Home Model Engine Machinist > Showing Them > Finished Projects > Elmer's Grasshopper #37 Engine
Old 05-14-2012, 05:57 PM   #1
Inky Engines
Inky Engines's Avatar
Liked 46 Times on 23 Posts
Likes Given: 23
Default Elmer's Grasshopper #37 Engine
As promised, I've put together a video of the latest Elmer Verburg engine from the Inky Engines stable. It joins the wobblers and beam engine, videos of which were attached to my recent Newbie posting.
Please excuse my attempt to show pressure on the gauges ..... an expensive computer, excellent eyesight and quick reactions on the pause are probably necessary to read the dials on the video .... for anybody interested at slow tickover the engine is running on 1.5 psi at 166 rpm whilst on 7.5 psi it runs at 722 rpm ... full scale deflection on the left hand gauge is 15 psi and that on the right 60 psi ... I bought the 15 psi gauge upon realising that with the Elmer's engines I was building the needle barely moved on the 60 psi gauge. The grasshopper will of course run faster, but this is not imho appropriate for a beam engine!
Now the grasshopper is consigned to the mantlepiece I will concentrate on completing Elmer's #33 Mill and #41 Factory Engines. I'm building these as a pair and may let them run together as a quasi twin cylinder slide valve set up ... not exactly realistic, but fun!
Kind regards
Geoff at Inky Engines
Inky Engines is offline
OregonBill Likes This
Old 05-14-2012, 06:04 PM   #2
mklotz
mklotz's Avatar
Liked 140 Times on 260 Posts
Default Re: Elmer's Grasshopper #37 Engine
Well done, indeed. A beautiful model.
I must agree with you. Beam engines are not meant to be run fast. Stately and elegant, not frenetic, is the way to go.
Regards, Marv
Home Shop Freeware
http://www.myvirtualnetwork.com/mklotz
mklotz is offline
Old 05-14-2012, 06:05 PM   #3
b.lindsey
b.lindsey's Avatar
Liked 63 Times on 62 Posts
Beautifully done Geoff!! It obviously runs well and the finish is superb!! Well done...already looking forward to your next ones
Bill
skype: william.lindsey.iii
b.lindsey is offline
Old 05-14-2012, 06:06 PM   #4
dgjessing
dgjessing's Avatar
Liked 38 Times on 37 Posts
Looks great! Well done
dgjessing is offline
Old 05-14-2012, 06:34 PM   #5
lazylathe
lazylathe's Avatar
Liked 25 Times on 25 Posts
Another great engine Geoff!!!!
Runes beautifully, especially at the slowest speed!!
Those engines look grand when they are able to just tick over!
Fit, finish and presentation are amazing!!
Congratulations!!
Andrew
The best part about procrastination is that you are never bored, because you have all kinds of things that you should be doing.
Time is money, money is the root of all evil, and knowledge is power. Therefore, procrastination is the key to world peace.
lazylathe is offline
Old 05-14-2012, 06:54 PM   #6
Troutsqueezer
Troutsqueezer's Avatar
Liked 32 Times on 51 Posts
First class. Should look real nice up there on the mantle.
-Dennis-
Once you see the bandwagon, it's too late.
Troutsqueezer is offline
Old 05-14-2012, 07:41 PM   #7
90LX_Notch
Liked 41 Times on 41 Posts
Geoff,
Very well done. The video presentation is one of the best I've seen with the transitions from the plans, to the raw stock, machined parts, assembly and running of the engine. Very nicely done.
90LX_Notch is offline
Old 05-14-2012, 09:15 PM   #8
Sshire
Sshire's Avatar
Liked 267 Times on 167 Posts
Likes Given: 3
Beautiful execution. Great runner. The Grasshopper was my 2d engine and one of my favorite builds.
Very nice base.
Best
Stan
Best,
Stan
Philadelphia, PA
USA
Sshire is offline
Old 05-15-2012, 07:44 AM   #9
arnoldb
arnoldb's Avatar
Liked 93 Times on 178 Posts
A very nice build of the Grasshopper indeed
I like your use of the nylock nuts on the pivot pins
Kind regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Old 05-17-2012, 02:41 PM   #10
Inky Engines
Likes Given: 23
Gentlemen .....
Thank you for your encouraging comment ... it is very much appreciated. Noted in particular that both Stan and Arnold have built the same engine.
Iím pleased, but not surprised to hear that you take most pleasure from seeing beam engines such as this run slowly. Notwithstanding, it is perhaps necessary to run the models at both slow and high speeds to assure oneself of the quality of build ... Iíve had engines running well at slow speed, but presenting problems at high, and vica versa.
Arnold ....
... the Nylock nuts on pivot pins! I agonized over these for some time ... they are not exactly authentic. Elmer Verburg does however use a lot of these small pins secured by even smaller pins which are not only a pain to make, but moreover can be fiddly when dismantling and reassembling the engine .... hence my change of approach to M2 and M2.5 threaded pins and Nylock nuts ... I remanufactured such pins for Elmerís Beam Engine #24 which is about half the size of the Grasshopper, and they look fine.
As an aside, I note that on your Tall Vertical Open Column build you dismiss use of cheese-head screws on the finished engine .... I think most would agree, no slotted screws (although Darren uses them on his very nice virtual engine!). Leads then to the question as to what fixing finds general favor? I have tended to use button head socket screws, more from habit than any logic. Iíve considered cap head socket screws, and noted that size for size they use a larger socket key than the button head screws ... less likelihood of damage to the socket and key perhaps, but maybe more of a tendency to strip aluminum threads? Studs and hexagon nuts seen to be the other option ... on some models they look superb, on others less so ... maybe Iíll try these next, but for now its another Elmer 3Ē spoked flywheel for the Factory Engine.
Kind regards
Elmer's Grasshopper first run Sshire Photos and Videos 8 05-05-2012 04:27 AM
Elmer's grasshopper question Sshire General Engine Discussion 3 02-26-2012 10:12 PM
Arnold's take on Elmer's Grasshopper arnoldb A Work In Progress 119 02-10-2011 05:59 PM
Elmer's Grasshopper skipp48 A Work In Progress 4 09-29-2010 02:08 PM
Elmer's Grasshopper Engine rake60 Photos and Videos 10 08-02-2007 07:46 PM
