Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Adjustable mill table stops
Old 09-05-2012, 09:30 PM   #1
wheeltapper
Senior Member
Liked 34 Times on 31 Posts
Default Adjustable mill table stops
Hi
I posted this over at MadModder and thought you might like to see it here.
I just fitted some adjustable stops to my Chester Conquest mill and thought you might like to see.
I've seen this done somewhere on the web but I can't for the life of me remember where, so I can't take credit for the idea.
This is the Y travel fitted on the l/h side
and the X travel fitted on the rear
I killed two birds with one stone here as the table movement has always been stiff and jerky, if I set the gibs in the centre of travel they locked up at the ends and adjusting at the end meant they flopped about in the centre.
So I stripped the tables right down and polished the gibs and dovetails and got it a bit better but they still got tight at the ends.
then I realised that not only do they slide against the dovetails but also against the bottom surface
marked in this pic
and although the sliding surface on the underside of the tables was smooth and polished the surfaces in the pic looked like they had been hacked flat with a chisel.
also the ends were slightly higher than the middle.
so, a quick touch with a fine file followed with a diamond hone and I had smooth travel all the way.
Roy
I used to be confused, now I just don't know
wheeltapper is offline
Old 11-05-2012, 09:55 PM   #2
Philipintexas
Liked 60 Times on 47 Posts
Default
I've been playing with ideas on this subject and I like your approach. Now if I can incorporate a DRO it will be complete. Great idea.
Philipintexas is offline
Milling Table Stops cfellows Machine Modifications 17 08-19-2012 05:51 AM
table heigth on mill ozzie46 Tools 4 03-10-2012 05:28 PM
Adjustable Mill Stop. Arnak Machine Modifications 6 07-30-2011 10:11 AM
X2 mill - xy table problem Kermit General Engine Discussion 5 03-15-2010 04:20 AM
MILLING MACHINE TABLE TRAVEL STOPS Brian Rupnow Machine Modifications 21 11-07-2009 12:40 AM
