessim
Liked 12 Times on 12 Posts
I know this may sound silly but I have the same mill as yours and have had similar problems, I use a plastic faced hammer and sometimes I have to belt it really hard,up until now it has always eventually come out!, as dwentz says ,don't twist it but when you put it back ,a tiny smear of oil doesn't stop it sticking but helps a lot to get it out again!, also try taking the draw bar completely out and squirt some WD40 in there and leave it for a while, then try again!
Giles
gilessim is offline
Old 05-21-2009, 12:03 PM   #9
bob ward
Liked 19 Times on 19 Posts
Is a an improvised puller feasible?
I'm thinking 2 metal plates, one bears on top of the loosened draw bar, the other across the quill area, and 2 lengths of threaded rod to tie them together
bob ward is offline
Old 05-21-2009, 01:57 PM   #10
Andrew_D
Liked 3 Times on 3 Posts
Rick
For reference... In Canada, Princess Auto sells the X2 with an MT3 spindle as well, even though their catalog states it is R8.
The draw bar thread is not machine specific though, since it only passes through the machine. It's the accessory (end mill holder, collet, drill chuck, etc.) that determines the thread. I have accessories that use 3/8" draw bars and others that use M10 draw bars.
But, getting back on topic... On my X2, I loosen the draw bar a couple of turns to start. Now if the table is clear, I lower the head onto "something" to support the head. Usually though, there is a setup on the table and I'm changing cutters mid-project. In this case, I make sure to tighten the lock on the Z-axis. Now give a few light-medium taps. As mentioned before, this is better than a big whack. I use a small 4 oz. hammer for this. It's small enough to remind myself not to swing it to hard. This has always worked for me.
Every once in a while, I'll rub the inside of the spindle taper with an oily rag to clear out any possible chips. Just remember to dry it off before using - you don't want oil in there. All collets, chucks, etc also get a quick rub with an oily cloth and a dry down before being installed.
Andrew
Andrew_D is offline
WTB Morse Taper 4.5 to Morse Taper 3 Adapter dwentz Buy / Sell / Trade / eBay 11 02-12-2016 07:26 PM
How to clamp a morse taper? Sshire General Engine Discussion 5 08-23-2011 12:18 PM
Morse taper MT2 mimoletti General Engine Discussion 9 03-16-2011 01:03 PM
Morse Taper with tang SAM in LA General Engine Discussion 16 08-05-2010 08:01 PM
For Sale: Morse Taper #3 3/8" collet and 3/8" End mill holder. Twmaster Buy / Sell / Trade / eBay 1 11-26-2009 01:51 AM
