Home Model Engine Machinist > Building Them > Plans > Free plans for a larger, simpler, beam engine
Old 07-24-2008, 02:46 PM   #1
Brian Rupnow
Liked 4125 Times on 3271 Posts
Likes Given: 37
Default Free plans for a larger, simpler, beam engine
I love Elmers engines, and I love the concept of all the moving mechanisms on a beam type engine.--That being said, after building one of Elmers basic wobblers, I find them, well,--tiny!!! They work, and they work very well, but for new amateur machinists like myself, its almost micro machining. I want a beam engine that is larger, and somewhat simpler to build, and one for which a kit is not needed. I want the parts to be large enough that I can machine them without a magnifying glass, and I want all the parts to be made from bar stock. So--I have taken Elmers beam engine, scaled it up to twice the size Elmer had in mind, and I am doing up a complete set of plans which I will post here. Many of the peices will be simplified, and if someone wants to take any of the parts and fancy them up a bit, that is perfectly fine with me. Stick around, and as I get the plans completed, they will be posted here with full dimensions and material specifications.--Brian
Brian Rupnow
Brian Rupnow is offline
mcshaned Likes This
Old 07-24-2008, 03:39 PM   #2
malcolmt
Liked 14 Times on 14 Posts
Likes Given: 51
Default Re: Free plans for a larger, simpler, beam engine
Brian
Excellent thinking, I will look forwards to your progress. Thank you for sharing this with us.
Kind regards
Malcolm
malcolmt is offline
Old 07-24-2008, 04:01 PM   #3
Philjoe5
Philjoe5's Avatar
Liked 330 Times on 272 Posts
Likes Given: 54
Brian,
Good for you, excellent idea! I am in the same frame of mind. I dislike running a tap into metal and trying to imagine that I'm cutting threads (like 2-56). I just did a 1.5x scaleup of a Ray HasBrouck design but I won't post my plans since he's still selling them. But it was a straightforward scaleup - just multiply everything by 1.5x and improvise when necessary. I'm looking forward to your results.
Phil
Beware those who are often wrong, but never uncertain - B. Parker
Philjoe5 is offline
Old 07-24-2008, 04:08 PM   #4
Brian Rupnow
Likes Given: 37
Definately a work in progress as we speak. I'm on holidays and its rained all damn week!!! Might as well do something I enjoy--(you'd think I would get enough design work the other 50 weeks of the year). I love this 3D software (Solidworks) and steam engines, so---
Brian Rupnow
onepenn111 Likes This
Old 07-24-2008, 04:32 PM   #5
SignalFailure
Liked 11 Times on 20 Posts
If anyone wants Elmer's Beam scaled up by about 1.75x and converted to metric I can supply the plans (I haven't got round to building it yet though!).
One day I will completely finish one project.
SignalFailure is offline
Old 07-24-2008, 04:35 PM   #6
SmoggyTurnip
Liked 4 Times on 4 Posts
Can someone tell me what the advantage of the beam is? I never understood why the beam was used. Why not just connect the piston to the crank with a connecting rod - you have to connect the beam with a connecting rod. Please educate me?
SmoggyTurnip is offline
Old 07-24-2008, 05:00 PM   #7
Brian Rupnow
Likes Given: 37
The beam type engines didn't originally turn a wheel. Instead of a wheel, the end of the beam was connected to a plunger in a pipe that pumped water out of the coal mines in Wales. I expect that the wheel was added at a later stage to get rotary motion, as the design of steam engines evolved. Eventually, somebody had the same thought you did, and the beam was done away with.
Brian Rupnow
hein Likes This
Old 07-24-2008, 05:03 PM   #8
SmoggyTurnip
Well that makes sense! Thanks alot.
Old 07-24-2008, 05:08 PM   #9
kvom
kvom's Avatar
Liked 614 Times on 485 Posts
Likes Given: 287
Watt's original engine was a beam style mine pump.
kvom is offline
Old 07-24-2008, 05:10 PM   #10
malcolmt
Likes Given: 51
That would be great. i have been considering this engine for some time.
Kind regards
Malcolm
malcolmt is offline
Lotsa free engine plans gunboatbay Plans 33 01-31-2017 10:36 PM
New beam engine plans oldboatguy Plans 48 03-03-2015 02:52 PM
Brian Rupnow's Plan for a larger simpler beam engine barryb Plans 5 04-26-2014 05:42 PM
First Engine from Plans - Elmer's Beam agr A Work In Progress 28 07-07-2009 05:58 AM
a Horizontal engine - First build(Lots of free plans too!) Kermit Plans 14 12-20-2008 05:05 PM
