Project of the Month built by dnalot
Home Model Engine Machinist > Building Them > General Engine Discussion > milling machine question
Old 11-28-2011, 08:36 PM   #1
johndaddy
Liked 2 Times on 1 Posts
Default milling machine question
I am new to the forum and am in the process of buying a milling machine. Which is better Grizzly G0619 at $1469.00 with shipping wt. of 418 lbs or Lathemaster LMT25L at $1389.00 with shipping wt. of 340 lbs? Will be using for hobby building.
johndaddy is offline
Old 11-28-2011, 08:46 PM   #2
Chazz
Liked 2 Times on 2 Posts
Default Re: milling machine question
Generally, the rule of thumb for Milling machines is; "Get the biggest machine you can both afford and have room for. Our smaller 'hobby' machines need all the weight and ridigitity we can afford.
After that, bells and whistles, R8 has a larger holding range than MT3, power z or y axis, how much HP etc.
Have fun,
Chazz
Yellowknife, Northwest Territories, Canada
Craftex CT039 9 x 20 Lathe & CT129N Mill
Chazz is offline
Old 11-28-2011, 11:22 PM   #3
Entropy455
Liked 57 Times on 43 Posts
http://www.grizzly.com/products/Mill...wer-Feed/G1007
My first milling machine was the Grizzly G1007 (see above link). In my opinion, the G1007 is an excellent starter mill. It is not as rigid as a knee mill, but itís very robust by mill-drill standards. It has more than enough horsepower Ė so much so that if you attempt heavy cuts, youíll have the power, but the bit will chatter. With light (reasonable) cuts, it works great. The power feed is a dream! I could not imagine attempting to machine anything without the power feed. On that note: my next machine will have power feed on the y-axis also. . . The G1007 is easily maneuverable with a small shop engine crane. (See below link).
http://www.harborfreight.com/2-ton-f...ane-35915.html
I built a lifting fixture consisting of a small trapezoid piece of steel welded a 5/16Ē chain. The trapezoid steel piece will wedge-fit into the top inner-lip of the millís vertical cylinder (casting lip) providing an easy means of rigging the entire mill. Just pop off the dust cap and slip in the chain assembly for easy moving.
Iím not familiar with the G0619.
I do agree however that you should purchase the largest machine you can afford (and fit into the shop). The only exception would be if youíre only looking to manufacture the smallest of components Ė where a smaller machine might be desirable.
Entropy455 is offline
Old 11-29-2011, 06:58 AM   #4
Troutsqueezer
Troutsqueezer's Avatar
Liked 32 Times on 51 Posts
Ask ten hobby machinists a question and you'll get eleven different answers. With that in mind, here's my response. Buy the smallest and cheapest machine that will get the job done. Take the money you have saved and spend it on your wife. You will be much happier in the long run.
Trout
-Dennis-
Once you see the bandwagon, it's too late.
Troutsqueezer is offline
Old 11-29-2011, 11:00 PM   #5
moanaman
BarryG41
moanaman's Avatar
Liked 7 Times on 7 Posts
Likes Given: 7
I would prefer the Grizley over the Lathemaster of the 2 you are considering. It appears to have a larger column and hopefully more rigid.
Barry G
Barry G Moana South Australia
moanaman is offline
Old 11-30-2011, 12:17 AM   #6
bearcar1
Senior Member
Liked 43 Times on 43 Posts
Originally Posted by Troutsqueezer
............... Take the money you have saved and spend it on your wife. You will be much happier in the long run.
Trout
Spoken like a true gentleman. Well done Trout'.
BC1
Jim
bearcar1 is offline
Old 11-30-2011, 03:33 AM   #7
larry1
Liked 6 Times on 6 Posts
Likes Given: 7618
Trout, Truly spoken like a true gentleman thank-you very much. larry
larry1 is offline
Old 11-30-2011, 06:05 AM   #8
S3MIH3MI
S3MIH3MI's Avatar
Liked 5 Times on 2 Posts
Likes Given: 5
I'll bet he's away from the computer for a minute and that was his wife posting...
LOL
S3MIH3MI is offline
Old 11-30-2011, 02:53 PM   #9
Swede
Liked 29 Times on 29 Posts
A good wife would not begrudge her man a modest toy that would bring years of joy.
In the grand scheme... it's $1,400 bucks. Millions of men spend 8X that on motorcycles or other gadgets, or spend that annually on a golf course.
Swede is offline
Old 11-30-2011, 06:09 PM   #10
Troutsqueezer
Trout has learned a thing or two in his old age.
Sometimes I scratch my head at some of the advice given as to which machines are best. Best for you is not necessarily best for me. Whatever fits the bill is 'best'. So then we have to ask, what is the bill? Given this is HMEM, some terms come to mind such as 'hobby' and 'model'.
Now I don't know about you but when I think hobby, I don't think hogging out material as fast as I can. I might think along those lines if this were a production machinist's forum. No, I think that enjoyment, relaxation, taking all the time I want and thinking things through is where the rewards are in this hobby. Oh, and discussing those attributes in forums like this.
After dinner and watching Jeopardy with the wife, I head out to the shed for a couple hours each evening. I am quite satisfied upon entering to see my Harbor Freight mill and lathe sitting there, waiting for me to figure out my next part. I remove small bits of metal at a time. One evening, one small part, eventually an engine. Life is good. I also enjoy tweaking with those machines, make them as good as they can be. All at low expense. Contrary to belief, these machines bring "years of joy" as well as any other.
I have other hobbies. They require a budget as well. Most here probably do too. It just wouldn't work for me to starve my other hobbies because someone else thinks bigger and more expensive is always better. It's about enjoyment on as many levels as you can swing it, not about having the biggest and best toy. I need something that works. I don't need a monster truck if my Toyota is going to get me there and back. But hey, that's just me.
-Dennis-
lennardhme Likes This
Milling machine nsfr1206 Tools 11 12-02-2011 01:18 PM
XJ 25 Milling machine kendo General Engine Discussion 0 07-20-2010 10:38 AM
Looking for a milling machine mcr Buy / Sell / Trade / eBay 2 10-31-2009 07:24 PM
New Milling Machine Oldmechthings The Break Room 6 09-10-2008 09:40 PM
New milling machine question #1 Brian Rupnow General Engine Discussion 9 06-23-2008 03:50 PM
