Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Hardinge belts
Old 12-18-2012, 07:01 AM   #1
Buchanan
Buchanan
Buchanan's Avatar
Liked 167 Times on 49 Posts
Likes Given: 464
Default Hardinge belts
Hello All
I have two! hardinge HLV-H lathes. I have had belt slip for a while and have kept adjusting the belt tension on one of them for the last few years.
A few weeks ago one belt snapped. Nobody here in Australia knows what the nunbers on the belt mean. It has worn narrow because when I brought it over from England the pullys rusted so we cannot match it from actual dimensions. Could any body help me with a part number or size in current use. The old belts are marked Hainsworth P614 S ansdP394 S
Thank you
Deryck
Buchanan is offline
Old 12-18-2012, 11:16 PM   #2
Mark Rand
Liked 7 Times on 5 Posts
Default
The upper belt is a Gates 9625 or equivalent and the lower one is a 9624.
Mark Rand is offline
Old 12-19-2012, 05:59 AM   #3
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 464
Default
Hello Mark
Thank you very much, this is a great help.
Buchanan is offline
Old 03-25-2013, 10:31 PM   #4
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 464
Default
Hello Mark.
I went to my local belt supplier and they orderd the belts in and when they came they were skinney little fan belts. Is there a prefix or belt type or section that I should speciefy?
Deryck
Buchanan is offline
Old 03-26-2013, 10:08 PM   #5
Mark Rand
Default
Sorry about that they're VSG-9624 and VSG-9625.
Mark
Old 03-27-2013, 12:24 AM   #6
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 464
Default
Hello Mark
Thanks for that . I will see what i can get.
Deryck
Buchanan is offline
Enco GL-30B mill/drill belts, manual? RAB Tools 5 09-18-2013 02:21 AM
Best place to buy CNC gears and belts Dinkum CNC Machines and Conversions 8 07-04-2012 09:04 AM
Timing belts - what to get and where to buy? clivel Tools 8 06-12-2012 10:09 PM
What to use for miniature drive belts??? Brian Rupnow General Engine Discussion 19 07-09-2009 03:47 PM
Small Flat Belts Supplier [ UK ] Bluechip The Break Room 0 01-03-2009 08:57 AM
