Home Model Engine Machinist > Building Them > General Engine Discussion > Turning Between Centres
Old 11-08-2008, 09:33 PM   #1
Maryak
Maryak's Avatar
Liked 141 Times on 126 Posts
Default Turning Between Centres
Hi Guys,
I've noticed in a couple of posts that when turning between centres, the soft centre is held in a 3 jaw chuck.
I've not seen it done that way before.
Please, why is it done this way
Thanks
Its hard to remember your objective was to drain the swamp when your up to your neck in alligators.Если вы у Тетушки были яйца, она была бы Дядюшкой
Maryak is offline
Old 11-08-2008, 10:14 PM   #2
kvom
kvom's Avatar
Liked 614 Times on 485 Posts
Likes Given: 287
Default Re: Turning Between Centres
I think you saw my posts.
The shop doesn't have the slotted dog plates handy AFAIK. The jaws work just fine given that the leg of the dog is long enough for contact.
kvom is offline
Old 11-08-2008, 10:40 PM   #3
Brian Rupnow
Liked 4125 Times on 3271 Posts
Likes Given: 37
Maryak--The biggest reason is that it saves me the agravation of having to remove the chuck and install the faceplate.
Brian Rupnow
Brian Rupnow is offline
Old 11-08-2008, 10:54 PM   #4
Maryak
Maryak's Avatar
kvom, Brian.
Thanks for helping me out, I understand much better now
Maryak is offline
Old 11-08-2008, 10:58 PM   #5
Mcgyver
Liked 15 Times on 14 Posts
that's the way machinists do it, because its quick and accurate. skim any piece of steel to put a 60 degree cone on it and there's zero run out
Mcgyver is offline
Old 11-08-2008, 11:07 PM   #6
Maryak
Maryak's Avatar
Mcgyver,
Makes a lot of sense, funny how you can't see the wood for the trees sometimes
Maryak is offline
Old 11-08-2008, 11:30 PM   #7
Mcgyver
on our little lathes it might not matter that much, but i can see why you'd want to avoid changing tool on a larger lathe......but I like to pretend I'm a machinist so that's how i do it
Mcgyver is offline
Old 11-08-2008, 11:38 PM   #8
John S
Liked 72 Times on 60 Posts
Likes Given: 8
Because if you mount the centre in the headstock as is standard on some gap bed lathe you finish up with the saddle over the gap and unsupported.
Also you often have run out of bed length to get a bed stop on and still reach the end of the work.
Using a quickly trued up centre in the chuck will have the effect of moving the job down the bed a bit.
As others have mentioned it's also for the inherently idle
John Stevenson [ was JohnS the 3rd.]
Nottingham, England
John S is offline
Old 11-09-2008, 02:08 AM   #9
Maryak
Maryak's Avatar
Thanks Guys, for all the good reasons for the 3 jaw chuck approach.
Filed away in my "I must remember that" box.
Best Regards
Maryak is offline
Old 11-09-2008, 12:58 PM   #10
Dhow Nunda wallah
Liked 2 Times on 2 Posts
Maryak, I've taken a similar approach myself.
Chuck up a bit of steel and put a point on it, then weld a "dog" on the end of the workpiece which will engage one of the chuck jaws. This allows you to turn all the way down the piece.
The dog is, of course cut/ground off after turning.
I may be a lazy bastard, but I'm good at it
Dhow Nunda wallah is offline
Right Facing and Turning, also Clockwise Turning? Antman General Engine Discussion 6 08-28-2011 10:20 PM
Turning in the Mill doubletop Tools 12 01-09-2011 12:20 AM
Drilling centres in long bar without a fixed steady. Gauge3 Tips and Tricks 5 10-07-2010 12:54 AM
How to measure hole when boring between centres? SignalFailure General Engine Discussion 26 12-15-2009 09:39 PM
Live centres SignalFailure General Engine Discussion 11 05-15-2008 10:01 PM
