Home Model Engine Machinist > The Tools and Tips > Tools > dovetail cutter speeds
Old 05-08-2009, 07:07 PM   #1
mnewsholme
Default dovetail cutter speeds
Im cutting some dovetails on a hemingway kits ball turning tool. Whats a typical speed to run the cutter at? at widest diameter cutter is about 1" diameter. do I calculate cutter speed for tip diameter or for average diameter? I'm cutting en1a steel on an x3 mill. Also what sort of depth of cut should I be using. I've already done first two dovetails using 400-600rpm and depths of cut between 0.2 and 0.3mm. Went ok and gave a decent finish but there was a lot of vibration. not sure whether I need to change cutter speed or depth of cut or both. Any suggestions please
matt
mnewsholme is offline
Old 05-08-2009, 08:10 PM   #2
arnoldb
arnoldb's Avatar
Liked 93 Times on 178 Posts
Default Re: dovetail cutter speeds
Matt, were you using any form of lubrication ? - If you use a lubricant, you should be able to run at a higher spindle speed - also, your cutter will last longer. It also depends on the rate you feed at.
I know this is not much help - I'm sure one of our more experienced members will be able to provide a better answer
Regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Old 05-09-2009, 09:16 AM   #3
scoop
Liked 3 Times on 3 Posts
As dovetail cutters are normally straight toothed they cut with a very harsh intermittent action and hence calculating a speed/feed combination based on normal helical type milling cutters can give unsuitable results.For this reason I always use my eyes and ears to determine the speeds and feeds for cutters.As you have already mentioned a lot of vibration It would seem that although the finish is good the cutter speed/feed is probably too high for your setup.Calculating a cutting speed for any form of tool is only a guide for people who require a fast removal of metal as if in a production shop,which normally means that large rigid machines with good fixturing are being used.The life of the tooling is also expected to be much reduced from its maximum.Therefore I always try to make any machining I do to be a be a steady,pleasant,easy on the nerves operation that does not over stress either the parts being cut or the machine tool doing the cutting.So to sum up,if in doubt start with a slow spindle speed and just take a small cut and see what happens.If it all goes well then just up it a little,your machine will tell you when to ease up by complaining(a bit like wives really).Most cutting operations will not suffer by being done at a slower rate than is possible and the tool will still be good to use again after you are done.
I also find that on some dovetail cutters that they have too many teeth on them which can cause chatter and vibration.This I cure by grinding off alternate teeth on the cutter to let the tool cut more smoothly.A bit drastic I know but it does work,but only do it as a last resort.
The above lecture is only the procedure that I use and is by no means to be thought of as the correct method as I am sure that other people have better methods,if it is of any use to you then good luck.
best regards Steve C.
non plaudite-modo pecuniam jacite.
scoop is offline
Old 05-11-2009, 03:20 AM   #4
cfellows
cfellows's Avatar
Liked 762 Times on 489 Posts
Likes Given: 3
I've cut a few dovetail slides in cast iron and in steel. I know this might not be best practice in machining, but I've found that the slower the spindle speed the better. I usually run my dovetail cutter on the slowest spindle speed. Just means you have to feed the work slower.
Chuck
cfellows is offline
45 degree dovetail cutter, is there such a thing as a 45 degree diamond insert? playerofpawns General Engine Discussion 5 03-22-2011 04:40 AM
Spherical Cutter (Ball Cutter) to fit my QCTP BenPeake Tools 0 08-24-2010 11:38 PM
Dovetail cutter feeds and speeds? Twmaster General Engine Discussion 1 04-21-2010 08:49 AM
Dovetail cutting? Lakc General Engine Discussion 14 09-16-2009 05:50 PM
Homemade dovetail cutter. DICKEYBIRD Tools 10 06-29-2009 02:24 PM
