Project of the Month built by deeferdog
Home Model Engine Machinist > Whats Left? > The Break Room > Mudding Drywall
Old 03-05-2012, 02:04 AM   #11
woodnut
Liked 8 Times on 5 Posts
Likes Given: 4
Default Re: Mudding Drywall
The trick with drywall compound, the pre-mixed stuff is to add a bit of water to it. It's way to thick the way it is. I never use the stuff in the painting isle, it drys to hard and is almost impossible to sand after. Most people put it on too thick, I might have to do 4 coats, but there hardly any sanding.
John.
woodnut is offline
Old 03-05-2012, 04:10 AM   #12
Captain Jerry
Captain Jerry's Avatar
Liked 38 Times on 69 Posts
Also called sheetrock or wallboard.
If you think someone else can do it better then hire them, but if you want to do it yourself then here a list of tips
1. Use the WIDEST spreader you can, at least 4" but better 6" or 8", and keep the edge clean.
2. Apply mud to a slightly damp surface. Wipe with damp sponge first.
3. Spread it thin and wide. With a wide knife and good technique, there should be no visible marks or edges to
sand but if you want to be sure, sand VERY LIGHTLY with a damp foam backed sanding block and dunk the block in a bucket
of water periodically, to remove accumulations.
4. Keep the beer ice cold. Once you have opened a beer, do not resume working until you have finished the beer.
Jerry
There are things you can do and things you can't do.
I'm never sure which is which.
Captain Jerry is offline
Old 03-05-2012, 02:16 PM   #13
Stan
Liked 31 Times on 31 Posts
For all the little nicks, dings, nail holes, etc., I use Pollyfilla by Lepage or it's equivalent. It comes in a tube that you cut the end of the tip and just force a small amount into nail holes or a small amount on a putty knife to fill depressions. A quick rub with 80 grit after an hour and another swipe with a small amount on the putty knife. Ready to paint in two hours.
Unless you are painting with high gloss paint, don't use fine sandpaper. The very smooth surface will not hold paint like the paper surface on the sheetrock, or existing paint, and every patch will show up as a shiny spot on flat or semi gloss paint.
Stan in Leduc, Alberta, Canada. 53.40NĀ* 113.5W
Old, but still on the right side of the grass.
Stan is offline
Old 03-05-2012, 03:29 PM   #14
ShopShoe
Senior Member
ShopShoe's Avatar
Liked 96 Times on 87 Posts
A few years ago we were faced with a poorly-finished room left by the previous owners of our house. After opening the walls for more electrical and HVAC work and replacing doors with wider ones and retrimming here and there, we sanded off the worst of the old mud jobs, then "papered" the wall with a textured fabric that is sold for this purpose and is designed to be painted over itself. We then put in new baseboards and molding and painted it all. It worked surprisingly well without so much dust and without hours and hours of sand-mud-sand-mud-sand that would have been the case.
This has been shown on some of the D-I-Y TV shows here in the US and was everything it claimed to be for us.
--ShopShoe
ShopShoe is offline
Old 03-05-2012, 11:22 PM   #15
Tin Falcon
Tin Falcon's Avatar
Liked 812 Times on 646 Posts
Likes Given: 18
I have played with drywall and muddling for for pieces of close to 35 years my first project building my own bedroom when I was about 16. Ugly at best . When I was about 27 I bought a house a fixer upper. I had to dry wall what is now my shop the ceiling is 7ft on one side and slopes up to ten on the other. Much better results. the biggest project I worked on was a habitat house for friends from church. The whole family worked all summer virtually every Saturday until the house was done. The insulation was contracted out it was actually cheaper than buying insulation. we did the dry wall on the whole house the Kids helped put the mud on lot of sanding . I have learned with mud less is more the less you put on the less there is to sand. thin layers . The more work gets done faster.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 03-06-2012, 01:26 AM   #16
woodnut
Likes Given: 4
+1 for the wide spreader. Unless your in a tight area I use a 6" spreader. The biggest I have is 12", this one allows for some nice feathering. Keep your tools clean! Keep the edges of your good mud container clean as well, don't let the mud dry up on the sides as it will flake off and put lumps in your mud making it impossible to get good clean spread. When done for the day I scrap down the edges and throw that mud out, (unless i am sure there are no dryed spots in it), I usually use the pail of pre-mixed mud, level off the top and cover the mud with water to stop it from drying out between uses. Pour off the water and mix well before using the next day/time. To help the mud dry faster set up an oscillating fan in the room and point it at the area(s). Let it run over night. A heat gun will work, but can cause cracking.
I another trick I was taught was for screw and small anchor holes is to take the butt of your screw driver and grind it into the hole to making a dimpled area. This gives you a nice area to fill and keeps the little paper edges out of the way.
woodnut is offline
Old 03-06-2012, 01:43 AM   #17
Hilmar
Liked 11 Times on 11 Posts
Get the right mud, there are pots with a green and I think with a blue lid.
For different purposes.
Hilmar
Hilmar is offline
