Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > General Engine Discussion > MjN Fabrication
Old 01-03-2009, 04:34 AM   #1
Rustkolector
Liked 85 Times on 40 Posts
Default MjN Fabrication
I have found the ignition supplies from MjN Fabrication to be excellent, but have found it very difficult to do business with the company. They have been non responsive for quite awhile. No response whatsoever to email, and don't answer the phone. Their website is out of date. They have been difficult to contact in the past, but persistance usually paid off. Not so lately. Has anyone been able to do business with them in the last few months? Any suggestions on how to get hold of them?
Jeff
Rustkolector is offline
Old 01-03-2009, 10:32 AM   #2
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 950 Times on 640 Posts
Likes Given: 8
Default Re: MjN Fabrication
I have been having the same problem. The last I heard there have been some major issues in the home that resulted in the guy going back to work full time.
There is another guy selling ignitions. His name is Roy Sholl. He makes ready to go systems for the guys who fly planes. He has an "ignition kit" that consists of the electronics and the coil. Hall sensors are seperate. Catch him at the shows and prices get a little better. His spark plugs are made in china. If you perfer an american made product, Dale Detrich makes the 1/4-32 plugs right here in the USA for the same price. Roy does not carry the distributor cap or rotor. I had to make my own from acrylic.
rsholl@cncengines.com
http://www.cncengines.com/ic.html
http://www.daledetrich.com/spark_plugs.htm
stevehuckss396 is offline
Old 01-03-2009, 11:32 PM   #3
Rustkolector
Thanks for the info on Roy Sholl. He has a few of the things that I need, but not everything.
Jeff
Old 01-03-2009, 11:55 PM   #4
stevehuckss396
Senior Member
Likes Given: 8
Jeff
What else would ya be needin.
Old 01-05-2009, 03:03 AM   #5
Rustkolector
I need a 4 post distributor for a new project.
Jeff
Old 01-05-2009, 10:43 PM   #6
stevehuckss396
Senior Member
Likes Given: 8
I had to make one. I used clear acrylic rod but any insulator that machines well will work.
If you find another source, please post.
spurgear Likes This
Old 01-06-2009, 02:26 AM   #7
Rustkolector
That's a pretty nice looking distributor. I recently received some Bob Shore plans for a 1" dia Hall Effect distributor that Bob had designed. I have never seen any mention on forums of anyone using one. I am not sure how well the Hall sensor would work in that close proximity to the high voltage, but Bob was pretty good at ignition systems so may give that a try.
Jeff
Old 01-06-2009, 02:59 AM   #8
stevehuckss396
Senior Member
Likes Given: 8
Jeff
Well this IS the Bob Shores distributor. The only difference is the cap and rotor. I could send you the drawings for them if you wish. I had to install the screws in the cap and then go back to the lathe and machine the heads off until I had a .005 clearance between the rotor and the screw heads.
Old 01-07-2009, 02:52 AM   #9
Rustkolector
How well does the Hall Effect work compared to points in the distributor? I am assuming it works well, and the high voltage RF interference does not effect it. I am curious, why did you change Bob's design? Yes, I would be interested in your modification drawings. Thanks.
Jeff
Jconner9@twcny.rr.com
Old 01-07-2009, 03:33 AM   #10
stevehuckss396
Senior Member
Likes Given: 8
Jeff
It works well. Bob Shutt has a running example of the Shores Peewee V4 engine on youtube.
I didn't change the design, I just made the cap and rotor.
This test distributor i made for the Bugatti project made good spark. It is different in the fact that it has 1 magnet and a steel vane to block the sensor from the magnet.
spurgear Likes This
x2 bench fabrication. Speedy General Engine Discussion 21 05-14-2012 08:49 PM
Copper Boiler Fabrication sunworksco Boilers 30 03-03-2011 03:32 AM
Curved slot using only a lathe and fabrication SignalFailure Tips and Tricks 7 11-03-2010 06:58 AM
