Project of the Month built by TonyM
Home Model Engine Machinist > Building Them > General Engine Discussion > Drill sharpening jig
Old 11-23-2011, 08:41 PM   #1
firebird
Liked 76 Times on 76 Posts
Default Drill sharpening jig
Hi
Has anybody made a simple drill sharpening jig? I'd like to make something that I can use on my disc sander sooner than the grindstone. Any ideas welcome.
Rich
firebird is offline
Old 11-23-2011, 08:56 PM   #2
ShedBoy
Senior Member
ShedBoy's Avatar
Liked 41 Times on 42 Posts
Likes Given: 17
Default Re: Drill sharpening jig
I assume you know a bit about drill point geometry already. Try this site lots of good info
http://www.gadgetbuilder.com/DrillSharp.html
I have an inexpensive drill bit sharpener as described at the bottom of the page which seems to work okay once you know what is happening and what causes what. Here is a another page with some good ideas.
http://www.instructables.com/id/Shar...Bits/?ALLSTEPS
If you look through the rplies the is a different way to mount it which would be better. I am sure you will open a can of worms with this question. I am looking forward to the answers.
Brock
Don't follow me I'm lost too!
ShedBoy is offline
Old 11-23-2011, 11:01 PM   #3
ShedBoy
Senior Member
ShedBoy's Avatar
Likes Given: 17
Here is one for small drillls from the model engineering website.
http://modelengineeringwebsite.com/Small_drills.html
Brock
ShedBoy is offline
Old 11-24-2011, 12:07 AM   #4
rake60
rake60's Avatar
Liked 219 Times on 194 Posts
I worked with guys who could hand grind a drill bit perfectly every time.
I could never do that, so they were all very dear friends!
The problem with a drill sharpening jig is it doesn't really grind the relief
from the cutting edge.
Bits sharpened in a jig will drill but the cutting edge will often have zero or
even negative relief. They don't cut well and burn up quickly.
This isn't a plug for Drill Doctor, but it explains it better than I can.
Rick
Seriously, how many times can THAT happen in one day?
rake60 is offline
Old 11-24-2011, 12:52 AM   #5
Tin Falcon
Tin Falcon's Avatar
Liked 813 Times on 647 Posts
Likes Given: 18
I learned how to hand sharpen . I do I will say a decent job at it. I also have a drill doctor. It also takes some practice and feel but much more consistent than by hand. There had been an ongoing discussion about the drill doctor in another thread, so will not get too involved here.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 11-24-2011, 09:27 PM   #6
firebird
Hi
Thanks for all the replies so far. Thanks for the links Brock.
I have a disc sander in my wood work shop which I use for shaping wood (obviously) but also for grinding chisels, screw drivers, plane irons in fact pretty much anything I can throw at it. One of the best bits of kit I have ever made. I'm currently building a 8 inch version for the metalwork shop. Being able to grind on a flat surface is an advantage I find. I'm not keen on using the side face of a grinding wheel. I have sharpened some of my larger drills by hand on the disc sander with reasonable results but not as accurate as I would like.
I have seen the drill doctor before which looks to be a nice tool but not within my budget at the moment.
It seems there is a bit more to drill sharpening than first meets the eye.
My thoughts are if I can hold the drill bit at 59 to the disc in a jig of some sort then turn it I would at least be able to get a better more accurate grind. What do you think.
Rich
firebird is offline
Old 11-24-2011, 09:32 PM   #7
ShedBoy
Senior Member
ShedBoy's Avatar
Likes Given: 17
I met an old chap who use to sharpen his drills in that way with on addition, he ground the negative relief after the twisting part. This left no chisel point but a cone point, it worked okay for wood, don't know how it would go with steel but I think there would not be enough strength in the point. Drill point geomtry is the key.
Brock
ShedBoy is offline
Old 11-24-2011, 09:37 PM   #8
tel
tel's Avatar
Liked 110 Times on 105 Posts
Most of my drill sharpening is done freehand on the home made 7" disk sander as well - they do a good job. I am, however, having made the Harold Hall grinding table, looking to use that with the smaller sizes
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 11-24-2011, 09:40 PM   #9
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
how about one of these
http://www.generaltools.com/825--ORI...ENT_p_213.html
Old 11-24-2011, 10:09 PM   #10
ShedBoy
Senior Member
ShedBoy's Avatar
Likes Given: 17
That is the type I run, takes a bit to set up right but I have good results with it as long as it is mounted at the 12 oclock position on the side of the wheel. This way it grinds perpendicular to the cutting edge and makes for a strong edge, if you mount it at 9 oclock the cutting edge chips real easy. Good cheap tool and if you look you will see them alot in the background of posts so they are used. I got a big fluro magnifying desk lamp to help with set up of small drills. They work good on discs and belts too.
Brock
ShedBoy is offline
Tool sharpening in the UK Blogwitch The Break Room 0 03-15-2012 09:19 AM
Harold Hall Drill Sharpening Rest. Arnak Tools 7 07-10-2011 05:51 PM
Unknowm drill bit sharpening attachment clemlou General Engine Discussion 0 10-13-2009 02:14 AM
Hand Sharpening? BobWarfield Tips and Tricks 34 04-22-2008 10:43 PM
sharpening small drill bits gilessim General Engine Discussion 9 01-30-2008 04:23 PM
