Home Model Engine Machinist > Building Them > Engines From Castings > Small Gas Engine
Old 06-30-2012, 09:06 PM   #1
mhirst121
Liked 9 Times on 4 Posts
Default Small Gas Engine
Hello all, while attending the 1000 engine rally here in the UK I came across these castings for a small gas engine. The large parts had been machined and a few items were included with the castings. It is always a risk buying castings that have been machined as to whether they are correct or not, luckily these measure up fine to the drawings.
The engine is not a model but a full size engine. The bore is 61mm and the stroke is 80mm. The flywheel is around 14" in diameter and 2" across the face.
Although it is not a model, It is a Klein gas motor of German manufacture, I thought some of you would like to follow my trials and tribulations in a build log for it.
I will be ran on propane and have hot tube ignition, it has sideshaft driven cams that operate the valves. I may also fit a CDI ignition unit and spark plug so that the engine can be run outside if it is windy.
Let me know if you think a build log would be of use to anyone.
A few pics of the castings below, the vernier in front of them is 6" and should give some idea of the physical size of the engine.
MartinH
mhirst121 is offline
Old 06-30-2012, 09:23 PM   #2
vcutajar
vcutajar's Avatar
Liked 156 Times on 127 Posts
Likes Given: 43
Default Re: Small Gas Engine
Hi Martin
I have pulled a chair and will follow you on your journey. Hope you do not have any missing castings.
Vince
vcutajar is offline
Old 06-30-2012, 09:29 PM   #3
mhirst121
Vince what you see in the pictures is all I got, the sideshaft perch brackets and the mains caps will have to be machined or fabricated. Shouldn`t be too much of a problem, the mains caps will be a bit more work as one half is already machined, will have to match the caps up to them.
MartinH
Old 07-01-2012, 12:29 AM   #4
rebush
Liked 9 Times on 9 Posts
Martin: Can't wait to see where this leads. I'm sure it will be interesting. Roger
Hopelessly lost but making darn good time.
rebush is offline
Old 07-01-2012, 12:49 AM   #5
Don1966
Senior Member
Don1966's Avatar
Location: Morgan City, Louisiana ( along the Gulf Coast)
Liked 39 Times on 39 Posts
Likes Given: 7
Any engine built is interesting to me, I will follow you on your venture it looks like a real educational venture to me.
Don
How Many times I did that?
Don1966 is offline
Old 07-01-2012, 06:31 AM   #6
Jasonb
Jasonb's Avatar
Liked 425 Times on 267 Posts
Likes Given: 18
I'll be watching, always a softie for a gas engine.
It's a pity there is not more metal on the lower bearing housings as you could have made the tops and then bored oversize and bearings to suit, maybe there is still room for a light skim?
J
Jasonb is offline
Old 07-02-2012, 08:03 PM   #7
mhirst121
Right then, let the fun begin. I like to work from castings, don`t know why I just do, so with this in mind I decided to make the parts I felt should have been in a complete set of castings. With this in mind I thought I would start with the sideshaft perch brackets.
Blocks of steel for brackets
Blocks machined square and to required size
Marked out
Excess cut out on the bandsaw
Step milled to size
Recess for cap machined
Cap block machined to fit main part
Drilled and tapped for screws
Ready for the lathe
Centred in lathe ready to cut first face and bore
First face done and bored to size
cap screw faces machined
Finished cap
Bracket mounting holes drilled and marked out and cut to lines of finished size
Finished brackets
And test fit to the engine
I will tidy them up a little more with a file to make them look a little more like castings. Well thats a start anyway.
MartinH
Old 07-02-2012, 11:32 PM   #8
Herbiev
Herbiev's Avatar
Liked 289 Times on 245 Posts
Likes Given: 97
Thanks for sharing Martin. Looking forward to next instalment
Herbie
Hallett cove
South australia
Herbiev is offline
Old 07-03-2012, 01:00 AM   #9
idahoan
idahoan's Avatar
Liked 189 Times on 101 Posts
Likes Given: 60
Great stuff Martin,
Please keep posting your progress on this neat little engine.
How will it be fired? Hot Tube maybe?
idahoan is offline
Old 07-03-2012, 01:04 AM   #10
idahoan
idahoan's Avatar
Likes Given: 60
Oops, Sorry; I went back and read your original post where you said that it would be hot tube
idahoan is offline
A small steam engine firebird A Work In Progress 299 10-18-2012 08:31 PM
Engine For a Small Generator chopsuwe Plans 3 05-13-2011 11:04 PM
Small V12 engine boatmadman General Engine Discussion 9 03-04-2011 09:21 PM
Small Vertical Engine Nave Photos and Videos 6 09-03-2010 09:24 AM
Very small engine Chris333 Plans 18 02-10-2010 09:17 PM
