Project of the Month built by Rustkolector
Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > Luck of the Dumpster
Old 10-06-2016, 12:33 AM   #1
vederstein
Must do dumb things....
vederstein's Avatar
Liked 294 Times on 187 Posts
Likes Given: 85
Default Luck of the Dumpster
I was back in the machine shop at my workplace and in the scrap bin I found eight ball screw slides. The longest has about a 23" stroke.
I asked my boss, and he let me take them.
After some investigation, they've been sitting on a shelf for years and they just decided to scrap them.
I don't know what I'm going to do with them, but SCORE!!!!!
...Ved.
vederstein is offline
7
People Like This
Old 10-06-2016, 03:22 AM   #2
Ratshooter
Liked 9 Times on 6 Posts
Likes Given: 5
Default
In the time honored tradition of the Home Shop Machinist board, let me be the first to award you with the "You Suck" honor!
Regards, Tim
Ratshooter is offline
3
People Like This
Old 10-06-2016, 03:54 PM   #3
DICKEYBIRD
Liked 59 Times on 49 Posts
Default
Geez, you suck so bad, the world barometric pressure just plunged downward.
(Congrats on a huge stroke of luck!)
"Accuracy is the sum total of your compensating mistakes."
Milton in Tennessee, USA
DICKEYBIRD is offline
Old 10-06-2016, 05:45 PM   #4
Journeyman
Journeyman's Avatar
Liked 7 Times on 6 Posts
Default
Definitely jealous!! Looks like you are half way to a nice CNC router there..
Good Luck
Real stupidity beats artificial intelligence every time... Terry Pratchett
Journeyman's Workshop
Journeyman is offline
Old 10-06-2016, 06:09 PM   #5
DICKEYBIRD
Default
Looking at that photo of your shop, you're going to have trouble finding a spot to store at least 3 of those. I have the perfect spot to store them: under my ol' all-thread rod equipped router!
RunnerPack Likes This
Old 10-06-2016, 10:29 PM   #6
vederstein
vederstein's Avatar
Likes Given: 85
Default
Thanks for ribbing....
I think I'll probably make a CNC router. I'm not a woodworker, but my brother and brother in law are. I'll probably give it to one of them when done. It'll be a nice winter/spring project.
Going this route will ease my wife's mind for a while. I was going to get a 3D printer and get set up for an aluminum lost wax foundry. (But I have no experience with casting).
That will use up probably four slides (2 Y-axis, 1 X-axis, 1 Z-axis).
As for the remainder, I see a CNC or Ardunio controlled bubble machine for the 2017 Maker Faire season.
...Ved.
tr7sprint79 Likes This
Old 11-13-2016, 09:31 PM   #7
vederstein
vederstein's Avatar
Likes Given: 85
Default
Following are some pics of the progress I've made using these slides to build a CNC router.
If there's interest, I can continue posting. If not, I can stop. It's no big deal to me.
Anyway, except for the 4" aluminum channel and wood I purchased for the Y-axis slide mounting, I'm building this thing with materials I have laying around and without any plans. It's just kind of falling together as I go. (I'm amazed at the quantity of aluminium barstock I've accumulated. Some of this stuff I didn't even know I had).
Onto the pictures:
5
People Like This
Old 11-14-2016, 03:42 PM   #8
DICKEYBIRD
Default
Heck yes there's interest! Keep it coming. I need to see lots of CNC construction at the moment to keep me motivated. I'm itching to move forward with the upgrades to my router but my neighbor/buddy & his company have other plans. They give me little machining jobs now & then but this latest batch is taking up all my nights & weekends. Oh well, gotta make hay while the sun shines. I can use the extra income to buy more toys!
Old 11-14-2016, 04:04 PM   #9
Journeyman
Journeyman's Avatar
Default
You will want to keep it!! Routers are not for wood alone. If built rigid enough and fitted with a cheapo 2.2kW water cooled spidle it will happily munch it's way through aluminium.
Keep posting
Old 11-19-2016, 02:27 AM   #10
vederstein
vederstein's Avatar
Likes Given: 85
Default
The past few days have been productive.
First I drilled/tapped the blocks which will mount the X-axis rail.
The to see my progress, I C-clamped the X-axis in place.
Later I'll transfer punch the mounting holes in the slide to the blocks. Then I'll drill/tap the blocks to mount the rail permanently.
2
People Like This
Bad timing, bad valve, bad luck ghart3 Engines From Castings 7 10-26-2011 07:03 PM
Luck and a camera Cedge The Break Room 4 05-02-2010 03:00 PM
Some guys have all the luck SignalFailure The Shop 8 01-03-2008 01:21 PM
