Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > A Work In Progress > STEN smg 1/2 scale
Old 02-16-2012, 12:06 AM   #1
IanN
Liked 17 Times on 14 Posts
Default STEN smg 1/2 scale
OK, I'm sorry that I've only just thought of posting this project here - it has been under construction for some time now.
The background:
During his National Service (in the 1940's) my father had an "experience" with a Sten gun. The incident became part of the family folk law and in a rash moment I offered to make a model of the Sten for my father.
The project was well underway - I completed the research and drew the appropriate drawings and had started the actual construction but my father passed away before the model was finished and my work on the task ground to a halt.
I re-discovered the model a little while ago and decided to finish it.
1 - casing 1.JPG   2 - casing 2.JPG   3 - casing detail 1.JPG   4 - casing detail 2.JPG
IanN is offline
Old 02-16-2012, 12:09 AM   #2
steamer
Liked 104 Times on 100 Posts
Default Re: STEN smg 1/2 scale
Hi Ian,
Cool, my friend trades in miniatures....and a well known member here makes some.
What caliper are you modeling? 22?
steamer is offline
Old 02-16-2012, 12:23 AM   #3
IanN
Hi Dave,
Legislation in the UK is such that the model is non-functional.
The chamber is 4.5mm and the barrel is drilled through at 2mm diameter (just so I can poke arod down the barrel to dislodge anything that got jammed into the 4.5mm chamber......)
Ian.
IanN is offline
Old 02-16-2012, 12:26 AM   #4
IanN
Hi Dave,
Ian.
5 - barrel.JPG   6 - barrel nut.JPG   7 - barrel nut detail.JPG   8 - barrel and nut 1.JPG
IanN is offline
Old 02-16-2012, 12:29 AM   #5
steamer
OK
Here in the states it is generally frowned upon....ie illegal...to make a machine gun without a "constructor's license", but you can get the paperwork sorted and do so.
I'm very interested in this project...I'll be watching along....but you have piqued my interest about your father and his run in!...
Welcome!
steamer is offline
Old 02-16-2012, 01:04 AM   #6
shred
Liked 34 Times on 34 Posts
That looks to be a neat little memento to be passed down. It looks like you've got a pretty good grip on it, but if you need anything from drawings, I can probably scratch some up.
shred is offline
Old 02-16-2012, 01:34 AM   #7
Stan
Liked 31 Times on 31 Posts
The Sten gun was a classic example of 'you get what you pay for'.
They cost less than $3.00 to produce during WWII.
Stan in Leduc, Alberta, Canada. 53.40NÂ* 113.5W
Old, but still on the right side of the grass.
Stan is offline
Old 02-16-2012, 09:20 PM   #8
IanN
Some more pictures of the Sten.
The magazine collar.
9 - barrel and nut assy 2.JPG   10 - magazine collar - 1.JPG   11 - magazine collar 2.JPG   12 - magazine collar 3.JPG
IanN is offline
Old 02-16-2012, 09:33 PM   #9
IanN
The casing assembly and the casing with the barrel.
13 - casing assy.JPG   14 - casing and barrel 1.JPG   15 - casing and barrel 2.JPG
IanN is offline
Old 02-16-2012, 09:52 PM   #10
IanN
The bolt and bolt handle
16 - bolt handle 1.JPG   17 - bolt and handle 1.JPG   18 - bolt and handle assy 1.JPG
IanN is offline
1/4 scale V8, first project. keith5700 A Work In Progress 411 07-17-2017 01:22 PM
1/6 scale Chevy V8 mklotz Photos and Videos 23 02-17-2013 06:34 PM
1/10 SCALE V8 schmetty A Work In Progress 5 08-05-2011 08:00 AM
Digital Z scale Noitoen Machine Modifications 11 01-04-2010 09:36 PM
Scale Hardware is the U.S.'s best source for scale model fasteners. PTsideshow The Break Room 21 05-21-2008 12:57 PM
