Project of the Month built by driller1432
Home Model Engine Machinist > Showing Them > A Work In Progress > Building Rudy's Steam Tractor
Old 03-06-2009, 01:41 AM   #1
4156df
Liked 27 Times on 27 Posts
Default Building Rudy's Steam Tractor
I’ve started a build of Rudy Kouhoupt’s Model Steam Tractor. The tractor is 3/4” scale and is loosely based on the J.I. Case steam engines. To quote Rudy, “…it is not an exact scale replica. Some of the parts have been arranged to improve the ease of construction of the model or to insure its dependable operation.” The part about “ease of construction” was strangely appealing.
I purchased a set of plans that have been recently published by Village Press. This will be the first engine I intend to operate with steam, so having plans to work from should be a good thing. My plan is to build the rear wheels first (they look like the hardest part to me) and if that goes well then proceed with the rest of the engine.
Interestingly, Rudy’s original engine, which he built for his Popular Mechanics article (Feb. 1971), is at the Craftsmanship Museum in Vista, CA. The museum is about 40 miles from me. I expect to make several trips there as this build goes along. Here’s a photo I took of it.
The rear wheels are supposed to be brass, 4 1/2” OD & 4 1/4” ID, fabricated from a cast-brass pipe adapter. Good luck finding one. The closest I could come in brass was a threaded specialty connector for $148 and I would need two!! I’m barely started and I have to deviate from the plans. However, I guess being able to do that is part of the beauty of model engineering and of not building an exact replica. Anyway, I ended up selecting a 4” copper sweat fitting that is 4.350 OD and 4.136 ID. Close enough. Thirty-eight bucks, but I get two wheels from one fitting. The other raw materials are 1” brass rod for the hub and 3/32” rod for the spokes.
For the rims, I cut two 1 1/2" wide rings from the coupling.
Since I’ve only got a 6” lathe, I had to get creative to face the edges (Rudy says this can be done with a file!?).
Next step…spoke holes. There are 24 spokes per wheel, twelve to a side, staggered so the two sides are off-set. To drill the holes I layed out the spoke pattern and glued it to a wood fixture (I’m a big fan of wood for one-time fixtures). The way this one works is the black lines represent one side’s spokes and the red the other. Line up the reference line on the inside of the rim with either a red or black line, drill, move the reference to the next line of the same color and so on. Then reverse the rim and drill the other side using the opposite color lines. I first spot drilled and then thru drilled.
Drilling the copper didn’t go so well until I got some info from helpful people on this board (see thread on “Drilling Copper). The trick is slower speed (1000 rpm or slower) and coolant (preferably tallow).
Each wheel has 24 “grouters” fastened with rivets. They’re fastened such that two of them fall between each spoke. Rudy’s suggestion was to drill the holes on one side of the rim and then use the grouter as a guide to line drill the other side during assembly.
The rivets will be 1/16”, but I used a #51 drill which makes it just a little easier to get the rivets in. I used the same drill fixture as for the spoke holes, but used a new reference line set off the proper distance from the original reference. Then I aligned the new mark with each of the spoke lines, spot drilled and then thru drilled.
After the holes were all drilled, I deburred the inside using a 3” diameter scotchbrite wheel in the drill press.
Next thing to tackle are the hubs. So far so good.
Dennis
P.S. I tried smaller photos for this post. Are these the right size or should I go back to larger ones??
Southern California, USA
4156df is offline
cardinalis1 Likes This
Old 03-06-2009, 02:14 AM   #2
rleete
Liked 36 Times on 36 Posts
Likes Given: 40
Default Re: Building Rudy's Steam Tractor
Nice, informative post. I like the simple setups.
Pics are just fine.
Easily distracted by shiny things
rleete is offline
Old 03-06-2009, 02:28 AM   #3
steamer
Liked 104 Times on 100 Posts
Cool...always wanted to watch that build.
YES the pics are good!
Keep them coming......
steamer is offline
Old 03-06-2009, 02:36 AM   #4
Maryak
Maryak's Avatar
Liked 140 Times on 125 Posts
Looking good. Now I know why the question on drilling copper.
Best Regards
Its hard to remember your objective was to drain the swamp when your up to your neck in alligators.Если вы у Тетушки были яйца, она была бы Дядюшкой
Maryak is offline
Old 03-09-2009, 05:44 AM   #5
4156df
The hubs are a basic turning operation. They’re drilled 0.250” and there’s a 6-32 set screw in the center of the hub for securing the wheel to the axle.
The spoke holes are drilled to match the holes in the rims with 12 spokes per side staggered so the two sides are offset. I used a locating method similar to the one used for drilling the rims. The fixture is positioned on the drill press for the first side. Twelve holes are drilled using the black lines for reference, then the fixture is re-positioned for the second side and the holes are drilled using the red lines for reference. Holes were spotted with a spotting drill and then drilled. The hub is 1.5” long and 1” diameter. Spoke holes are 3/32”.
Wheel assembly tomorrow.
Dennis
4156df is offline
Old 03-09-2009, 11:11 AM   #6
ksouers
Liked 55 Times on 55 Posts
Dennis,
Following along.
Very creative indexing solution.
Kevin
Kevin
I make things.
ksouers is offline
Old 03-09-2009, 03:40 PM   #7
cfellows
cfellows's Avatar
Liked 759 Times on 487 Posts
Likes Given: 3
Nice looking build, Dennis! I'll be watching the progress.
Chuck
cfellows is offline
Old 03-09-2009, 05:26 PM   #8
DougLanum
Liked 5 Times on 5 Posts
[img]http://Dennis,
Nice Job.
This tractor was my first project about 30 years ago.
Mine has a lot of miles on it. I'd take it to an engine show and the kids or "Crawling engineers" come out of the woodwork to steer.
I made my wheels from steel tube, the cross head design was made closer to what Case manufactured, and the gearing was reduced so the tractor moved at a more realistic speed.
Please keep sending updates and if I can answer any questions don't hesitate to ask.
I'll try to attach a photo.
Doug
[img][/img]
DougLanum is offline
Old 03-09-2009, 05:30 PM   #9
DougLanum
My Message got lost, but the photos got sent ??
Nice job Dennis, please keep us updated. I built one of the tractors as my first project about 30 years ago. It has many miles on it.
I take it to an engine show and the kids "crawling engineers" come out of the woodwork to steer it.
I used steel pipe for my wheels, changed the cross head design to match the Case design more and reduced the gear ratio so the tractor moved at a more realistic speed.
Don't hesitate to ask question if you need help
Doug
Old 03-09-2009, 06:29 PM   #10
4156df
Doug,
Nice job on your engine. I've been hoping a few builders would pop up as I go along. I know I'm going to have questions, particlarly as I get closer to running it. The plans have absolutely no info on them about operation.
Dennis
4156df is offline
Building one of Rudy's steamers Deanofid A Work In Progress 333 06-16-2016 10:58 AM
Steam Tractor Harold Lee A Work In Progress 25 02-17-2012 12:36 AM
Pics from Steam & Tractor show in my home town kvom Shows and Events 3 11-14-2010 04:14 PM
steam tractor on craigslist bjo Buy / Sell / Trade / eBay 1 08-25-2010 08:53 PM
Rudy Kouhoupt's Steam tractor Ben_Imbrock General Engine Discussion 2 10-28-2009 01:31 AM
