Home Model Engine Machinist > CNC and 3-D Printers > Software and Programming > learning cad
Old 03-08-2013, 06:09 PM   #61
lohring
Liked 75 Times on 61 Posts
Likes Given: 10
Default
Thanks for all the suggestions. The drawing is from an Aprilia 125 cc motorcycle cylinder. The engine develops 54 hp and is considered to be the state of the art in high power, small two stroke engines. It was developed without the use of CAD so I suspect the 3D rendering is built from scans of the core patterns. I could build models like the 3D picture to cast molds to make the cores like the pictures of sand casting core molds below. However, I thought I would try solid modeling since it has lots of advantages when combined with 3D printing for scaling or altering parts to test the effects of small changes.
I'm studying lofts in Alibre and it looks like I can loft a section along a curve. That will be a good place to start. I can work up to a series of sections along a complex curve if needed. It still looks easier to build a physical model, though.
Lohring Miller
lohring is offline
2
People Like This
Old 03-10-2013, 03:51 AM   #62
wildun
Liked 7 Times on 7 Posts
Default
LOHRING,
The name Jan Thiel rings a bell from the late sixties, was he the guy who was involved with designing the 50cc racers for the Dutch Jamathi team of the late sixties/early seventies and later moving to Derbi?
If that is the case, then his knowledge of two strokes would be second to none.
BTW, my school French was not quite up to scratch for the forum but I was able to get the gist of it!
wildun is offline
Old 03-10-2013, 06:37 AM   #63
Auzzie53
Liked 2 Times on 2 Posts
Default
Originally Posted by jixxerbill View Post
I want to learn cad, but whats the best/easiest to learn... i have downloaded several trial ones over the years but learning curve seemed steep.. It will still be steep but i really want to learn it for eventual use in cnc machine... A little background about myself. I took drafting in high school, back when it was pencil and paper (1984).. Since then I have worked construction and being able to read and understand prints has been invaluable... I currently have the turbocad trial version and i can sketch out parts in paper mode (takes a while lol) but in model mode i cant get zoomed in far enough....Turbocad web sight has a tutorial video for sale .. I was wondering if anyone had used it before...Thanks Bill
send me your email address and I will send you some material
Auzzie53 is offline
Old 03-10-2013, 11:46 AM   #64
dman
Liked 36 Times on 32 Posts
Likes Given: 5
Default
lohring that looks like a learning experience recreating that in cad. I'm just curious, what are you planing to do with all this? do you have an aprilia and looking for even more power? or trying to learn from it and reproduce it on something else? I'm thinking about getting into 2 strokes on a modification and performance level myself.. I'd really like to see where you go with this.
dman is offline
Old 03-10-2013, 05:57 PM   #65
petertha
Liked 223 Times on 170 Posts
Likes Given: 4
Default
Wow those core patterns are very complex looking. Yet another example of trade craftsmanship achieved long before computer drafting. Seeing those, I think my earlier examples may be barking up the wrong tree for you. I was attempting to show simplistic 'cuts' from a solid, kind of like port passages in a typical RC 2-stroke crank case.
Here is another example along the lines of the one core piece you show. It’s a similar principle oflofting a port shape into a main trunk body. But more along the lines of 'adding’ material to build up some solid shape. I made 3 sections & a spline curve, lofted the solid into the cylinder & filleted the top. In this case I’m just radially copying the exact same arms for illustration, but nothing stopping you from having uniquely shaped and/or un-equalspaced octopus tentacles.
Now what you do with this positive shape is beyond myability. Possibly it could be submerged within a crankcase block & cut away yielding thecavity. SW has such tools & I mentioned other cad packages do this byboolean solids (adding or subtracting). One can also offset or shell a solid.The Cad raw ingredients are there, but how you physically go about designing it isa bit above my head. Fascinating stuff.
petertha is offline
Old 03-11-2013, 03:49 PM   #66
lohring
Likes Given: 10
Default
I'm designing a high power 26 cc two stroke. I race model boats and even the best available engines are considerably behind the state of the art. My inspiration is this quote:
"The best horsepower we attained at Aprilia last year (2007 125cc GP) was 53,9 HP at 13000 rpm. This means a Pme of 14.88 at a piston speed of 23,6 m/sec. Using these same values means that a single cylinder 50cc would give 29.5 HP at 17850 rpm and a 50cc twin would give 39 HP at 23600 rpm, measured at the gearbox output shaft. I am 100% sure these values can be attained although it never will be proved due to lack of interest and money. Remember that 50cc development was stopped in 1983 and enormous progress was made in the following 24 years. Now, sadly, also the development of the 125cc two strokes has stopped, the two stroke will only survive in karting but there will be no progress because of the very strict regulations!"
