Project of the Month built by Ghosty
Home Model Engine Machinist > The Tools and Tips > Tools > Home Made Surface Grinder Plans
Old 10-25-2007, 06:29 PM   #1
rake60
rake60's Avatar
Liked 216 Times on 192 Posts
Default Home Made Surface Grinder Plans
I suppose a home made grinder of any type is only as safe as it's
construction allows it to be. In other words, I should probably leave this
one alone! LOL
However it looks like a decent idea for building an inexpensive mini
surface grinder. The plans are at: http://www.dm.net/~lughaid/vest.htm
The pictures on the web page are too small to be of much use, but if you
save them to your computer, they can be enlarged to show the detail.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 10-25-2007, 06:38 PM   #2
tattoomike68
Liked 25 Times on 21 Posts
Likes Given: 8
I like the little shaper shown here.
http://www.dm.net/~lughaid/barry.htm
tattoomike68 is offline
Old 10-25-2007, 08:37 PM   #3
J. Tranter
Liked 6 Times on 6 Posts
I think it was Home Shop Machinist had plans to build a small surfice grinder.
J. Tranter is offline
Old 10-25-2007, 10:51 PM   #4
macona
Liked 5 Times on 4 Posts
I dont think I would waste my time. Surface grinders are all about accuracy and the chances of building a decent one are not so great.
Then there is the spindle... You wont get a decent finish unless you use the right bearings and those can be several hundred bucks a piece.
A well outfitted used surface grinder can be found for pretty cheap. $1000 or less. You will end up spending that much buying parts alone to build one.
macona is offline
what home made machines have you made? New_Guy Tools 36 12-13-2012 03:47 PM
Surface Grinder MachineTom General Engine Discussion 0 04-06-2011 01:04 AM
any plans for home made dro extension readouts nurgle Tips and Tricks 7 04-05-2009 01:06 PM
HSM Surface Grinder Brass_Machine Tools 6 01-16-2008 11:15 PM
surface grinder uses georgeseal General Engine Discussion 13 01-15-2008 04:04 PM
