Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > Team Builds > TB3 - Roll Call
Old 07-09-2008, 11:44 AM   #21
kvom
kvom's Avatar
Liked 605 Times on 483 Posts
Likes Given: 282
Default Re: TB3 - Roll Call
I didn't see the springs on the parts list. Are we making springs or finding some that are already made?
kvom is offline
Old 07-09-2008, 10:56 PM   #22
Powder keg
Powder keg's Avatar
Liked 32 Times on 32 Posts
Forgot about the springs. We'll have to make them also. Anyone want to play with those?
We are still missing page ten. David sent me a link with the plans and it is gone off his page also. I Emailed him and let him know about it.
Wes
Wesley P
Idaho:o)
A Gismo ??? If it has a flywheel or spins and is made with small parts. I'll take one! If it makes noise, moves, or requires frequent oiling and dusting it's a better deal yet. It's especially right if its shiny and bright.
Powder keg is offline
Old 07-10-2008, 01:47 AM   #23
chuck foster
Liked 38 Times on 38 Posts
i will have the springs on the valves when i'm done............unless someone really wants to make the springs ........just let me know
chuck
the northern chuck
chuck foster is offline
Old 07-10-2008, 09:18 PM   #24
zeusrekning
Liked 10 Times on 10 Posts
I attempted to solder a 3/16 carbide endmill to a piece of brass shim stock(.020" thick). It worked very well. I can't solder for $#!^ ,yet. So I'm sure soldering won't be a problem.
Tim
"The superior man is modest in his speech, but exceeds in his actions."
zeusrekning is offline
Old 07-10-2008, 11:55 PM   #25
Powder keg
Powder keg's Avatar
Ok, David fixed my link and I sent it to all the team players) There is a cam, regulator bobbin, and regulator arm left. Any takers?
Wes
Wesley P
Idaho:o)
Old 07-11-2008, 04:22 AM   #26
JMe
Liked 7 Times on 7 Posts
Hi
i take the regulator arm pivot
Jacques
JMe is offline
Old 07-11-2008, 09:42 AM   #27
Dick L.
Liked 2 Times on 2 Posts
Wes, I'll do the Bobbins. I didn't see a call out for material type for them though.Needs to be a good bearing surface inside and out. How about cast iron or brass?
Dick
Dick L. is offline
Old 07-12-2008, 11:15 PM   #28
Powder keg
Powder keg's Avatar
I was just checking to see if Te_gui got my PM about the Flywheels? I haven't heard back yet.
Wes
Wesley P
Idaho:o)
Old 07-13-2008, 06:22 AM   #29
te_gui
Liked 4 Times on 4 Posts
Hey Wes,
I had thought I replied but it may have gone poof, I dunno. We are trying to decide on flywheel material. I have lots of steel available, maybe some brass/bronze but probably not enough to do all of them. If I do steel I am looking into a friend who does nickel plating to see if that might be a feasible option. Enough brass from McMaster Carr will be about 650 so that's a little steep. I think aluminum might be a little light for a hit and miss, they need the mass to carry them thru. Anyone have any thoughts or suggestions?
Brian
te_gui is offline
Old 07-13-2008, 12:40 PM   #30
kvom
kvom's Avatar
Likes Given: 282
I plan to paint my flywheels, similar to the pictured version. So steel is fine for me.
kvom is offline
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex General Engine Discussion 11 06-11-2009 01:19 PM
TB2 - Roll Call Brass_Machine Team Builds 0 06-20-2008 05:02 AM
TB1 - Roll call for Elmers OC Brass_Machine Team Builds 0 05-21-2008 06:31 AM
What Would You Call This? rake60 The Break Room 2 08-28-2007 01:12 AM
