Home Model Engine Machinist > Showing Them > A Work In Progress > MY Seadog
Old 01-22-2009, 02:35 AM   #1
steamer
Liked 105 Times on 101 Posts
Default MY Seadog
Hi All,
I am in the process of powering up a model tug. To do that I am building a "Seadog" as sold by Scratchdog Motors and as featured in Model Engine builder.
1" bore and stroke 4 cycle of a distinctively "Westbury" style.
The engine will be built for RC, and I would like to finish her out in traditional early 1900's flare....bling if you must.
I intend to put a forward/reverse transmission and a centrifical clutch for operation.
There are some changes from the original, some for "use and abuse" sake and some because as the president ( small p ) of my own engine manufacturing company, I get to choose the "Bling"
This is my first IC engine.....but not my first engine....if you know what I mean.
So here's where we are:
Boring and facing the crankcase
Timing case started
Timing case on the block
Setting up to make custom bolts
Filing rest set up for Hex heads on bolts
Hex Heads complete...about 2 minutes per bolt.
boring the timing gear cobore
boring the cam gear cobore
first operation on timing gear cover casting.
steamer is offline
Old 01-22-2009, 02:39 AM   #2
steamer
Default Re: MY Seadog
Second op on cover
Cam gear in place on locating button and positioned for proper mesh.
Camshaft bore boring fixture with cover in place ready for mounting on the faceplate
steamer is offline
Old 01-22-2009, 02:41 AM   #3
ksouers
Liked 55 Times on 55 Posts
Dave,
That's looking great! How long did it take you to get to this point?
Kevin
Kevin
I make things.
ksouers is offline
Old 01-22-2009, 02:48 AM   #4
steamer
Helping hands.....thanks little girl!
Locating the fixture off the locating button.....next put the cover back on and
Cover bored for outboard bearing and timing cover housing spigot.
Cam tunnel bored.....cover removed first.
steamer is offline
Old 01-22-2009, 02:50 AM   #5
steamer
back crank case cover removed showing 1/4" shaft going thru three ball bearings in three parts.
The cam boring job was a Saturday morning. I would say I have about 30 hours into it so far...with fixtures and such.
There will be a good bit of casting clean up for good looks, but that won't be so bad
The hole where it all happens.....
steamer is offline
Old 01-22-2009, 03:08 AM   #6
steamer
The tumbler transmission
steamer is offline
Old 01-22-2009, 03:22 AM   #7
steamer
Blingspiration
steamer is offline
Old 01-22-2009, 04:05 AM   #8
potman
Liked 3 Times on 3 Posts
Uh Oh ! Another gotta-watch-it-come-to-life.
Thanks Steamer for taking the time to show us your work.
earl...
potman is offline
Old 01-22-2009, 04:24 AM   #9
gmac
Liked 28 Times on 27 Posts
Steamer;
Thanks for the education - I'm the noob around here - there wasn't a photo here I didn't learn something from! Question - the second photo shows what I initially assumed was the equivalent of a milling plate attached to the faceplate; but then I noticed the holes are thru drilled but not threaded. Can you explain the use of this plate? Why are the holes not tapped?
Later photo's show non-drilled plates (fixtures?) used to attach castings to the faceplate - those appear to be methods of jigging that allow later removal from the faceplate and secondary machining operations to be performed without part removal from the jig. Correct?
All this curiosity stems from sitting around waiting for a back ordered copy of "Workholding in the Lathe" by Tubal Cain to arrive.....
Thanks
Garry
British Columbia, Canada
gmac is offline
Old 01-22-2009, 04:27 AM   #10
Maryak
Maryak's Avatar
Liked 141 Times on 126 Posts
Dave,
That's really nice work you are doing.
Some of your mounting techniques are inspirational.
I reckon its going to be one really special engine and tug boat.
Best Regards
Its hard to remember your objective was to drain the swamp when your up to your neck in alligators.Если вы у Тетушки были яйца, она была бы Дядюшкой
Maryak is offline
