Project of the Month built by Stefan-K
Home Model Engine Machinist > Building Them > Questions and Answers > lubricant for machining aluminum
Thread Tools Display Modes
Old 07-23-2008, 11:21 PM   #1
farmerbill13
Liked 4 Times on 4 Posts
Default lubricant for machining aluminum
I've used kerosene and wd-40 in the past,just wondering if there was anything cheaper that worked just as good?I'm machining cooling fins on a cylinder for a hot air engine.Thanks,Bill
farmerbill13 is offline
Old 07-23-2008, 11:45 PM   #2
rake60
rake60's Avatar
Liked 215 Times on 192 Posts
Default Re: lubricant for machining aluminum
Welcome to HMEM Bill!
You'll never find a better cutting fluid for aluminium than straight kerosene.
It may not be the safest thing. I've had more than one little yellow flame
flair up in front of me.
There are some commercial products available such as Tap Magic Aluminium
Now THAT is the TOP of aluminium cutting fluids.
For the cost of 16 ounces of that you can buy a gallon of kerosene that is almost as good.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 07-24-2008, 12:05 AM   #3
farmerbill13
Thanks Rick,tap magic is good stuff,I have used it on deep hole tapping and reaming and your right about the price.
Old 07-24-2008, 12:10 PM   #4
LCT
Guest
Posts: n/a
WD-40 is my choice. I have heard some people get good results from automatic transmission fluid too.
Old 07-24-2008, 12:59 PM   #5
Florian
Liked 24 Times on 24 Posts
Hi Bill
I usually use denaturated alcohol. You will have to open the windows but it works quite well and the surfaces look nice.
Florian
Florian is offline
Old 07-24-2008, 05:37 PM   #6
JaguarB
Liked 11 Times on 5 Posts
I have been using Barbecue lighting fluid with good results
Paul
JaguarB is offline
Old 07-24-2008, 08:38 PM   #7
Metal Mickey
Liked 19 Times on 18 Posts
Does anyone know where you can buy clear cutting oil?
Have a look at my website ....... http://www.mikes-models.com
I use my lathe to turn 'a' round........then I go back....
Metal Mickey is offline
Old 07-24-2008, 10:28 PM   #8
Tin Falcon
Tin Falcon's Avatar
Liked 808 Times on 645 Posts
Likes Given: 18
There was some discussion on this on another thread. A-9 appears to be mineral oil with some additives. Perfume dye and a couple "secret" ingredients. So mineral oil from the drug store or big box store should work fine.Mineral oil is clear
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 07-25-2008, 12:41 AM   #9
rake60
rake60's Avatar
I have a very OLD Machinery's Handbook here.
It is a 1st Editon printed in 1914.
(No it is NOT for sale!)
Aluminium was a precious metal then.
The book recommends "Rendered Beef Tallow" as a cutting fluid
for aluminium.
Cut a chunk of fat off a cow, boil it into an oil and your all set!
Well... It worked in 1914!
Rick
rake60 is offline
Old 07-25-2008, 12:53 AM   #10
Stan
Liked 31 Times on 31 Posts
Metal Mickey: Are you looking for a high sulphur cutting oil or a cutting fluid for some particular metal?
Tim: Those 'additives and secret ingredients' make a big difference in the mineral oil for cutting aluminum. Like the additives and secret ingredients your wife puts in the flour when she makes a chocolate cake.
Stan in Leduc, Alberta, Canada. 53.40NĀ* 113.5W
Old, but still on the right side of the grass.
Stan is offline
Effect Of machining speed on surface roughness in cutting 6061 aluminum Sshire Metals 4 08-03-2012 08:45 AM
Nanolube Lubricant Philjoe5 Special Materials 21 02-18-2011 02:11 AM
Why--What is going on with this Aluminum? Diy89 Questions and Answers 9 01-20-2010 06:00 PM
Lubricant tmuir Questions and Answers 7 04-30-2008 04:53 PM
aluminum Mike of the North Buy / Sell / Trade / eBay 1 04-14-2008 03:00 PM
