Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Metals > Nickel Aluminum Bronze (630)
Old 01-13-2009, 01:02 AM   #1
shred
Liked 34 Times on 34 Posts
Default Nickel Aluminum Bronze (630)
So I lucked into a couple feet of 2.5" dia 630 bronze this afternoon (it had the tiger-striped look of bronze and was cheap, so I snagged it). How bad is it to machine on hobby-size tools (10-12" lathe, bench mill)?The web sites I've been able to find don't say much about machinability, which is usually a bad sign (one said 30% of 360 brass)... I was thinking of making things like flywheels from it if it's not going to be too cantankerous (I passed on a bunch of 304 stainless, remembering some poor reviews here)
shred is offline
Old 01-13-2009, 01:37 AM   #2
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 948 Times on 639 Posts
Likes Given: 8
Default Re: Nickel Aluminum Bronze (630)
I have an el-cheapo 9X20 lathe and i have turned titanium, bronze, stainless, nickle. I would'nt worry about it.
stevehuckss396 is offline
Old 01-13-2009, 03:00 AM   #3
rake60
rake60's Avatar
Liked 220 Times on 195 Posts
630 bronze cuts beautifully for larger parts.
When it gets too thin it becomes a little fragile to work with.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 01-13-2009, 04:28 AM   #4
shred
Rick
Cool, thanks Rick. I guess I'll hang onto it then
At $20 for 18" of 2.125" round bar I figured it was worth a gamble at a Cedge-worthy scrap score
shred is offline
Old 01-13-2009, 10:07 AM   #5
jack404
Liked 10 Times on 10 Posts
like Rick said use WD40 or Kerosene to lube while cutting for nicer finish thats about all i can add
jack
jack404 is offline
Old 01-13-2009, 08:38 PM   #6
Kermit
Guest
Posts: n/a
Typical Uses
Industrial
Hydraulic Bushings for Earth Moving Equipment, Valve Balls, Bushings, Bearings, Heat Exchanger Flanges, Welded Piping Systems, Gears, Pump Parts, Condenser Tube for Power Stations and Desalting Units, Structural Members, Pump Shafts, Aircraft Parts, Valve Guides, Plunger Tips, Valve Seats, Shafting, Cams, Corrosion Resistant Articles, Balls, Heat Exchanger Headers, Tanks
Marine
Ship Propellers, Bolts, Nuts, Pump Parts, Propellers
Plumbing
Faucets
Old 01-13-2009, 09:36 PM   #7
rake60
rake60's Avatar
I had to check the current price today at work.
2" 630 Bronze Rod is listed at $76/Ft
I'd say you found a deal there!
Rick
rake60 is offline
Upgrading to bronze from aluminum Swede Home Foundry & Casting Projects 4 03-30-2012 03:56 PM
Nickel plating deadin General Engine Discussion 6 02-02-2011 03:00 AM
Need Nickel Silver rodbuilder Buy / Sell / Trade / eBay 1 02-10-2010 09:37 PM
plating kits including chrome, gold, nickel, copper, brass and many more. PTsideshow The Break Room 1 05-08-2008 06:27 AM
Electroless (or electric) nickel plating. GeorgeGreek Metals 24 01-29-2008 10:48 PM
