Project of the Month built by edholly
Home Model Engine Machinist > Building Them > General Engine Discussion > Pultra lathe
Old 04-21-2009, 10:16 AM   #1
abby
Liked 70 Times on 55 Posts
Likes Given: 8
Default Pultra lathe
Hi all , I have just added to my machining capability by purchasing a used Pultra 17/50 micro lathe.
I bought it on the basis of photographs and having received the machine , although I am happy with it , I find that the compound slide does not fit the bed , even though it looks identical to the correct part.
Does anyone have a similar machine ? at least one member does if they are still active.
Could anyone post a picture of the under-side of the slide so that I can see how it should locate onto the bed , I know it is secured with a large thumb-screw.
thanks in anticipation
Abby.
abby is offline
Old 04-21-2009, 12:13 PM   #2
Jasonb
Jasonb's Avatar
Liked 409 Times on 253 Posts
Likes Given: 18
Default Re: Pultra lathe
Don't know if these will help
http://www.lathes.co.uk/pultra/page16.html
Jason
Jasonb is offline
Old 04-21-2009, 01:38 PM   #3
abby
Likes Given: 8
Thanks Jason , lathes.co.uk is always my first port o'call for info but nothing there , even Tony ,the site owner,could not help. I have several feelers out so I am sure something will turn up.
abby is offline
Old 04-21-2009, 07:26 PM   #4
old-biker-uk
old-biker-uk's Avatar
Liked 16 Times on 15 Posts
Here's the underside of mine, tho' I'm not sure it'll help much, now I look at it it appears that one of the locating pieces is not OEM, made of black bar, no dowel pins & slotted screw.
Anyway FWIW
Mark
What you say & what people hear are not always the same thing
old-biker-uk is offline
Old 04-21-2009, 09:32 PM   #5
Hal
Liked 10 Times on 10 Posts
Mark
Pretty fancy wood blocks.
Most of my wooden block are chunks of 2" x 4"
What neat stuff have you been working on lately
Hal
Hal is offline
Old 04-21-2009, 10:13 PM   #6
old-biker-uk
Hal
They are first attempts at Rose turning & were handy for propping up the slide!
My latest is to try and learn how to hand engrave, to that end I made an engraver's ball vice. (details here.)
I was working on the principle that if I had all the tools it would be easy - how wrong can you be? All I have done so far is to ruin some nicely polished metal and poke several triangular holes in my hand
Mark
Old 04-21-2009, 10:37 PM   #7
abby
Likes Given: 8
Thanks biker thats exactly what I needed , the piece of steel nearer the handle has 2 dowel pins , mine is missing the second piece that presumably is adjusted using the screw , could you post a picure of the tool post ? does it only use 2 fixings ? looked at your web-site , workshop looks brilliant , I have never seen such diverse arts in one place.
abby is offline
Old 04-21-2009, 11:08 PM   #8
Hal
Mark
I checked out your web site.
VERY impressive work. Thanks for sharing and showing what can be done.
For thoses who haven't looked at "old-biker-uk" site you need to check it out, you'll be impressed!!!!!!!!!!!
Hal
Hal is offline
Old 04-22-2009, 08:20 AM   #9
old-biker-uk
Abby-
Here's the tool post on mine,
just a simple lantern type where the tool height is adjusted by the knurled ring on the threaded cylinder & locked by the top screw as in the pic.
I will make a 4-way post one of these days - another 'round toit' job on the list.
Mark
Old 06-21-2013, 11:51 PM   #10
platelayer
Liked 1 Times on 1 Posts
Default
Hello Abby,
I have 3 Pultra lathes, and I can definately say that you should only have one locating piece underneath. The idea is that when you tighten the clamp one keeps the locating strip in contact with the side of the bed, and the underside of the compound slide is in contact with the top surface of the bed. Your compound slide appears to be not seated properly on the bed, and I suggest you remove the second home made strip before damage ensues.
Richard.
platelayer is offline
$1050 LOGAN LATHE METAL LATHE CONVENTIONALMODEL 7515 GOOFY063 Buy / Sell / Trade / eBay 0 03-09-2012 09:57 PM
Small Lathe, Beginers Lathe Sieg C1 geoff The Shop 0 03-07-2012 05:04 PM
