Home Model Engine Machinist > The Tools and Tips > Tools > Box Tool aka Small diameter turning tool
Old 10-16-2008, 12:50 PM   #1
DickDastardly40
DickDastardly40's Avatar
Liked 12 Times on 12 Posts
Default Box Tool aka Small diameter turning tool
On another thread, Cedge asked Tel to show details of a tool for turning small diameters. As I am at a 'loose end' at work I thought I would submit a link to one I've seeen for sale by one of the 'usual supect' UK ME suppliers:
http://www.chronos.ltd.uk/cgi-local/...10_2e_2e_2e_2e
No affiliation with seller but have bought several items from them over the years.
Hope this is of help to someone
Al
Life should not be a journey to the grave with the intention of arriving safely in a well preserved body, but rather a broadside skid in, thoroughly used up, totally worn out and loudly proclaiming 'Wow, What a Ride!'
DickDastardly40 is offline
Old 10-16-2008, 01:09 PM   #2
Twinsquirrel
Twinsquirrel's Avatar
Liked 6 Times on 6 Posts
Default Re: Box Tool aka Small diameter turning tool
Hey Al,
I get a cookie error when I click on your link, is this the tool you mean?
If you need to find the listing at chrono the tools reference number is xc10
David
Twinsquirrel is offline
Old 10-16-2008, 01:22 PM   #3
DickDastardly40
Dave,
The link works for me, (I did check before posting too). Regret I can't see your picture due to work IT restrictions but the XC10 reference is correct; putting SDTT into the chronos site seach brings it out too.
Thanks for pointing out the potential error to others.
Al
Old 10-16-2008, 03:39 PM   #4
BobWarfield
BobWarfield's Avatar
Liked 33 Times on 33 Posts
Box tools can be made or bought. Think of a follower rest built into the toolholder, or in some cases just a special purpose follower.
Here is a Swiss lathe box tool:
Two rollers to support the work. Note that you have to make your cut in one pass on that one!
Here is one where the rollers are bolted to the saddle:
Frank Ford has a nice one on his site:
And here is another interesting specimen:
You get the idea!
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
BobWarfield is offline
Old 10-16-2008, 06:18 PM   #5
tel
tel's Avatar
Liked 111 Times on 106 Posts
This is my version
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 10-16-2008, 07:03 PM   #6
CrewCab
Liked 32 Times on 32 Posts
Tel ............ ................ excellent, I take it you use different size bushes depending on the required size of the "end product" ......... tell the 'ed Wombat you deserve a raise mate
CC
CrewCab is offline
Old 10-16-2008, 07:26 PM   #7
tel
tel's Avatar
Thanks mate!
Yes, the size of the stock dictates the bush size required. The only restriction is that you have to be able to make the reduction in one pass. Very handy for making small screws & rivets tho'.
In passing, for small stuff like this I usually use brazing rods as stock, available in a range of sizes, in manganese and tobin bronze and cheaper by far than the 'usual suspects'.
Tel
tel is offline
Old 10-16-2008, 07:56 PM   #8
CrewCab
Actually that's wrong isn't it ........... the bush is dictated by the diameter of the material being fed, and as you say you have to reduce it in one pass, so several bushes .......... varying diameters, (in small steps) would be useful ....... it's slowly sinking in Tel
CC
CrewCab is offline
Old 10-16-2008, 08:16 PM   #9
greenie
Guest
Posts: n/a
I can see that you have adapted it from a BOX tool, now how do you part-off the finished bit, when you got that fixed to the cross slide?
If you had made it so that it was fixed/adapted to fit to the tailstock, then the parting-off tool would still be able to be used.
Made up these two little jiggers to fit to a Unimat 3 tailstock, they do the same thing, I use lots of 10 BA and 12 BA bolts, With these in use on the tailstock, then the parting-off tool can still be used. Use the bronze rod as well, it's sure the cheapest way to go.
Old 10-16-2008, 10:43 PM   #10
Cedge
Cedge's Avatar
Liked 60 Times on 59 Posts
Greener
We're talking tiny rod. A pair of side cutters do the job quite well. 1/8 inch Bronze rod is $9.99 for 21 feet in Northern Tools' welding supply area. Picked some up a few weeks back. You're right....very handy to have around.
Thanks Tel and all... thats the tool and its nice to see the variations. I wonder if one could mount a small die right on the tool and turn it straight to threaded rod.
Steve
Cedge is offline
Turning a Small Diameter Antman General Engine Discussion 29 03-05-2012 10:14 PM
Radius turning tool vid kustomkb The Break Room 5 03-04-2011 04:25 AM
Small diameter running down tool deverett Tools 1 09-27-2010 10:56 AM
SRDCN Turning Tool Omnimill Tools 23 03-12-2010 02:42 PM
Turning very small diameter bar mooseman General Engine Discussion 7 09-23-2008 11:44 PM
