Project of the Month built by Stefan-K
Home Model Engine Machinist > Building Them > Engines From Castings > Stuart Turner boiler feed pump
Thread Tools Display Modes
Old 06-12-2012, 03:44 PM   #1
Marty Feldman
Liked 5 Times on 2 Posts
Default Stuart Turner boiler feed pump
Has anyone here done the little S-T pump? I have a question about the function of a steam passage shown on the print.
-Marty, in Owl's Head, Maine-
Marty Feldman is offline
Old 06-14-2012, 10:06 AM   #2
engjas
Liked 2 Times on 2 Posts
Default Re: Stuart Turner boiler feed pump
Hello Marty
I've recently acquired some castings for the Stuart Pump and am also puzzling out how it works and how to machine the parts.
The drawing I have is #90085 and is dated 26 November 1976. There are however differences in dimensions and methods between the casting set I have and this drawing.
If you can identify the passages I'll try and help with the explanation.
engjas is offline
Old 06-14-2012, 06:03 PM   #3
arnoldb
arnoldb's Avatar
Liked 92 Times on 177 Posts
Hi Marty
If you can add an image of the section on the print showing the part with the mystery passage, it will help others to help you.
Kind regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Old 06-14-2012, 10:13 PM   #4
rhankey
rhankey's Avatar
Liked 37 Times on 31 Posts
Do post a section of the drawing and circle the passage way you are unsure of. If it is the manual feed pump to which you refer, it can't be too difficult for us to figure out. I might also be able to figure it out based on the plans for the Stuart triple that I'm building which includes two pumps (water and air). The pumps on the triple look a little different than the manula feed pump, but I suspect they function pretty much the same internally. Other than being unsure how much clearances to allow for the pistons, I have had no trouble decoding the drawings and the vrious passage ways.
Robin
rhankey is offline
Old 06-15-2012, 04:50 AM   #5
rklopp
Liked 21 Times on 19 Posts
If you mean the single cylinder steam driven pump, I built one years ago. I have the plans stashed someplace, so fire away with questions.
rklopp is offline
Old 06-26-2012, 05:58 PM   #6
Marty Feldman
The pump is a single cylinder steam pump. The 2 pictures below are from the print that came with the Stuart turner castings. It does not have a number or a date, but it is an original ST print.
The upper picture shows the valve chamber. A mystery to me has to do with the 'T' shaped passage I have hand-colored in red, somewhat faintly, on the left side of the drawing. The short vertical stem of the 'T' is the steam-in to the pump. The longer horizontal part of the 'T' shows two very small holes, one on the left and one on the right, drilled at right angles to the longer horizontal part of the 'T'. They look like little black dots on the print. What are those 2 holes for?
The second of the two pictures shows the cylinder to which the valve chest mates.
Sorry about the miserable resolution of the photographs. I can no longer get Photobucket to behave as it used to. Doing a digitized scan of the print might be the right avenue for conveying a clear image.
Old 06-26-2012, 07:37 PM   #7
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 528 Times on 398 Posts
Likes Given: 38
MF,
Having blown them up a little and sharpened as well, it is still rather difficult to read.
The conclusion that I came to is that it is the steam inlet (the small piece of the 'T') and a spool (piston) valve goes into the long part of the 'T'.
As the piston valve is moved in and out by the piston rod of the main cylinder (going to the pump itself) it will feed steam to either end of the cylinder, making the piston go in and out. Basically, a piston valve engine.
So turn on steam, and the unit will just go backwards and forwards, driving the pump on the other end of the main piston rod, whilst at the same time, moving the spool valve so that feeds steam to the top and bottom of the piston and so on and so on and so on......................... continuous motion, and water pumped, until steam is cut off.
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 06-26-2012, 11:35 PM   #8
Charles Lamont
Liked 84 Times on 65 Posts
Likes Given: 11
The valve worked from this piston rod controls a loose shuttle valve which in turn controls the steam distribution to the
cylinder. I have not made one of these (though I have often thought of doing so - some time) so I cannot be of more help without
a better look at the drawings, including the valves.
This may help a bit:
http://www.modelboatmayhem.co.uk/for...?topic=29412.0
Charles Lamont is offline
Old 06-30-2012, 11:15 AM   #9
KBC
Junior Member
KBC's Avatar
Liked 45 Times on 29 Posts
Likes Given: 4
Hi Marty,
In answer to your question ( WHAT ARE THE 2- HOLES FOR ) the 2- holes that you wish to know about are exhaust ports, they link up to the 2- holes on the face of the cylinder and connect to the exhaust outlet via the 'T' shaped dotted drilled holes going to the 3/16 x 40 tapped outlet.
If you look on the cross sectional plan of the steam chest the 2- 20deg holes coming in from each end of the 1/4" dia shuttle valve hole this carries the exhaust from the piston up thro" the shuttle valve and then transfers to the cylinder exhaust holes.
When you make the 5/32" dia auxiliary valve keep the edges a sharp as possible with dimensions strickland to the drawing, like wise on the shuttle valve.
Hope this answers your question.
Geo.
KBC is offline
stuart turner 4000 boiler dunc2504 Boilers 5 05-10-2012 09:50 PM
Boiler feed pump (cylinder bore v pump bore) question syrtismajor Questions and Answers 2 09-28-2011 06:39 PM
Southworth Boiler Feed Pump SBWHART Engines From Castings 6 04-24-2011 04:55 PM
Boiler feed pump Steam4ian Plans 8 10-24-2009 10:13 AM
Aus ebay STUART TURNER BOILER FEED PUMP Davo J Buy / Sell / Trade / eBay 2 02-22-2009 09:28 PM
