Hi!
Today, I had a break-trough with casting a center-piece of my scale Diesel engine. For me, that's a milestone. And enough reason to show off!
About the engine:
This is a 200 hp Diesel engine off the "DM"-series. DM stands for Diesel Motor. It was built by MAN. The DM series was the second generation of diesel engines that were sold in volumes and they were the first ones that worked quite reliably. There were different sizes. To my knowledge a DM 8 (8hp), DM 50 (50 hp) DM 75, DM 100 and DM 200. At least the bigger ones (starting from DM 50) were available in 1, 2, 3 and 4 cylinder configurations.
My model is a 2 cylinder version with 200 hp (100 hp per cylinder).
These engines worked with compressed air injection.
How that project started:
January 2005, I got a tip that there is an old Diesel engine at Passau. I found a tiny picture and decided to have a look at it.
Having seen it, I realized that this will be my next project.
I tried to get plans from MAN's archive, but they no longer had them. They lost all of them during a fire.
But I'm stubborn!
I contacted the municipal works (owner of the engine) and asked for permission to take dimensions. They were NOT happy. It took some time, and then they allowed me to take pictures, dimensions and even step on the engine.
Together with a friend, we went there. 'Till noon, we sticked about 1500 dots onto the engine, took pictures from all perspectives (IIRC 200) and removed the dots again.
200 hours of photogrammetry work followed ... even more hours on the CAD. And endless hours hunting for books that showed something of the internals.
The result will be a model in scale 1:10.
Here is a picture of the original engine:
You can see the dots that were sticked onto masking tape to increase contract.
And one that shows a detail of the cylinder head. Just so you can imagine the work involved to re-model all those points.
It didn't take too long for me to realize, that I will fail with my equipment and my knowledge.
So I bought a used and MAHO MH 700 C mill with a broken controll and replaced that with LinuxCNC.
Bought a Myford cylindrical grinder and completely restored it. Bought X and Y and Z and repaired it.
Then, finally, when I realized that I somehow forgot what I initially wanted to do, started with castings. That was spring of 2011. Built furnaces (2 of them have retiered), built a muller, built a core sand mixer, built ... ahhhh ... tools to make tools to make tools!
Long story short. Here is my A-frame I succeeded in casting today:
These are the cores that go inside. I had to mill channels as gates and a pool that takes the first shot of cold pour.
This casting has a split pattern with two loose inserts and 7 cores. These cores are made out of 10 parts.
Wall thickness is 3 mm in most places!
I'll show more pictures. But now it's time to go to bed. Will have an other casting session tomorrow and take the chance to show more castings I have made.
If you do have questions, feel free to ask!
Nick
