Project of the Month built by driller1432
Home Model Engine Machinist > The Tools and Tips > Tools > Homemade Spot Welder
Old 09-03-2012, 01:38 PM   #1
Ruy
Liked 10 Times on 3 Posts
Default Homemade Spot Welder
Hello all. I want to present my Homemade Spot Welder.
Uses two transformers of microwave.
General View
Inside view
Wrapping the secondary
Fan cooling
Contactor
Welding Clamp (Side)
Ruy is offline
akitene Likes This
Old 09-03-2012, 01:45 PM   #2
Ruy
Default
Welding Clamp
Secondary Cables
Timer
I get an amperage of around 1000A.
Welding stainless steel plate of 0.8mm to 1mm thickness perfectly.
Thanks to all
Ruy is offline
7
People Like This
Old 09-03-2012, 03:35 PM   #3
rkepler
Liked 31 Times on 26 Posts
Likes Given: 4
Default
Impressive performance and very nicely put together, great work!
rkepler is offline
Old 09-04-2012, 12:21 PM   #4
Lockstocknbarrel
Lockstocknbarrel's Avatar
Liked 21 Times on 13 Posts
Default
Ruy,
Very Professional, that is impressive, electricity and me have never got on at all, you only have to look at my sidecutters.
Kindest Regards
Beagles
Lockstocknbarrel is offline
rodw Likes This
Old 09-04-2012, 12:46 PM   #5
hi speed scrap
Junior Member
Liked 17 Times on 10 Posts
Default
I like that Ruy! beautifully done,
I need a small one just like that for my future turbine project.
hi speed scrap is offline
Old 09-11-2012, 09:11 PM   #6
rtp_burnsville
Liked 4 Times on 4 Posts
Default
Hi,
Interesting project..... Do you happen to have a schematic?
Thanks,
Robert
rtp_burnsville is offline
Old 02-15-2013, 10:36 AM   #7
kj66ro
Default
Hello Ruy.
My name is Roger, could you provide the schema of the electronic part of the welding machine. Which parts used in the circuit
I visited your page about handmade knives but could not find the contact email
att
Roger
kj66ro is offline
Old 02-15-2013, 12:49 PM   #8
ROBERTBRUCE
Default
Very impressive.
I could do with one of those, particullary as i have a broken 700 watt microwave (electronic timer broken)
sitting in the barn.
Do you have any further details
regards
rbk
ROBERTBRUCE is offline
Old 02-15-2013, 09:01 PM   #9
Lockstocknbarrel
Default Plans or Build log.
Olá Ruy,
Como você pode ver, existem vários membros perguntando se você poderia ajudar ou fornecer os planos para o soldador local, é uma construção muito profissional.
Eu gostaria de planos, se você pode publicá-las.
kindest Atenciosamente
Beagles.
Hello Ruy,
As you can see there are several members asking if you could help or supply the plans for the Spot welder, It is a very professional build.
I too would like plans if you can post them.
Kindest Regards
Beagles.
2
People Like This
Old 02-16-2013, 10:32 PM   #10
Ruy
Default
As soon as possible I post the plans for the machine.
Ruy is offline
2
People Like This
Tig Welder 1hand Tools 43 12-22-2011 12:28 AM
Need welder recommendations BrianS General Engine Discussion 28 07-27-2011 03:57 PM
VMC - Spot the difference! Omnimill Machine Modifications 8 07-10-2010 12:29 AM
Cigweld Transmig 130 Twin Gas/Gasless mig welder. wm460 General Engine Discussion 2 01-19-2010 11:17 AM
Welder and Plasma Cutter Tech macona General Engine Discussion 4 10-15-2008 07:14 AM
