Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > Flat Belts and Model Engines?
Old 01-18-2013, 12:57 PM   #1
Generatorgus
Senior Member
Generatorgus's Avatar
Liked 177 Times on 112 Posts
Likes Given: 32
Default Flat Belts and Model Engines?
I can't seem to find anything. The wheels of progress are turning in my head. Crowned pulleys, flywheels, belts
GUS
Generatorgus is offline
gus Likes This
Old 01-18-2013, 01:33 PM   #2
Jasonb
Jasonb's Avatar
Liked 421 Times on 263 Posts
Likes Given: 18
Default
Can you be more specific, what sort of scale, flat belts and the propper joining clips are available in certain scales.
Would also help to know where in the world you are rather than suggest suppliers thousands of miles away.
Jasonb is offline
narrowgauger Likes This
Old 01-18-2013, 03:43 PM   #3
deverett
deverett
Liked 159 Times on 128 Posts
Default
I've also often pondered this question. What do you use for flat belts about 1" wide?
From UK, I have tried green flat plastic belting as sold by one of the traction engine casting suppliers (LSM from memory), but it is too stiff and slips. Doesn't look very authentic, either. Now I'm thinking of making my own from thin leather. Cutting with a Stanley knife to width over the required length - say 6" between pulley centres, about 16" long - using a steel rule as a straight edge. The ends could then be scarfed and glued with Evostik or similar type latex glue and the joint stitched to prevent the ends peeling apart.
Any other suggestions?
The Emerald Isle
deverett is offline
Old 01-18-2013, 06:14 PM   #4
GailInNM
GailInNM's Avatar
Liked 284 Times on 238 Posts
Likes Given: 109
Default
For flat belts up to about 3/8" (9mm) wide, a large number are available for electronic device service. Things like turntables, VCRs and similar devices.
The best USA source that I have used for these is:
http://www.mcmelectronics.com/browse/Belts/0000000162
They have flat, round and square belts and you can select what you want from the check box on the left side of the above link. The nice thing about MCM is they give the actual size and not just "this belt fits XYZ###" device.
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is offline
Old 01-20-2013, 11:18 AM   #5
Generatorgus
Senior Member
Likes Given: 32
Default
Jason, good question, sometimes I feel like everyone should be on the same page I am, how untrue. You may notice that I have now released a clue to the location of my hideout.
I'm thinking in the 1/2" width range.
My first thoughts are, like Dave suggests, leather but I'm thinking that leather won't work as it would probably have too much stretch at that size range, unless you could possibly prestretch it.
Green is positively out of the question, it would destroy the look.
And, although I would rather any such belting would at least look "leatherish", I woudn't mind doing some experimentation, perhaps leather laminated on a more substantial substrate, but I think thickness would probably limit that. Or posibly faux leather?
Gail's link would be the easiest if the belting could be spliced to length, or the project be sized to existing belt sizes, but is subject to the "leather look" limitation, but better than green.
Still wondering if the crowned pullies or flywheels would function as in real life size machinery.
Oh yeah, I'm thinking about driving a generator, of course.
Thanks
GUS
Old 01-20-2013, 12:18 PM   #6
trumpy81
Liked 53 Times on 40 Posts
Default
Gus, you could use leather. Simply soak it in water for a day or so and then let it dry in the sun for about a week, that should take care of any stretching that might occur. You could then splice and glue together and use simple paper staples to represent the hinge and pins (forgot what it's actually called ... doh!).
Food for thought.
Andy M
Skype - live:ivatrumpy
trumpy81 is offline
Old 01-20-2013, 02:05 PM   #7
canadianhorsepower
canadianhorsepower's Avatar
Liked 296 Times on 236 Posts
Likes Given: 1411
Default
GUS
Hi try this supllier, I've been using it for over a decade building robots
and doesn't matter what I think.... they carry it
http://www.sdp-si.com/
Luc
"if you dont stand for something
you will fall for everything"
canadianhorsepower is offline
Old 01-20-2013, 04:21 PM   #8
deverett
deverett
Default
Originally Posted by trumpy81 View Post
Snip ... and use simple paper staples to represent the hinge and pins.
STAPLES. That's a darn good idea. Much easier than sewing!
The Emerald Isle
deverett is offline
Old 01-21-2013, 12:52 PM   #9
Generatorgus
Senior Member
Likes Given: 32
Default
Guys, thanks for the replies and links. At least I have some options to ponder.
Trumpy, I think they're called laces. I have a full size belt lacer.
Thanks
GUS
Old 01-22-2013, 11:07 AM   #10
trumpy81
Default
Thanks
GUS
Thanks Gus. I knew it was something simple but just couldn't prod the grey matter into giving it up ...
I'll try not to forget it next time
There's a couple of videos on YouTube about lacing, one is by Tubalcain (MrPete22) and the other by Keith Fenner. Both worth watching even if you're an old hand at it.
Andy M
trumpy81 is offline
V6 Model Engines... BlakeMcKee General Engine Discussion 12 12-17-2010 12:14 AM
Model Airplane Engines. Metal Butcher Plans 3 12-26-2009 04:56 AM
Screws for model engines D.C.Clark General Engine Discussion 14 08-23-2009 10:47 PM
Small Flat Belts Supplier [ UK ] Bluechip The Break Room 0 01-03-2009 08:57 AM
Why build model engines? Tin Falcon Introduction 2 08-01-2007 01:27 AM
