Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > Example of 3D Printing
Old 05-01-2012, 05:55 AM   #1
SBWHART
SBWHART's Avatar
Liked 194 Times on 178 Posts
Default Example of 3D Printing
A ex work friend bought himself a 3D printer and asked me if I had anything that would be suitable that he could use that showed the off the printers capability to produce molding paterns, well i didn't so I contacted Rob Willson and he kindly provided a 3D drawing of a cylinder patern.
This is the result
Aparently the printer is not unlike a CNC router but instead of a cutter it has a plastic injecting nozle, you first have to convert the 3D drawing into G code as used for CNC, this is used to drive the printer that builds up a matrix of plastic to form the patern.
Neat hey
Stew
A little bit of clearance never got in the way
SBWHART is offline
Old 05-01-2012, 12:06 PM   #2
Herbiev
Herbiev's Avatar
Liked 285 Times on 242 Posts
Likes Given: 92
Default Re: Example of 3D Printing
Totally awesome
Herbie
Hallett cove
South australia
Herbiev is offline
Old 05-01-2012, 02:57 PM   #3
lazylathe
lazylathe's Avatar
Liked 25 Times on 25 Posts
Hey Stew,
Do you have that file in .stl format?
If you do could you upload a copy of it?
I can print off a copy here and show the results using our rapid prototyping printer.
Andrew
The best part about procrastination is that you are never bored, because you have all kinds of things that you should be doing.
Time is money, money is the root of all evil, and knowledge is power. Therefore, procrastination is the key to world peace.
lazylathe is offline
Old 05-01-2012, 03:23 PM   #4
rhitee93
rhitee93's Avatar
Liked 70 Times on 57 Posts
Likes Given: 27
Spooky. Just yesterday I sent some files for a pattern to cast an Elmer's #29 cylinder to the guy who runs our 3D printer. I'll post some pics when I get them.
Our machine is not and FDM (Fusion Deposition Modeling) machine like the original post, but uses an UV cured acrylic. the resulting parts are not as strong as the ABS parts from an FDM machine, but have a better surface finish.
We also send a lot of parts out to be made on a sterolithography (SLA) machine. Those parts have a very good finish, good tolerances, and there is a wide variety of material options.
-Brian
rhitee93 is offline
Old 05-01-2012, 03:48 PM   #5
lazylathe
lazylathe's Avatar
LOL!!
We have two Projet DP 3000 printers here.
Also using a light cured acrylic material with a paraffin wax used for support.
Great surface finish and extremely accurate.
We use them to print all of out metal denture frameworks which are then cast in an induction machine.
Andrew
Old 05-01-2012, 04:15 PM   #6
rhitee93
rhitee93's Avatar
Likes Given: 27
That is funny, we have the SD3000 form the same company
-Brian
rhitee93 is offline
Old 05-01-2012, 04:54 PM   #7
jolijar
Liked 3 Times on 3 Posts
You can get a DIY version of the commercial printers for around $500-1500 they work pretty well. The detail and tolerances isn't as good and you cant have big overhangs...
lots of users post stuff they made on this site
http://www.thingiverse.com/thing:9166
this is one of the items I designed and printed for a friend of mine. Made out of ABS plastic
I recommended checking out the makergear printers they are pretty much the best of the best when it comes to home printers.
http://www.makergear.com/products/m-series-3d-printers
If it ain't broke fix it till it is.
jolijar is offline
Old 05-01-2012, 05:06 PM   #8
JorgensenSteam
Guest
Posts: n/a
The inexpensive 3D printers don't seem to be very reliable, can be extremely slow, may not have very good software, and the parts generally have rough surfaces.
The expensive 3D printers work well, but the equipment and material costs are astronomical to say the least.
Below is a 3D print from a $25,000 machine.
Sometimes you can farm out the 3D printing if you can get a cheap enough quote.
The inexpensive 3D printers don't seem ready for prime time yet.
Also, be aware that a raw 3D model is usless as a pattern.
You have to consider such things as shrinkage, parting surfaces, core prints, machining tolerances, draft angle, etc., etc.
Pattern making is an entirely different thing above and beyond making a 3D model.
Casting is yet another art, with gates, risers, flasks, green sand, etc.
R.Diesel Likes This
Old 05-06-2012, 07:41 PM   #9
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
There is a kid from the NEMMES group that has a rapman. the kit is currently 1495
he has had it on display at caben fever and the NEES shows.
site to ponder
http://reprap.org/wiki/RepRap
tin
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 05-06-2012, 11:33 PM   #10
warranator
Liked 4 Times on 4 Posts
Anyone had any dealings with this model 3d printer? For $550 bucks would be a good start to learn on.
http://store.solidoodle.com/index.ph...&product_id=56
warranator is offline
3D printing outfits? Lakc General Engine Discussion 10 08-31-2010 12:16 PM
3D Printing? rodbuilder The Break Room 17 05-11-2010 02:32 AM
Printing a drawing from AutoCad format gbritnell Software and Programming 12 11-09-2009 10:05 PM
