Project of the Month built by Stefan-K
Home Model Engine Machinist > The Tools and Tips > Machine Modifications > ONE SHOT OILER
Thread Tools Display Modes
Old 03-01-2012, 06:29 PM   #1
crab
confused
crab's Avatar
Liked 17 Times on 17 Posts
Default ONE SHOT OILER
Here is a oiler I found doing a google search.It's for a X3 but would work on most any mill or lathe.
http://www.home-machine-shop.com/ONE...LER/index.html
Bill
Central California
crab is offline
Old 03-01-2012, 07:00 PM   #2
RonGinger
RonGinger's Avatar
Liked 112 Times on 86 Posts
Likes Given: 5
Default Re: ONE SHOT OILER
Its a nice neat tubing job, but it is not going to work well. He has no check or metering valves, so which ever line has the least resistance will get all the oil, nothing will go into the harder ones. And surely you cannot expect all the passages to have exactly the same resistance.
I want to do a one shot on my mills, but its the metering valves tha tmake it hard/expensive.
RonGinger is offline
Old 03-01-2012, 07:39 PM   #3
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 528 Times on 398 Posts
Likes Given: 38
Have a look at this page, it shows the correct way to do it, complete with metering valves.
http://www.arceurotrade.co.uk/Catalo...ication-System
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 03-01-2012, 07:53 PM   #4
dieselpilot
Liked 105 Times on 94 Posts
Likes Given: 3
What exactly does the metering in the valve?
dieselpilot is offline
Old 03-01-2012, 07:57 PM   #5
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Likes Given: 38
They make all the oil lines have the same back pressure, so a line with low back pressure (big open fits) won't get all the pumped oil. They should all get the same amount.
Old 03-01-2012, 08:23 PM   #6
dieselpilot
Likes Given: 3
So it's just an orifice or something more like a pressure regulator that would include check valve action. OK I found the stuff in Mcmaster. Thanks! I plan to add an oiler to my Emco lathe when I put it back together.
Greg
Old 03-01-2012, 09:02 PM   #7
crab
confused
crab's Avatar
I just put grease Zerk's in mine and made a high psi oil pump out of a grease gun. Not as good as a one shot but it works.
Bill
Central California
crab is offline
Old 03-01-2012, 11:30 PM   #8
RonGinger
RonGinger's Avatar
Likes Given: 5
I see on McMaster they are about $12 each, so its a bit of an expensive job if you need to lube 8 or 10 points. They have several flow ratings, but no way to guess which rating to use.
Does anyone know what size would be right for out home shop size machines?
Old 03-01-2012, 11:32 PM   #9
chuck foster
Liked 38 Times on 38 Posts
thanks for the idea bill...........now i can add that to my list......my long long long list of things to do....
chuck
the northern chuck
chuck foster is offline
Old 03-02-2012, 01:59 AM   #10
rkepler
Liked 31 Times on 26 Posts
Likes Given: 4
Likely an 00 or 0. As I recall they're designed to work with 12-15psi, you need to take that into consideration as well as some filtering before the oil gets into the line.
rkepler is offline
My first shot at scraping TroyO Machine Modifications 13 07-03-2012 02:31 AM
OILER CUP ZAPJACK Finished Projects 5 11-29-2010 06:49 AM
Parting shot SignalFailure Safety 7 11-15-2010 06:55 AM
IH Mill Prep for CNC Conversion: One shot oiler, Z-mod, etc. BobWarfield Machine Modifications 30 11-05-2008 07:25 PM
Screen shot Powder keg Computer Geek Zone 5 02-06-2008 04:33 AM
