Home Model Engine Machinist > Building Them > General Engine Discussion > Counterbore Concentric issues
Old 01-30-2013, 11:05 PM   #1
Nhat
Liked 3 Times on 3 Posts
Default Counterbore Concentric issues
I was wondering if anyone knew of a method to drill concentric counterbores on both sides of a rectangular block of acrylic with a through hole? I've tried one method of drilling a counterbore one side and then drilling a hole through the center. Then flipping the piece and placing its hole through the drill bit to center it and clamp it down before doing another counterbore. This method works okay, but I was wondering if anyone knew of a more efficient method that gives better results?
Nhat is offline
larry1 Likes This
Old 01-30-2013, 11:11 PM   #2
Alchymist
Alchymist's Avatar
Liked 18 Times on 14 Posts
Likes Given: 37
Default
IF your block is perfectly square, set up two stops for adjacent sides, drill , counterbore, then flip so the same two adjacent sides are against the stops. Counterbore. If every thing is square, the counterbores will align.
Alchymist is offline
Old 01-30-2013, 11:16 PM   #3
Nhat
Default
Alchymist, thank you for the tip. I'm actually trying to drill counterbores for a rectangular piece; however, I have access to a milling machine.
Nhat is offline
Old 01-30-2013, 11:22 PM   #4
goldstar31
Liked 382 Times on 329 Posts
Likes Given: 603
Default
The most accurate method of boring is NOT to start from both sides, or have a boring head or whatever. The accurate way is to drill a hole and then put an inline boring bar through.
It comes out perfectly parallel.
This is the way that Chaddock did his Quorn tool and cutter grinder
goldstar31 is offline
Old 01-30-2013, 11:26 PM   #5
johnmcc69
Liked 19 Times on 18 Posts
Likes Given: 22
Default
Are you using a "standard" screw ct'b that has a pilot on
it or are you doing something different?
johnmcc69 is offline
larry1 Likes This
Old 01-31-2013, 06:55 AM   #6
Nhat
Default
Goldstar31 - I like your method. I will try to do that. Thank you!
Johnmcc69 - I was actually using this wooden counterbore because that's all I had at the time: http://www.lulusoso.com/upload/20120...D_WOOD_BIT.jpg
I'm gonna try to find an adjustable counterbore and that will work a lot better. Thank you!
Nhat is offline
Old 01-31-2013, 08:33 AM   #7
goldstar31
Likes Given: 603
Default
It appears in G H Thomas Model Engineers Workshop Manual along with many detailed improvements. True, they may have to re-scaled or drawn for lathes other than the Myford but they really do work.
You will that after you have spent hours making a part that a Thomas tool will not let you down.
So success
Norman
Old 01-31-2013, 10:20 AM   #8
Jasonb
Jasonb's Avatar
Liked 426 Times on 268 Posts
Likes Given: 18
Default
How big is the block of acrylic?
I would hold it in the 4 jaw drill then bore the trough hole, bore the counterbore then turn it the other way round and clock it true with a DTI then bore the other counterbore, should be able to get within 0.001"
J
Jasonb is offline
larry1 Likes This
Old 02-01-2013, 04:53 AM   #9
smithtools2007
Default Counter Bore
We are a leading manufacturer of counter bores as per picture attached. If you have any enquiry, you may send us smithtools2007@rediffmail.com
smithtools2007 is offline
Old 02-02-2013, 11:19 PM   #10
Krutch
Krutch's Avatar
Liked 8 Times on 8 Posts
Likes Given: 3
Default
If I read the post right, the OP wants counterbores to be aligned at both ends of a hole on a rectangular block.
Make the first bore then using a locator of the bore size to locate the first bore on the table under the spindle. This will put the opposing surface up and the first bore under the spindle putting the second face under spindle for the alignment. Make the second bore. If both faces are parallel the bore will be aligned.
If the opposing faces are not square with each other, make the locator for the bore and long enough to locate the through hole and hold on an angle plate using a surface parallel with the hole.
My .02 cents worth.
Krutch
If I'd a known I'd live this long, I'd a had more fun getting here!
Krutch is offline
Making your own counterbore Bernd Tools 6 01-26-2016 04:29 AM
Drilling Concentric Holes dusty General Engine Discussion 14 08-18-2013 10:07 PM
Bollaero 18 issues.... Eartaker General Engine Discussion 1 07-13-2011 10:16 AM
Eclipse Piloted Counterbore Set. wla421 Tools 0 05-13-2010 06:10 AM
drilling concentric holes oregonsteam General Engine Discussion 2 08-31-2009 03:50 AM
