Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > A Work In Progress > Quarter Scale Merlin V-12
Old 02-14-2015, 06:05 AM   #1
mayhugh1
mayhugh1's Avatar
Liked 1824 Times on 387 Posts
Likes Given: 536
Default Quarter Scale Merlin V-12
The Rolls Royce V-12 Merlin, was one of the best known, if not most influential, WWII aero engines. It was deployed in the British Spitfire and later replaced the Allison in the American P-51 Mustang. I recently purchased a set of quarter scale castings from a small San Diego start-up that originally planned to build and sell completed quarter scale Merlins nearly a decade ago.
http://www.quarterscalemerlin.com
The parts I received were investment cast and can be best described as large pieces of (expensive) jewelry. They share most of the realistic features and intricate detail with the equivalent parts on the full-size engine. Photos of the castings are available here:
http://www.quarterscalemerlin.com/castings/
I've no experience in working with castings, and was a little taken back by the notes accompanying them. The notes warned, in several places, that being long, complex, and thin-walled, they will likely require straightening and, in some cases, heat treating.
The set I purchased includes castings for a functional supercharger, but it's not clear whether its scaled development was ever fully completed and just how much of it became a part of the prototype that was produced. The original designers opted for a glow plug engine, and so the magneto development may not have been completed. Finally, the notes mentioned fuel distribution issues with the Merlin's scaled-down intake manifold. The developers eventually designed an alternate configuration with multiple carburetors in order to get a running prototype, but the drawings didn't include information on its design. Over-heating issues were also mentioned, and a prop didn't show up in the published video of their running engine. Working these issues will add some interesting challenge to the project, but I'd rather additional development work wasn't going to involve very expensive and perhaps irreplaceable castings.
I've been able to find online evidence of three other builders who have tackled this project using these particular castings. One posted his crankshaft build on 'the other' forum but he never returned after creating his own piece of art.
My plan is to spend the first few weeks evaluating the castings I have so I can better understand the issues involved with getting them ready to machine. My first goal will be to see if I can get the major crankcase components straightened and fitted together with minimal machining. -Terry
Mayhugh1
mayhugh1 is offline
5
People Like This
Old 02-14-2015, 06:18 AM   #2
Simon
Liked 67 Times on 60 Posts
Likes Given: 28
Default
I've been dreaming about these castings for a very long time but I just know it is well beyond my capabilities!
Really looking forward to following your build.
"The reality is that without cheap imported machines, I would be spending my time doing something less creative and less enjoyable" - Captain Jerry
/// is offline
Old 02-14-2015, 11:27 PM   #3
Herbiev
Herbiev's Avatar
Liked 285 Times on 242 Posts
Likes Given: 92
Default
WOW!! That's some project. Will be following along for sure
Herbie
Hallett cove
South australia
Herbiev is offline
Old 02-15-2015, 02:42 AM   #4
mayhugh1
mayhugh1's Avatar
Likes Given: 536
Default
I'm going to try to justify some of the craziness that I'm about to apply to these very expensive parts with some background theory. Precipitation hardening is a common way of strengthening 356 aluminum which is a popular casting alloy. To promote this process, certain impurities such as magnesium and silicon must also be present in the aluminum melt. As the castings cool these impurities form simple compounds which gradually, over time, come out of solution (precipitate) and they end up distributed throughout the casting. These precipitates harden the casting by preventing its plastic deformation (bending or stretching) when it is put under stress. These precipitates strengthen the casting, but they also make it brittle. This hardening process is kicked off just after the castings solidify, and it continues for hours to days or even weeks later depending upon the casting's storage temperature. Because of this process's dependency upon time, it is also commonly referred to as age hardening.
A casting that has been age-hardened has little tolerance to bending, twisting, or stretching. If a 356 casting warped during its solidification, and if it requires straightening before it can be finish machined, then it must be annealed. This can be done by heating the casting to about 700F and then allowing it to air-cool. The common shop technique of using an acetylene torch to create a soot coating for use as an annealing temperature indicator also works for 356. If, after straightening, the part is left in its annealed state, significant strength will be lost. For 356 the tensile strength loss can be as great as 10,000 psi. Unfortunately, a 700F annealing is not high enough to kick off another age hardening cycle.
The casting can be re-hardened, though, back to its maximum strength by heating it to 1000F for a dozen or so hours and then quickly quenching it. What makes this difficult to do in a home shop is the fact that aluminum melts at 1035F, and so careful temperature control is required. There is also a chance that the casting will deform under its own weight if it isn't properly supported. In addition, air-cooling needs to be minimized which means the quench tank needs be located within seconds of the furnace.
Unlike the more familiar hardening process associated with steel, precipitation hardening does not occur immediately after the quench. The metal may remain soft enough to be straightened for up to a full day after the quench.
Production castings should normally be straightened by the foundry before age hardening has progressed to any significant extent. An even better solution, of course, is to design the part so warpage is a minor concern, and the casting can be corrected by finish machining. The Merlin castings were not straightened by the foundry, and their thin-wall and complex cross sections make them very susceptible to warping that may not be correctable solely by machining. Straightening, after the castings have been allowed to harden, was therefore left to the end-user.
Since this is a totally new experience for me, I felt it would be best to practice on some scrap cast parts I picked up long ago from my favorite scrapyard. My practice pieces, which are louvered vents, were sand cast from 356 and allowed to age-hardened for many years.
