Project of the Month built by apointofview
Home Model Engine Machinist > CNC > CNC Machines and Conversions > PC based DRO?
Thread Tools Display Modes
Old 04-03-2013, 11:45 AM   #1
Rivergypsy
Liked 224 Times on 118 Posts
Likes Given: 227
Default PC based DRO?
Just something that I've been pondering, but does anybody know of a PC based DRO system, please?
I've found Yadro on the net, but the boards are out of stock, but I keep wondering how feasible it is to build one myself.
The other option would be something Arduino based. I've found one of these that works through an Android phone, but I'd be loathe to leave one of these next to flying swarf.
Any help or pointers gratefully recieved!
Rivergypsy is offline
Old 04-03-2013, 12:11 PM   #2
microcraft
Liked 2 Times on 2 Posts
Default
Android (or "Smartphones") have indeed become a big fixture of our lives. However, I don't think they are yet up to the task of being a DRO display. Imagine being in the middle of a tight tolerance cut and the phone rings
I like the idea of dedicated devices for certain tasks and your PC Based DRO would fit the bill.
microcraft is offline
Rivergypsy Likes This
Old 04-03-2013, 12:25 PM   #3
dman
Liked 36 Times on 32 Posts
Likes Given: 5
Default
http://www.shumatech.com/web/product...0/construction
this could be fun... also the source code may help you/someone write a dro application for a pc if you are set on the pc thing. you'll need to know how to read different encoders. also you could probably just use cnc software on a pc if it has support for different encoders.
dman is offline
gabby Likes This
Old 04-03-2013, 02:40 PM   #4
n4zou
Liked 37 Times on 30 Posts
Default
New Android Tablets can be found for less than $100 now. This makes them suitable for use as dedicated devices.
Do-it-yourself DRO with Arduino and Android
n4zou is offline
2
People Like This
Old 04-03-2013, 03:41 PM   #5
lohring
Liked 67 Times on 54 Posts
Likes Given: 10
Default
I built a YARDRO. It needs a really old laptop with a serial connection, but the programming is open source. I'm not sure the hardware is available any more.
Lohring Miller
lohring is offline
gabby Likes This
Old 04-03-2013, 06:28 PM   #6
dnalot
Project of the Month Winner !!!
dnalot's Avatar
Liked 294 Times on 103 Posts
Likes Given: 52
Default
You might look at Artsoft's Mach 3 cnc controller software. It is made to be used by almost any hardware and can be configured a 100.000 different ways. You can also make your own custom screen layout. I have used it since I built my CnC machine 13 years ago. It was version Mach 1 and I only paid $100, with a lifetime free upgrade.
What do you plan to use for position senders?
dnalot is offline
Old 04-03-2013, 11:14 PM   #7
Teus
Teus's Avatar
Liked 5 Times on 3 Posts
Default
And then there is also Caliper2PC.
Teus is offline
74Sprint Likes This
Old 04-04-2013, 12:09 AM   #8
jgedde
jgedde's Avatar
Liked 116 Times on 67 Posts
Likes Given: 21
Default
That's slick! I want one!
jgedde is offline
Old 04-04-2013, 07:04 AM   #9
ycroosh
Liked 7 Times on 5 Posts
Default
John,
That's the old version. The new version is even slicker and easier to build
On a serious note, I've been using Android tablet for a DRO for over a year now and a PC before that. (I built the first version in late 2011 when I first got the mini mill) and it's been pretty stable. I had more trouble with the scales being sensitive to noise and ground loops than with the tablet itself.
Thank you
Yuriy
ycroosh is offline
Old 04-04-2013, 11:15 AM   #10
Rivergypsy
Likes Given: 227
Default
Hi guys,
Thanks for all your feedback on this
I'd planned on using quadrature scales, and also a rotary encoder on the lathe spindle for angular display for live tooling use, and switchable to rpm for general use.
The Arduino solution looks neat, and i already have one of them, but I do like to get hot swarf pinging around, so I'd like the display to be pretty robust. The Shumtech again looks neat, but it's out of stock at the mo, so I'll give them a chase up.
If I went the Mach3 route, is it likely to confuse it if it has no motors connected?
Sorry for what may be dumb questions, but i'm a lot more comfortable with mechanics than electronics...
Many thanks
gabby Likes This
V4 steam engine - based on CFellow's opposed 4 crueby Finished Projects 9 09-15-2012 03:48 PM
Hit and Miss based on Chuck Fellows design FIXIT Questions and Answers 13 08-04-2010 05:53 AM
Recommend a web based mail service DickDastardly40 Computer Geek Zone 5 03-05-2009 02:02 AM
