Project of the Month built by driller1432
Home Model Engine Machinist > The Tools and Tips > Tools > building a Pulse EDM Machine
Old 08-06-2017, 02:18 PM   #1
canadianhorsepower
canadianhorsepower's Avatar
Liked 295 Times on 235 Posts
Likes Given: 1407
Default building a Pulse EDM Machine
Hi all,
I'm am currently starting a build of a EDM machine
by Benjamin Fleming.
http://www.homebuiltedmmachines.com/
that's the link. just wondering if it's ok for me to post the progress and if peoples are interested in it
thanks
Luc
"if you dont stand for something
you will fall for everything"
canadianhorsepower is offline
Old 08-06-2017, 03:30 PM   #2
SilverSanJuan
Liked 123 Times on 70 Posts
Likes Given: 169
Default
I'm certainly interested. Seems like a good topic for the Tools area.
SilverSanJuan is offline
canadianhorsepower Likes This
Old 08-06-2017, 03:59 PM   #3
kadora
kadora's Avatar
Liked 284 Times on 112 Posts
Likes Given: 500
Default
Hello
I have built simple EDF machine for one of my previous project.
It worked quite nice . I used carbon electrode and sparked material
under distilled water.
I did hexagonal holes to the very hard 2 mm thick steel.
From that time machine waits on the shelf for a new project.
kadora is offline
Old 08-06-2017, 04:44 PM   #4
kvom
kvom's Avatar
Liked 605 Times on 483 Posts
Likes Given: 275
Default
A while back I read up on EDM. Seems making the electrodes can be a very messy business.
kvom is offline
Old 08-06-2017, 09:23 PM   #5
Buchanan
Buchanan
Buchanan's Avatar
Liked 139 Times on 44 Posts
Likes Given: 372
Default
You can use copper or even silver for electrodes. Any material with good electrical conductivity as well as a high melting point will work as an electrode. Th wear rate varies from material to material and electrode type. i have used old tungsten carbide inserts to spark erode recesses into tool holders. The first one gets quit worn because it removes the bulk of the metal but the second only has to clean up the pocket and you get a perfectly fitting tip. There are free machining copper alloys specialy for edm electrodes that machine better than free cutting mild steel.
Buchanan is offline
Old 08-06-2017, 10:51 PM   #6
nautilus29
Liked 6 Times on 5 Posts
Default
Copper tungsten has good wear rates and machining isn't too bad. Can't wait to watch the project in progress.
nautilus29 is offline
Old 08-06-2017, 11:35 PM   #7
Herbiev
Herbiev's Avatar
Liked 269 Times on 228 Posts
Likes Given: 88
Default
I'll be following with great interest too
Herbie
Hallett cove
South australia
Herbiev is offline
Old 08-07-2017, 05:51 AM   #8
kadora
kadora's Avatar
Likes Given: 500
Default
As i can remember /20 years ago/ my problem was that copper electrode was
often sticked to the sparked material probably because I used water as
EDM medium.
canadianhorsepower prepare for many many experiments with the electrode material , amount of discharge energy and discharge time tuning and so on.
Every kind of electrode needs special tuning.
Just for illustration picture of my simple home made EDM control box.
kadora is offline
Old 08-07-2017, 11:07 AM   #9
kvom
kvom's Avatar
Likes Given: 275
Default
The site I was reading only talked about graphite electrodes, hence my comment about being messy.
kvom is offline
Buchanan Likes This
Old 08-07-2017, 09:24 PM   #10
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 372
Default
Agreed. Kvom, I have machine a fair mount of graphite and will confirm that it is real messy.
Buchanan is offline
20 lb Thurst Pulse Jet Engines. Rocket Man Finished Projects 4 05-21-2014 02:24 PM
Pulse jet engine Dom General Engine Discussion 13 05-26-2013 01:02 PM
milling machine choice, what mill do you have for small engine building oldncrusty General Engine Discussion 16 05-14-2011 02:21 PM
Jan Ridder's Pulse Mobile kustomkb A Work In Progress 62 02-06-2009 02:25 PM
Building a base for a light milling machine Brian Rupnow A Work In Progress 20 08-08-2008 11:31 PM
