Home Model Engine Machinist > CNC and 3-D Printers > Software and Programming > dead LCD monitor
Old 10-05-2011, 02:48 PM   #1
gbritnell
gbritnell's Avatar
Liked 552 Times on 527 Posts
Default dead LCD monitor
Gents,
I have an Acer 19 LCD monitor on my computer. While using it yesterday the screen went black. I pushed the on/off button and it came back on for 2 seconds and then it went black again. This time the power LED wasn't even lit. I substituted my other monitor and everything was fine so it wasn't a power or computer problem.
I went online and typed in 'LCD monitor repair and got quite a few answers. Some seem to think it's as simple as replacing a couple of capacitors while others recommend replacing the power supply.
Has anyone had any experience with this situation? I know a new monitor can be purchased quite reasonably but I really like this one as it is a square format, not widescreen.
Thanks,
gbritnell
Talent unshared is talent wasted.
gbritnell is offline
Old 10-05-2011, 03:05 PM   #2
Lakc
Liked 62 Times on 56 Posts
Likes Given: 17
Default Re: dead LCD monitor
Check this out.
http://en.wikipedia.org/wiki/Capacitor_plague
Its possible to fix it if your good with a soldering iron. Once you get used to a widescreen you wont look at a square monitor the same way ever again.
Jeff
Lakc is offline
Old 10-05-2011, 04:30 PM   #3
around
Junior Member
Liked 9 Times on 9 Posts
George,
I have just repaired a 24" LG widescreen that refused to power up. Four bulging capacitors on the power supply were the root cause. A few minutes with a soldering iron and the monitor was back in operation. Look for a service manual on-line to help with the dis-assembly of the monitor.
Adrian
around is offline
Old 10-26-2011, 12:15 AM   #4
reneepaiva
Liked 8 Times on 5 Posts
gbritnell,
Take a look on this site.
http://www.ccl-la.com/blog/index.php...itor/#more-605
reneepaiva is offline
Old 02-23-2012, 04:55 AM   #5
neptune769
Liked 5 Times on 5 Posts
Originally Posted by gbritnell
Gents,
Thanks,
gbritnell
I know its an old post. But have fixed your monitor or still have it? I have fixed 4 of my monitors. Your problem is 99% chance it is a capacitor problem in the Back light inverter. If you hold a flash light up to your screen while it is on you should see whatever is on the screen. If you have any questions feel free to contact me.
Dennis L.
neptune769 is offline
Old 03-18-2012, 07:56 PM   #6
Tin Falcon
Tin Falcon's Avatar
Liked 815 Times on 647 Posts
Likes Given: 18
I may be up agains a similar issue . I just picked up a cheap used monitor from a non profit. It had a 7 day return waranty. And the outlet is an hour and a half drive or so. my monitor is a veiwsonic. and it is acting jumpy . I and thinking look for cold solder joints on the analog output as well as looking for bulging caps.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 03-18-2012, 10:47 PM   #7
neptune769
Hi Tim,
That would be a good place to start. What is it doing exactly?
Dennis
Old 03-18-2012, 11:06 PM   #8
Tin Falcon
Tin Falcon's Avatar
Likes Given: 18
intermittent vertical hold not holding.
did it on my lap top. then had it on the main desktop for a few days then started acting up again. different machines different cable. my wife turned it off then it would blip but not show a picture. then would work after multiple power up attempts.still a bit jumpy
Old 03-18-2012, 11:34 PM   #9
Don1966
Senior Member
Don1966's Avatar
Location: Morgan City, Louisiana ( along the Gulf Coast)
Liked 39 Times on 39 Posts
Likes Given: 7
Tinfalcon this is just a shot, but if you ae having vertical problems on serval machines it could be coming from the power company. Most monitors sync there vertical to the line input 60 HZ. Your TV would also be affected. Like I said just shot?
Regards Don
How Many times I did that?
Don1966 is offline
Old 03-18-2012, 11:45 PM   #10
neptune769
I have had problems with "flickering" just before one of the inverters went out. I don't know why. I look for bad caps and hope for the best.
Monitor (Baker Ball Hopper) Mike N Photos and Videos 3 01-29-2013 12:38 PM
Monitor problems neptune769 Computer Geek Zone 0 02-18-2012 03:29 AM
New monitor settings gbritnell Software and Programming 2 05-15-2010 01:50 AM
new monitor and old video card ? bmuss51 Computer Geek Zone 9 01-25-2010 12:49 AM
USS Monitor Engine nlancaster General Engine Discussion 14 07-08-2009 04:15 PM
