Project of the Month built by deeferdog
Home Model Engine Machinist > CNC and 3-D Printers > Software and Programming > Mastercam Mill 9.1
Old 07-23-2012, 03:19 AM   #1
azroyhelmy
Liked 2 Times on 2 Posts
Default Mastercam Mill 9.1
Hi guys,
I quite new to the CAM. I'm using 3 axis Fanuc controller mill and 9.1 version of mastercam.
My question is, how can i control my cutter wear? e.g : I'm ramping a 1" hole to 0.5" depth. my finishing cutter should make the last cut of 1" diameter at 0.5" depth. after checking the hole, the diameter is small of 0.0039".
So how can i used the 'wear' in tool offset controller? i tried before but the controller triggered an alarm not to do that. should i change the program? If so can anybody direct me to which i should select my 'offset' in Mastercam ?
Tq
azroyhelmy is offline
Old 07-23-2012, 08:10 AM   #2
mulac321
Liked 4 Times on 4 Posts
Default
Hi there are a few cnc experts on this forum but the best place for thousands of experts is the cnczone.com forum. I believe they have a dedicated section just for master am.
Calum
mulac321 is offline
Old 07-23-2012, 10:36 AM   #3
azroyhelmy
Default
thanks Calum
Old 07-23-2012, 11:59 AM   #4
kvom
kvom's Avatar
Liked 602 Times on 481 Posts
Likes Given: 249
Default
You could adjust the tool diameter in MC and regenerate the g-code.
The best source for info on Fanuc controller issues, IMO, is to register on Practical Machinist and ask your question. Be sure to specify the exact controller model.
kvom is offline
Old 07-23-2012, 12:26 PM   #5
idahoan
idahoan's Avatar
Liked 186 Times on 99 Posts
Likes Given: 59
Default
Tq
I'm running a rewer version of Mastercam (X5) and in the cut parameters dialog there is box for stock to leave on walls and one for stock to leave on floors. these can be set to a plus or minus value; so in your case you would enter -.002 as this value would only be for the radius. I'm not sure about the older version; but it may have somtining like this.
I assume that you are using a roughing and then finishing cutter?
idahoan is offline
Old 07-25-2012, 02:07 AM   #6
azroyhelmy
Default
Yes Dave, I running on different roughing and finishing cutter. Yes, there are dialog boxes for leave stock allowance in mastercam. but , we just don't know the cutter wear, spindle run out and etc that affect the final dimension. so it's quite hard to redraw and repost again to the controller.
I'm running cnc lathe too, and it's more convenient as all tools offset can be adjust freely.
Old 07-25-2012, 10:19 AM   #7
Aquaman
Default
There's a box... "Compensation type" I think it defaults to "Computer" click it and you'll see "Control"...."Wear"....etc.
You want to use "Wear" and re-generate the path. Post it and see if it outputs G42 and/or G43.
If your post is working correctly and it outputs the codes you should now be able to use the offsets on the control to make tool diameter offset changes.
Play with it a little on a scrap part.
Regards...
Aquaman is offline
azroyhelmy Likes This
Old 07-30-2012, 01:10 AM   #8
azroyhelmy
Default
Thanks Aquaman, I believe I get it. But when it come to ramping a hole, the controller still not allowed any value in 'wear' column of the controller offset.
Old 07-30-2012, 01:08 PM   #9
Aquaman
Default
See if you can figure out what "options" are turned on in your control.
In my experience, the controls come built with all the options included and the re-seller turns on those options that you pay extra for....
If something called "Helical or Tornado" isn't turned on in the control its probably not going to work and you'll have to use Circle Mill or the regular contour path in order to use your control offsets.
Try clicking "Compensation type" and "Control" and re-gen your path and post it.
You just have to fool with it until you get the machine to do what you want.
An easy way to size the hole is to just draw another circle that's .0039" larger than the one you just cut and drive the tool on the new circle as the finish path.
Whatever gets the hole to the size you want it to be......
Regards...
Aquaman is offline
Old 07-30-2012, 10:53 PM   #10
atheras29
Default
Originally Posted by azroyhelmy View Post
Hi guys,
Tq
Hi
Post from Master Cam the existing post again and before sent it to mill change the diameter of the existing # tool under description of tool
( make it smaller off .0039'')
second line under the first G codes
if you have any problems please post a picture of the post to help you
good luck
Dimitrios
atheras29 is offline
Mill-rite mill rebush Tools 4 05-11-2012 11:58 PM
Mastercam kustomkb Software and Programming 14 01-14-2010 01:25 PM
Tramming a small mill (Sherline mill) ttrikalin Tips and Tricks 9 11-22-2009 06:58 PM
Mastercam X2 help. Speedy Software and Programming 1 05-13-2009 11:44 AM
wanted mastercam book Speedy Buy / Sell / Trade / eBay 2 06-14-2008 10:13 PM
