Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > Gloves: blue nitrile, safe?
Old 10-31-2012, 08:01 PM   #1
digiex-chris
digiex-chris's Avatar
Liked 60 Times on 54 Posts
Likes Given: 15
Default Gloves: blue nitrile, safe?
I know that using a leather or mechanic's glove is dangerous, but I think using the blue nitrile or vinyl gloves should be fairly safe. I've had tonnes of these gloves fall apart when I ask them to stand up to automotive mechanic's abuse, and the other day a long curl snagged and tore one glove on my drill press without any ill effect, not even a tug. I often don't realize they've snagged something and tore until I feel the ATF or grease inside the glove. I tried them with my lathe, and notice I get far fewer of the tiny metal slivers I often get and none of the black hands from turning the cranks. Quite enjoying it. I can't see how they'd ever stand up to being snagged and pulling my hand into the machine, they just fall apart too easy. Thoughts?
digiex-chris is offline
Old 10-31-2012, 08:28 PM   #2
MuellerNick
Liked 189 Times on 127 Posts
Likes Given: 21
Default
Vinyl? You mean PVC? That's a thermoplast, big fun if it melts into your skin. NOT!
Soap is cheaper.
You only have to touch the slivers that are harmless, and stay away from the pointy ones. In case, I know where my tweezers are.
I hate gloves at work.
Nick
MuellerNick is offline
doc1955 Likes This
Old 10-31-2012, 09:14 PM   #3
bret4
Liked 9 Times on 6 Posts
Default
I would not ware any gloves while running a machine. The fact that you are asking is enough to tell you that it isn't worth the risk.
bret4 is offline
doc1955 Likes This
Old 10-31-2012, 11:58 PM   #4
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Default
Chris: Your shop you make the rules.
I wear gloves at work most of the time. leather for most applications or nitrile when leather would get quicly ruined or i need the feel. Also when I am in a lab and the hazards are chemical rather than physical.
While nitrile will tear fairly readily I would not wear them around machines. Is it worth the risk that one time the glove does not decide to tear before the machine tool tears into your finger. sometimes it is a matter of miliseconds or thousands of an inch that makes the difference between a near miss and a serious injury.
I know I have trimmed fingernails with a trim router not on purpose mind you . NO blood no harm just a very short fingernail. But for the grace of god and quick reflexes it could have been to the bone.
OSHA rules do seem silly sometimes but remember they were written in blood. For every rule written dozens were hurt or someone died.
You may want to try liquid glove or some other similar protective hand cream.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
davedfsme Likes This
Old 11-01-2012, 01:28 AM   #5
Lance
Liked 6 Times on 4 Posts
Default
As a professional mechanic I can tell you that they do tear easy, BUT they also grab and like to get wound up, with amazing strength when using impacts, and air ratchets. I'm new to this hobby, but I would not wear them around my machine.
Lance is offline
2
People Like This
Old 11-01-2012, 12:59 PM   #6
crankincraig
Liked 5 Times on 3 Posts
Likes Given: 3
Default
As the supervisor of a student machine shop our rules say ; No Way.
No gloves of any kind allowed while useing machines.
crankincraig is offline
doc1955 Likes This
Old 11-01-2012, 06:58 PM   #7
digiex-chris
Likes Given: 15
Default
That is all the warning I need. Thanks for that. No gloves then.
RollaJohn Likes This
Old 01-01-2013, 12:18 AM   #8
srgtherasta
Liked 6 Times on 2 Posts
Default
Take one of them gloves, twist one of the fingers around like string and see if you can tear it. bet you can't. I have seen it happen to a fitter at work on a pillar drill. Don't it makes a woeful mess to clean.
srgtherasta is offline
Old 01-01-2013, 06:21 AM   #9
wm460
wm460's Avatar
Liked 14 Times on 12 Posts
Default Once Bitten Twice Shy
No glove for this boy any more:
I was putting a bit CA to fill in a couple of voids in a pen blank, I had a plastic bag that a pen part came in on my index finger, holding the end with my thumb, when some how it wrapped its self around the mandrel.
It pull the glove off my and dragged my fingers around the mandrel, fortunely for me it stalled the lathe.
I would have been buggered if I had my big Vicmarc then.
end result was a cracked pen blank, bent mandrel and almost dirty undies.
The glove is just an examination glove a lot thinner and weaker than the nitrile gloves.
Mark
wm460 is offline
2
People Like This
Old 01-01-2013, 04:52 PM   #10
kvom
kvom's Avatar
Liked 605 Times on 483 Posts
Likes Given: 275
Default
I use these gloves, but only for oil changes and grease jobs on vehicles.
kvom is offline
Source for Nitrile or Viton Balls portlandron General Engine Discussion 5 01-30-2012 01:49 AM
Nitrile O'Rings robwilk General Engine Discussion 7 04-14-2011 07:29 PM
Safe alternative to fly cutter? compressor man Tools 10 05-26-2010 01:38 AM
Safe Chuck Speeds 1hand General Engine Discussion 3 03-01-2010 11:14 PM
Drive Safe 1Kenny General Engine Discussion 1 12-22-2007 03:22 PM
