Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > Multi cylinder CDI
Old 07-04-2013, 05:24 PM   #1
Leucetius
Liked 2 Times on 2 Posts
Default Multi cylinder CDI
Good evening guys.
A friend of mine and I have a question regarding CDI on multi cylinder engines. More exactly if it is possible to realize this (in our world) without the usage of a distributor to direct the discharge of the coil to the correct spark plug?
Greeting from Germany
Kevin
Leucetius is offline
Old 07-04-2013, 05:41 PM   #2
Lakc
Liked 62 Times on 56 Posts
Likes Given: 17
Default
To direct the discharge of a coil without a distributor is probably not going to happen. Multiple CDI units with multiple coils are generally the way its done.
Jeff
Lakc is offline
Old 07-04-2013, 06:03 PM   #3
Jasonb
Jasonb's Avatar
Liked 421 Times on 263 Posts
Likes Given: 18
Default
Depends on how many cylinders you have, if not many then the lost spark method is common. eg when the CDI is tripped usually by a hall sensor it will send a charge to each sparkplug only one of which will actually fire.
On say a V8 you could get away with two CDIs and loose the sparks.
J
Jasonb is offline
Old 07-04-2013, 08:09 PM   #4
el gringo
el gringo's Avatar
Liked 93 Times on 24 Posts
Likes Given: 16
Default
Roy Scholl at S/S engineering set me up with a two coil CDI for one of my
two cyl engines at a minimal extra charge that allowed me two wire both spark plugs from the same CDI although they were both triggered by the same hall sensor.
el gringo is offline
Old 07-04-2013, 08:38 PM   #5
Leucetius
Default
The engine at stake can be seen at the attached pictures. It's from the magazin 'Model Engineer' and my friend is in the planning phase of making it. I've done the CAD files for him and now he wants to change the engine from it's original glow plug system to spark ignited. As you can see on the rear view, a hall sensor can be attached at the camshaft without destroying the overall look. Imagine this beauty with a distributor...
So on the 4-cycle, 4-cylinder engine shown, this means all spark plugs fire together every cycle/90 camshaft rotation? Doesn't this especially leads to problems at the end of the intake/begin of compression?
We thought that maybe it's possible with 4 hall sensors but just one magnet. In the manner that there's just one coil which is triggered by each sensor and somehow the circuit routes the discharge to the corresponding spark plug.
Old 07-05-2013, 02:53 AM   #6
dieselpilot
Liked 108 Times on 97 Posts
Likes Given: 3
Default
Switching high voltage electronically is not easy or practical. A pair of twin ignitions is the simple answer if you want CDI and no distributor.
Seeing that you're in Germany you may look at http://www.power-spark.de/
Greg
dieselpilot is offline
Old 07-05-2013, 06:30 AM   #7
Jasonb
Jasonb's Avatar
Likes Given: 18
Default
It will depend on your timing and crank layout but taking a twin or one side of your engine as an example with two magnets on teh end of the cam shaft and one hall sensor.
As one sparkplug fires at the top of the compression stroke the other will get a spark at the top of the exhuast stroke which will have no effect.
The problem starts as you get more cylinders and the sparks get closer together to a stage where you get an early spark in one of the cylinders that tries to make the engine backfire.
J
Jasonb is offline
Old 07-05-2013, 09:05 AM   #8
Leucetius
Default
Thanks for your answers. We think the lost spark method is interesting as such but he won't use it. My friend will buy
a) one RC-i 400 from Power Spark and
b) two RCexl Twin cylinder from RCXp
when the engine is ready for testing - I will post results and videos.
Greetings and happy weekend
Kevin
Old 07-05-2013, 10:15 AM   #9
Niceonetidy
Colin D
Niceonetidy's Avatar
Liked 33 Times on 20 Posts
Likes Given: 56
Default
BTW,
You can buy these single and Twin Rcxel units at an amazingly low price from Hobby King, Search engine accesories
Life long modeller, www.bailey-steam.com
Niceonetidy is offline
Old 07-05-2013, 05:05 PM   #10
Leucetius
Default
That's a nice information! I know HK from my days I was flying several Helicopter and Airplanes, main source of LiPos in this time and scene
A multi-cylinder crankshaft machining tutorial gbritnell A Work In Progress 31 04-25-2015 10:59 AM
Multi page thread Draw-Tech General Engine Discussion 2 03-21-2013 11:02 PM
Multi-lead threads joeby Tips and Tricks 13 03-11-2010 05:10 PM
Making Multi Cylinder Engines Philjoe5 General Engine Discussion 7 11-26-2008 04:54 AM
Smithy Multi-Function machines Graybeard General Engine Discussion 12 01-04-2008 05:55 PM