Jan Thiel 2008
That would mean that my 1/2 of a two cylinder 50 cc engine could produce 19 hp rather than the 8 hp at around 18,000 rpm the very best current engines have. I would be happy with anything over 10 hp. I was involved with the current RC gasoline engine powered speed record of 109+ mph set in 2004 that still stands. The last complete engine I built was in high school over 50 years ago. I belong to a restricted forum of two stroke builders that made the above pictures available.
I'm trying sweep cuts in Alibre to generate the transfer passages. I hope to create one plane for each side of the transfer then sweep the shape shown in the 2D cross section around the bore from one plane to the other. I can then fillet the edges of the shape. So far it isn't working, though.
Lohring Miller
lohring is offline
Old 03-12-2013, 01:27 PM   #67
dman
Likes Given: 5
Default
Jan Thiel 2008
Lohring Miller
that'll get you sorta close but you may wat to try it with a mesh so things can be manipulated to get some of the more organic aspects of it closer. do you have a more readable copy of that blueprint? maybe in a .pdf or other vector format? mabe i'll try to draft someting up. it's been a while since i've done anything close to this. it turns out that this kind of drafting is rarely needed in what i'vw been doing
just for fun i ran some of those numbers for some popular 2 stroke engines to see what they could make in full race trim.. (assuming the bore/stroke ratio is close, i really just ran the numbers as if the aprilia was scaled.) an lt500r quadzilla could make around 135hp at 8200 rpm. a banshee or rz350 could also make 135hp at 11,600 rpm. (weird how that works isn't it) and a 250cc engine could make 86hp at 10,300 meaning a kawasaki h2 machiv could make a scary 258hp and even an h1 could make 196hp at 11,800.
what i think is interesting is the numbers are around twice what the best stock japanese engines made when 2-strokes ruled motocross but the rpm isn't too much higher. sounds like aprilia had a lot going on in this engine. maybe my next motorcycle will be a 2-stroke.
dman is offline
Old 03-12-2013, 03:27 PM   #68
lohring
Likes Given: 10
Default
Thanks for your offer to help. So far I think a series of cross sections along a 3D curved line is the only way. The only drawings I have of the Aprilia cylinder are .jpg. Below are the rest.
Lohring Miller
PS I've at least been able to model propellers. See below.
lohring is offline
Old 04-07-2013, 05:55 AM   #69
DanP
Liked 8 Times on 7 Posts
Likes Given: 4
Default
Hi
I was not sure where to ask this but I thought I would start here. A friend of mine is using a Mac drawing program, I don’t know what it is and he doesn’t seem to know either. I am using AutoCAD 2006. We have been collaborating on a Gauge 1/ Gauge 2 layout plan. When he sends me his file in either DWG or DFX I can open them with AutoCAD and use them, add to them, change them, whatever I can do with a normal AutoCAD drawing. When I send them back to him in either format he can see them but not use them. I save them as 2000, because that’s what he says he needs. So, the question, what are we doing wrong?
DanP is offline
Old 04-07-2013, 11:09 AM   #70
ausdier
Liked 83 Times on 59 Posts
Likes Given: 7
Default
Hi Dan,
Does your mate have an educational copy of the program he is using ?
This sometimes means it wont open non educational drawings.
Cheers.
ausdier is offline
Learning how to scrape :D ttrikalin Tips and Tricks 70 03-06-2012 04:53 PM
Still learning about myself - a funny story cfellows The Break Room 23 01-01-2012 08:26 PM
Compressor learning curve student123 General Engine Discussion 2 06-10-2010 06:09 AM
Newbie learning to post Phelonius The Break Room 2 01-25-2009 11:38 PM
Learning to use CAD tmuir General Engine Discussion 134 10-01-2008 08:06 PM