I decided to immediately answer a question that was in the back of my mind, and that was just how much could I permanently deform one of these castings without annealing. After breaking two practice parts, I realized the answer was 'pretty much nothing at all.' The rest of my practice was done using only annealed parts.
I eventually developed a process, after cracking a few annealed practice parts, for controlling the pressures I used to bend the castings. I learned to clamp the parts down firmly and to use positive calibrated stops to quantitatively limit the distance that an edge was being pushed. Rather than using a press I typically used my own strength and body weight in combination with fulcrums, levers, and clamps so I could maintain a hands-on feel for what I was doing. I found it was important to proceed in small deformation steps of .005" at a time and continually return to the surface plate to check my progress. I also decided it was best to not aim for perfection but to stop at the point where measurements showed I could machine the remaining defects away without negatively impacting the part's appearance. Since I had decided to not even attempt age-hardening in my shop, I tried to minimize the areas that I annealed. Before attempting any straightening, I located the major axis of the warpage using a surface plate, and I tried to anneal only a narrow region along that axis. I then applied my straightening efforts across this axis. After a full day of experimenting I had gained enough confidence to start on the Merlin parts.
I first selected the three crankcase-related castings. I was able to machine flat the bottom surface of the main casting with respect to the crankshaft bores in order to obtain a reference surface. The front gear case turned out to be the major problem area on this part. It was out of perpendicular by almost .050" over its 5" height. I annealed a line across the gear case just above the top deck of the crankcase. After clamping the crankcase with its reference surface down to my drill press table, I clamped a long piece of wood to the gear case to which I applied the straightening force. With a pencil mark on the wood as a moving pointer I carefully monitored the distance the part was being pushed. After a half dozen tries which included returning to the surface plate to check my progress after each push, I had finally bent the gear case to within .015" of perfection. At this point I was able to machine its cover mounting surface flat and perfectly perpendicular to the reference surface in order to meet the drawing dimensions with no noticeable impact on appearance. I then machined the rear of the crankcase to its finished dimension. The decks for the cylinder heads will be done later, since they can be cleaned up with just finish machining.
The gear case cover was relatively simple to correct because its major warp was also about a single axis. The documentation warned that this rather rigid part might have to be widened, and the drawings included the design of a complex 'stretcher' to attempt this. I'm thankful that my particular cover, which is a fairly rigid part, didn't require this really scary correction.
The oil pan was considerably more complex and problematic. Being rather flimsy by design, it was warped across two separate axes. In addition, it's width had to be spread to match the crankcase. When checked on the surface plate, one corner of this part was initially almost 1/8" higher the other three. This part required almost a full day to correct, and I ended up annealing practically the whole casting. Fortunately, the oil pan is not a structural part, and the loss in strength that it likely suffered is not important. In the set-up for its final flange machining, the pan had to be packed with plastic modeling clay in order to dampen the chatter created by the mounting flange machining. I used high relief aluminum-cutting Korloy carbide inserts for all the machining operations and was able to obtain excellent surface finishes on both the annealed and un-annealed areas of all three castings. - Terry
Mayhugh1
mayhugh1 is offline
15
People Like This
Old 02-15-2015, 01:13 PM   #5
kvom
kvom's Avatar
Liked 605 Times on 483 Posts
Likes Given: 283
Default
Quite an interesting process. If I understand properly you only needed to apply the torch to anneal along the axis of warping, while the rest of the casting was not heated.
kvom is offline
Old 02-15-2015, 03:05 PM   #6
Scott_M
Scott_M's Avatar
Liked 67 Times on 49 Posts
Likes Given: 211
Default
Nice work Terry, those really are some good looking castings.
Scott
Scott_M is offline
Old 02-17-2015, 10:42 AM   #7
michael-au
michael-au's Avatar
Liked 327 Times on 166 Posts
Likes Given: 782
This is a big project, I know someone that has completed the same engine, I have seen it run
It is an amazing project
Here is a picture of his engine
michael-au is offline
8
People Like This
Old 02-17-2015, 11:06 AM   #8
Ethan D
Liked 3 Times on 2 Posts
Likes Given: 17
Default
This is going to be amazing! the detail is crazy! Can't wait to see updates
Ethan D is offline
Old 02-17-2015, 11:48 AM   #9
gus
gus's Avatar
Liked 1161 Times on 815 Posts
Likes Given: 1539
Default
Mind boggling and only a true-blue blood HMEM Forum Member will attempt to build this engine. 1,000,0001 parts to machine. This engine will take at least 2 years to complete and run.
Gus,the Happy Boat-Fisherman and Happy Machinist.
(Jack of all Trades and Master of None)
gus is offline
Old 02-17-2015, 12:28 PM   #10
Ripcrow
Liked 13 Times on 12 Posts
Likes Given: 17
Default
Following along. Can't wait to hear it run. The most famous engine in the world. To me anyway
Ripcrow is offline
2
People Like This
For Sale, DeHavilland Cirrus Mk1 in quarter scale- Sold! gbritnell Buy / Sell / Trade / eBay 7 06-10-2015 07:59 PM
Merlin V12 matt-jaysey General Engine Discussion 5 02-10-2013 07:37 PM
Merlin V12 Castings for Sale agmachado Engines From Castings 5 12-05-2011 03:43 PM
Rolls Royce Merlin Proflooney General Engine Discussion 9 01-29-2011 03:26 PM
Packard Merlin V-12 pictures fltenwheeler The Break Room 7 09-29-2010 04:45 AM
