Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > Boilers > Cochran Boiler
Old 09-24-2008, 08:09 PM   #1
Florian
Liked 24 Times on 24 Posts
Default Cochran Boiler
Hi Guys
Another piece of work from my shop (which is not yet completed):
I am really fascinated by a type of boiler called "Cochran Boiler":
And i one day decided to build my own:
First parts are being tempered:
I used a round piece of pearwood to make the form for driving: (They were just felling a pear when i started my project and i took a piece of it. I then turned it down to the required diameter.)
That's the tube and also the first smoketube holding shell
And the second shell for the side of the chimney is just being driven:
tempering it with my torch:
Are there enough tubes, or shall i make some more...?
[continues soon]
Florian is offline
Old 09-24-2008, 08:42 PM   #2
Florian
Default Re: Cochran Boiler
Now, there need to be holes in these shells. I decided to make 23 smoke tubes with 6mm outer diameter and 5mm inner diameter.
I first marked the center positions with a scriber, center punched and finally drilled with the center drill:
The next step was to drill the holes up to 6mm.
And now the shell's completed. Well nearly.
I wanted to know ithe boilers capacity and so i estimated it:
The boiler will have in about 200 cm^2 heating surface. This type of boiler has an approximate capacity of 5cm^3. This means it can vaporize 5 cm^3 water per 100cm^2 surface per minute. That makes 4370 cm^3 steam per minute.
I also need the tubes:
and with some of them inserted in the shells
I turned the ends of these tubes with a mandrel on my watchmakers lathe:
This will be the smoke tube unit:
Ist small! (ruler with mm-scale)
Continues soon...
Florian is offline
GWRdriver Likes This
Old 09-24-2008, 08:51 PM   #3
Florian
Hi sorveltaja
Well no, i bought two hemispheres. But i made all the rest. (Not the tube )
While i was waiting for the hemispheres to continue the copper work, i used the time to make a safety valve:
Its body is made from gunmetal and the ball is stainless steel and has 3mm diameter.
The threads to connect it with the boiler are MF 5*0.5 ( 5mm fine metric threads with 0.5 mm pitch)
Florian
Florian is offline
Old 09-24-2008, 09:02 PM   #4
Florian
I then started making the big holes in the main boiler tube:
looks good, doesn't it?
And this will be the firebox:
from the top: (with the smaller hemisphere)
And with the big hemisphere on its top:
After trimming the tube and the big hemisphere, it loks like this:
with smoke tubes:
Now, i started drilling the oval hole for the connection between firebox and returning chamber:
and the shell with the oval hole now: (and the oval piece of tube)
somehow it looks strange...
Well that's it for the moment. I will shurely report any advance..
Florian
Florian is offline
Old 09-24-2008, 09:09 PM   #5
Maryak
Maryak's Avatar
Liked 140 Times on 125 Posts
Great Pictures and a good looking boiler - keep the info coming as when I find some copper I have a boiler to build and will be picking your brains.
Its hard to remember your objective was to drain the swamp when your up to your neck in alligators.Если вы у Тетушки были яйца, она была бы Дядюшкой
Maryak is offline
Old 09-24-2008, 09:27 PM   #6
Florian
Hi Maryak
Well, you might have to travel around half the globe to pick my brain
I live in Switzerland
Florian
Florian is offline
Old 06-08-2009, 08:11 PM   #7
Florian
Hi everyone
Although the board software reminds me to think about writing in that old topic (last post 120 days ago or more), i continue writing about an unfinished piece of work (some call it art )
Well, it has been a long time and i didn't have a loto of time for my hobby but finally i managed to continue with my cochran boiler.
Sorry guys, i didn't make a video of soldering it. I just forgot after more than half a year... It wouldn't even have been so easy to do that but i guess i would have found a way to do it..
Anyway; after the first and the second soldering step i made these two pictures of the boiler being cleaned in citric acid:
Then i had to do some soldering again and after soldering, cleaning, brushing and removing wasted solder the bolier looks really nice:
I didn't brush the firebox yet but i will do that as soon as i have the adequate brush for my dremel
Florian
Florian is offline
Old 06-08-2009, 08:15 PM   #8
Maryak
Maryak's Avatar
Florian,
Very nice.
Best Regards
Maryak is offline
Old 06-08-2009, 09:08 PM   #9
bearcar1
Senior Member
Liked 43 Times on 43 Posts
Florian, what a very unusual and interesting design this Cochran Boiler. Being from the MidWest US, I have never seen or heard of this design. (although that does not surprise me as there are quite a few things I have never heard of, or most likely will ) Could you tell us please, about the design's origins and what service applications it was intended for, and why. Thanks for all of the great photos and that is truly some beautiful smith work you have done.
BC1
Jim
bearcar1 is offline
Old 06-08-2009, 09:08 PM   #10
rake60
rake60's Avatar
Liked 220 Times on 195 Posts
Beautiful work Florian!
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
How much boiler? Lakc Boilers 4 10-31-2011 01:22 PM
A seriously big boiler Kaleb Photos and Videos 2 02-22-2011 04:47 PM
MOVED: Cochran Boiler Maryak Photos and Videos 0 05-17-2010 10:52 PM
How big a boiler? Phelonius General Engine Discussion 9 02-15-2009 06:01 PM
Boiler firebird General Engine Discussion 8 04-28-2008 10:05 PM
