Home Model Engine Machinist > Showing Them > A Work In Progress > Elbow Engine
Old 03-01-2012, 05:53 PM   #1
vascon2196
vascon2196's Avatar
Liked 285 Times on 195 Posts
Likes Given: 83
Default Elbow Engine
So I have decided to build the infamous Elbow Engine. I am using the plans found on the John-Tom website http://www.john-tom.com/html/SteamPlans.html.
Starting out with a bang (literally)...once I found out that I goofed the flywheel hub to the point of no repair I smashed it with a hammer. It sounds childish (and it is) but it felt great. Practice makes perfect right? The second attempt led me to make a fixture for mounting in the mill vice and everything went nice and smooth, so far so good. Next will be the flywheel rim.
The photo shows a correct flywheel hub and the hammered one. I have also included a CAD image of the fixture. It is a 2" diameter piece of aluminum cut to approximately 1" in length. I drilled and reamed a 1/4" hole in the center for a dowel pin and some 10-32 tapped holes for mounting. My intent was to create a program on the Bozo-Trak to cut (1) slot....I then unclamped the hub and indexed it 90-degrees using the dowel in the center. It worked out great. After the 4-slots were milled out I cut the outside diameter. After that I used the 4 outer tapped holes to mount the hub while I milled out the bore.
I can already see some of you (old school) machinists twitching in your chair asking "why didn't he use a 4-jaw chuck". Am I right Why do you think a hammer was taken to the first hub?
Chris
Chris
"A good craftsman never blames his tools"
vascon2196 is offline
Old 03-01-2012, 07:11 PM   #2
kvom
kvom's Avatar
Liked 614 Times on 485 Posts
Likes Given: 287
Default Re: Elbow Engine
Since you have a CNC mill, you "might" have tried it my way:
Mount soft jaws in the vise and mill a circular pocket equal in diameter to the flywheel stock. Then with the stock securely clamped you can mill the 4 pockets plus the center bore without moving the piece.
All's well that ends well.
kvom is offline
Old 03-01-2012, 07:28 PM   #3
vascon2196
vascon2196's Avatar
Likes Given: 83
Ahhhhhhhhhh.....that sounds better! See, this is why I like this forumn.
I make have to make a third flywheel now.
Thanks!
Chris
Chris
Old 03-01-2012, 07:33 PM   #4
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
On the other hand, why not make it without using CNC, then we can all enjoy your build.
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 03-02-2012, 01:59 AM   #5
vascon2196
vascon2196's Avatar
Likes Given: 83
John...I purchased a small rotary table a few years back for doing just that at home. But at the college I have access to the Proto-Trak and get to use it whenever I have time. This flywheel hub is the only part I will be using CNC for...the rest will be done manually.
Stay tuned...more to come.
Chris
Chris
Old 03-07-2012, 12:59 AM   #6
vascon2196
vascon2196's Avatar
Likes Given: 83
I finished the flywheel rim using 3-1/2" steel pipe as suggested in the plans. This was the first time I made a two piece flywheel so I was a bit nervous....and yes I had to scrap one because I removed too much material on the inside diameter. The second flywheel rim came out great.
The two brass cylinders came out fine...however the cylinder I planned on using for the flywheel did not fit and the cylinder that sits on the valve block did. I switched them around which is no big deal but now the cylinder that will sit on the valve block has a slight step in it.
I reamed the center holes of each cylinder to 3/16" diameter for a standard shoulder screw instead of a 1/4" screw like the plans had suggested. I felt that the head of the screw came too close to the pistons and made the decision to step it down a little. I like using shoulder screws anyway.
The valve block came out great and yes I used the Bozo-Trak to make the valve port slots...my rotary table is getting jealous!
Base tomorrow...I'm saving the pistons for last.
Chris
Chris
Old 03-18-2012, 10:53 PM   #7
vascon2196
vascon2196's Avatar
Likes Given: 83
Well I finished the sucker...and it seems as though I have a lot of "finessing" to do until it runs.
One I have it running there will be additional pictures and hopefully a video.
I am having a hard time spinning it freely by hand...it grinds an awful lot in a couple of areas.
I'll keep on cranking away though...
Chris
Chris
Old 03-20-2012, 09:39 PM   #8
vascon2196
vascon2196's Avatar
Likes Given: 83
I can't get this thing to work...is there any special way to assemble it for timing?
I have tried many different configurations and at 30psi it does nothing except leak air.
I machined and installed an o-ring into the base cylinder and that did nothing.
It spins freely by hand with a couple of rough spots.
Any suggestions? Should I smash it with a hammer?
Chris
Chris
Old 03-20-2012, 09:48 PM   #9
mklotz
mklotz's Avatar
Liked 140 Times on 260 Posts
Try lubricating the pistons with a heavy oil, eg 30 wt motor oil. That may form enough of a seal to get it to turn over.
Regards, Marv
Home Shop Freeware
http://www.myvirtualnetwork.com/mklotz
mklotz is offline
Old 03-20-2012, 09:52 PM   #10
arnoldb
arnoldb's Avatar
Liked 93 Times on 178 Posts
Hi Chris
No - the hammer won't work....
Where are the rough spots; this engine does not like rough spots... Are you trying to just turn the flywheel without any air pressure applied to the engine ?
What oil are you using for lubrication? - try different oils, starting with thin and moving on to thicker - mine runs best with diesel engine oil.
There's a problem with using thicker oils though - they provide a better seal (and stickier spots for spectators to rub off their faces ) - but introduce a lot of drag on the engine to overcome viscosity.
Regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Elbow Engine rustyknife Finished Projects 14 12-10-2011 05:17 AM
My Elbow Engine two dogs A Work In Progress 24 07-21-2009 02:23 AM
Elbow Engine? kvom General Engine Discussion 21 02-26-2009 10:10 PM
Elbow Engine J. Tranter Metals 5 11-01-2007 03:36 AM
My Elbow Engine Bogstandard Photos and Videos 44 08-21-2007 09:45 PM
