Home Model Engine Machinist > Building Them > General Engine Discussion > Imperial screwcutting on Metric lathe
Old 12-15-2008, 09:45 PM   #1
chillybilly
Liked 10 Times on 10 Posts
Default Imperial screwcutting on Metric lathe
Hi ,
Need to cut a Imperial thread on my metric lathe ,is it as simple as finding the pitch of the imperial thred and setting the machine to that I have a Harrison 11" with the 3 lever gearbox ,and also a pile of changewheels ,i still dont fully understand how to read the chart of pitch rates yet but i am on the case !!!Any help greatly appreciated .
"It takes the same amount ofÂ* time to make a lemon, as it does to make something that works" John Britten
chillybilly is offline
Old 12-15-2008, 10:00 PM   #2
John S
Liked 72 Times on 60 Posts
Likes Given: 8
Default Re: Imperial screwcutting on Metric lathe
Picture of the thread chart please ?
John Stevenson [ was JohnS the 3rd.]
Nottingham, England
John S is offline
Old 12-15-2008, 10:12 PM   #3
chillybilly
Will go and get one and suss out how to get it on here .........
I am in Nottingham too ...Small world..........
Old 12-15-2008, 10:38 PM   #4
chillybilly
Attached pic best as poss ...
On the left is the posn of levers A and B on the bottom is position of lever c .
Each square of the chart has two numbers ,one at the top of the square and one at the bottom ,i belive these to be the pitch.....on some of the squares there is a 3rd number in bold in the centre ,i believe this to be the feed rate .the plate is double sided ,one for fine and one for course ,and the necessary changewheel arrangenment to get this ....sorry about the crap pic
Old 12-15-2008, 10:45 PM   #5
John S
Likes Given: 8
Yes you are right it's a crap picture
Looks like it has a Norton type screwcutting box.
http://www.lathes.co.uk/harrison/page19.html
Is this it ?
Nottingham, England
John S is offline
Old 12-15-2008, 10:56 PM   #6
chillybilly
Thats the one ,mine is the 11 inch with the rounded head ,all the same as a 140 failing that ..........My nipper has had hold of the camera and killed it so it seems so was reduced to a mobile phone ................grim
Old 12-15-2008, 11:10 PM   #7
John S
Likes Given: 8
In the pile of gears do you have one with 127 teeth?
Nottingham, England
John S is offline
Old 12-15-2008, 11:16 PM   #8
chillybilly
Yep pretty sure that one is there,will check.......is that a key player?
Just looked up about the Jones 250 engine ,what a fella ,didnt realise the jet ski came from these parts either .Have you ever seen the film of john Britten and his bike
Old 12-15-2008, 11:27 PM   #9
chillybilly
Wrong again ,biggest i have is a 120 tooth next down is 100 tooth then all the rest must be smaller ,there is a good few however !!!!!!!!!! hey ho
Old 12-15-2008, 11:41 PM   #10
John S
Likes Given: 8
Look inside the end cover, there maybe an imperial conversion chart there.
If not I have a friend with a Metric 140 that i can scrounge a copy of the chart off.
Nottingham, England
John S is offline
Metric Thread On A Imperial Lathe doubleboost Tips and Tricks 1 01-28-2011 12:11 PM
Imperial thread cutting on a metric lathe bucketboy General Engine Discussion 4 05-18-2010 10:04 AM
Metric or imperial? bucketboy Tools 13 03-03-2010 10:28 PM
Metric or Imperial MattMoore General Engine Discussion 45 04-25-2008 10:49 PM
Metric to Imperial rake60 The Break Room 2 11-10-2007 11:31 PM
